Old Oct 29, 2011, 10:09 PM
JumpySticks is offline
Find More Posts by JumpySticks
Drifting off the reservation..
JumpySticks's Avatar
USA, LA, Broussard
Joined Jan 2011
Contest
The November BIG SKY Longest Duration Contest for all Electric Launched Gliders
THE NOVEMBER BIG SKY INTERNATIONAL
LONGEST DURATION CONTEST FOR ALL ELECTRIC LAUNCHED GLIDERS
THERMAL SOARING AND SLOPE SOARING
RULES AND INFO:
Contest will run from 12:01 am November 1 to 11:59 PM November 30 Eastern US time.
The contest is for ALL electric launched gliders or airplanes of all sizes, all materials and all controls. The contest is intended to help motivate you to develop your thermal and slope soaring skills.
The contest is open this to all e-gliders and, if you like, e-airplanes too. If it glides, it qualifies.
You can post as many times as you like using as many planes as you like, but only one will be counted per pilot per category regardless of what kind of plane you are flying. You can replace a shorter time with a longer time any point during the contest. You can fly as many flights as you like.
Goal - longest duration thermal and slope flights without use of the motor. I expect to see themal times in excess of 30 minutes and slope times in excess of an hour. But you are welcome to post any flight time you wish. Get your name on the list and be famous!
First, second and third place finishers in each category will receive an artfully designed, high quality, custom made, one-of-a-kind BIG SKY certificate of recognition including your name and/or moniker and the flight statistics you provide with your entry (including photo, video, gps or flight profiles).
THE PLANES:
* Any electric motor system
* Any wing controls and any wing span
* Any construction
BIG SKY - THERMAL SOARING
1) From a fresh hand or ground launch you can run the motor for up to 45 seconds, then you turn the motor off and you can not restart it. Reclimbs are not permitted. If you restart the motor the flight time is no good.
2) Motor time starts as soon as you apply throttle. This is an LMR, Limited Motor Run contest with a pretty long motor run allowed so that the motor run itself does not provide much advantage to anyone. Many will choose to shut off the motor in less than 45 seconds. No credit for shorter motor runs.
3) Soaring time starts when the motor goes off. Either you time the whole flight and subtract the motor run or you use two watches, one to time the motor run and one to time the flight. I have multiple timers on my radio so I can do this with my radio alone. How you do this is up to you.
4) You can time your own flight if you wish. You are on your honor. Time is truncated to the second. No fractions and no rounding. Read the seconds only.
5) Landing must be within 100 feet of the original launch location or the flight does not count. Landing must be on the ground/grass or pavement. Landing in a tree, bush, structure or other elevated spot that would not normally be a landing spot does not count. There are no other rules around the landing.
6) Time stops when the glider comes to a rest. So the clock keeps running if you clip a branch, or go to land and bounce back into the air. When the plane stops, time stops.
7) You can launch as many times as you like but each flight has to be from a fresh launch from the ground/hand. No reclimbs permitted.
8) Report your best time of the day by posting here. You can post as many times as you like, but only the best one will count. You can fly as many days as you like to work toward your best time. The goal is to achieve personal bests in the fun atmosphere of a contest.
BIG SKY - SLOPE SOARING
1) From a fresh hand or ground launch you can run the motor for up to 5 seconds, if you need it to get into the lift. I would expect most slope flights will have no motor run but some sites need a boost to the lift.
2) Motor time starts as soon as you apply throttle and is subtracted from the total flight time.
3) Soaring time starts when the motor goes off. Either you time the whole flight and subtract the motor run or you use two watches, one to time the motor run and one to time the flight. How you do this is up to you.
5) Landing has to be within 100 feet of the original launch location or the flight does not count. Landing must be on the same level as the launch. Landing down the slope or up in the trees does not count. You must come to rest in a "normal" landing spot and be able to walk over and pick it up. I realize this can vary by slope site so you are on your honor as to whether this was a normal landing.
7) You can launch as many times as you like but each flight has to be from a fresh launch from the ground or hand. No powered reclimbs permitted. If you restart the motor the flight does not count.
8) Report your best time of the day by posting here. You can post as many times as you like, but only the best one will count. Try as many days as you like to get your best time of the month.
For either contest you report the results via post.
Report Format:
Your Name - Real or RCGroup Name - your choice
Glider/plane name:
Thermal or Slope:
Date and Time of flight:
Duration of flight:
Comments - You are welcome to report anything you like about the day, the flight. Pictures, videos, gps plots, etc are welcome but not required.
I will maintain the thread and keep the second post updated with the top 10 Thermal and top ten Slope reports. Only one flight of each type will be recorded in the standings for each pilot. A new better time will replace the original.
THREAD CONTENT -
This thread is for contest reports and for discussion about the contest only.
Contest Records
Thermal:
Palo Lishak (aka TENDER in RCGroups)
Glider name: supra Stork electric
Thermal or Slope: Thermal
Date and Time of flight: October 29th 2011, start of flight 15:50 CET
Duration of flight: 1:45:40 (11 s climb with motor)
Slope:
Hunnerbunner
Duration: 2:33:14
Date: 4/26/11
JumpySticks is offline Find More Posts by JumpySticks
USA, LA, Broussard
Joined Jan 2011
Thermal Leaderboard:
Palo (aka TENDER in RCG)
Date and Time of flight: November 9th 2011, start of flight 14:05 CET
Duration of flight: 1:44:37
29 s (climb with motor) +
Sebastjan Hajnsek (aka seborossi)
Glider name: Elektra Super Light
Date and Time of flight: November 16th 2011, start of flight 13:05 CET
Duration of flight: 0:49:26
\Location: Middle of Slovenia
Forest Flyer
Plane: High Aspect 3.1 M
Date and time of flight: November 23, 2011 3:30 pm
Duration of flight: 38:55
Set-up: AXI 2820/10, 12x6 prop, 3S 2600 lipo., AUW 56 oz
25 sec. motor run
Leadchucker
Glider/plane name:Top Models Avia
Thermal or Slope:Thermal
Date and Time of flight: 8 Nov 2001 @ 13.30
Duration of flight: 35.50
22 second motor run to 200 metres
Location: South Jesey Golden Eagles R/C Club field,Pole Tavern,NJ
Pilottube
Plane: Radian RTF
Thermal/Slope: Thermal
Date: 11/7/11, 13:30
Flight Time: 26:45
30 second motor run
Robert Hubbard
Glider name: Radian Pro
Date and Time of flight: 10 November, 1030
Duration of flight: 16:06
Ray (aka 320pilot)
Plane: Poly Pulsar 3.2m:
Date: Nov 2 , 1430 EST
Flight Time: 10 minutes 08 seconds flight time: less 12 second motor run
Slope Leaderboard:
Mikegbogh
Date: 11/6/11
Slope: no motor run
Glider: Own design 2.5mtr span
Wind: light southerly
Venue: Tamatieberg Volksrust
Duration : 37 minutes
Old Nov 01, 2011, 05:03 PM
320pilot is offline
Find More Posts by 320pilot
320pilot's Avatar
Joined Mar 2009
Name: Ray (aka 320pilot)
Getting cold, 50 F or 10 celsius. A pretty short flight, but this is fall flying!
Not much lift, but I did stretch out the glide a bit, carving back and forth above a ridge, with some wind aloft. I had to keep moving around on the field, there was a tractor going up and down stacking the last cut of hay into winrows!
I flew again later, as sun was setting, in a smaller field with a friend who flies nitro helis. After catching some lift above a ridge line, I dumped it down, to show him a full flap, high speed descent, so time in the air, was short.
320pilot is offline Find More Posts by 320pilot
Old Nov 07, 2011, 06:27 AM
mikegbogh is offline
Find More Posts by mikegbogh
Upwardly Mobile
mikegbogh's Avatar
Roodepoort, South Africa
Joined Aug 2007
Slope attempt.
Hi guys,
This last weeken I drove 300kms to a PSS slope event and on sunday with a shift in wind and calm conditions and as the light gliders were all flying , I decided to fit my little video camera and fly.
No motor was used at all , and I even managed to take some video of the top of the 200mtr high communications tower looking down from above.
Mikegbogh
Date 6 th November 2011
Slope: no motor run
Glider :Own design 2.5mtr span
Good thermals and some patches of sink on the slope,, but an excellent days soaring, my batteries are recharged..
regards
mikegbogh is offline Find More Posts by mikegbogh
Old Nov 07, 2011, 02:25 PM
pilottube is offline
Find More Posts by pilottube
I ain't afraid of no highs
pilottube's Avatar
Spain
Joined Jun 2008
Plane: Radian RTF
Date: Nov 7 , 13:30
Flight Time: 26 minutes 45 seconds flight time: 30 second motor run
winds calm, sunny, warm weather.
Sometimes the plane just floats. My longest flight so far.
pilottube is offline Find More Posts by pilottube
Old Nov 07, 2011, 07:08 PM
USA, LA, Broussard
Joined Jan 2011
Finally....a slope entry! Thanks Mike.
Congratulations on that personal best Pilottube.
Yeah, sometime these planes seem like they're full of helium....good fun.
Old Nov 08, 2011, 08:34 AM
chickenwing is online now
Find More Posts by chickenwing
More Altitude, Less Attitude!
chickenwing's Avatar
United States, SC, Ninety Six
Joined Mar 2008
There's an idea... a mylar covered, sealed fuselage and wings charged with helium... I wonder if anyone has ever tried that? Hmmm...
chickenwing is online now Find More Posts by chickenwing
Old Nov 08, 2011, 05:01 PM
Leadchucker is offline
Find More Posts by Leadchucker
AMA7224 LSF1832
Leadchucker's Avatar
United States, DE, Seaford
Joined Sep 2008
Your Name - Leadchucker
Duration of flight: 35.50 on 22 second motor run to 200 metres
Fabulous weather for this neck of the wood this time of year with light winds, clear skies and *68*f air temperatures. No big boomer lift but many small wing wigglers, jus ride from one bubble to the next then the next......
Leadchucker is offline Find More Posts by Leadchucker
Old Nov 08, 2011, 07:30 PM
sonny1 is offline
Find More Posts by sonny1
Kool Kats Fly RC!! AMA 30462
sonny1's Avatar
United States, CA, Baywood-Los Osos
Joined Feb 2009
Nice to have a report on the capabilities of one of Top Model's planes, I've got my eye on one of those so it's nice to know they fly as advertised. I have an impromptu ALES contest coming up this weekend, maybe I will actually be able to post a time this month? Times are going to be hard to beat, but someone has to come in last, and it may as well be me!
Sonny
sonny1 is offline Find More Posts by sonny1
Old Nov 09, 2011, 09:08 AM
tender is offline
Find More Posts by tender
tender
tender's Avatar
Europe - Slovakia
Results from Slovakia
Nice weather conditions today: wind 0-1 m/s, temperature around 15C
Duration of flight: 29 s (climb with motor) + 1:44:37 gliding
tender is offline Find More Posts by tender
Old Nov 09, 2011, 09:47 AM
320pilot is offline
320pilot's Avatar
Joined Mar 2009
Nice times everyone
Old Nov 09, 2011, 12:09 PM
USA, LA, Broussard
Joined Jan 2011
That's it.....I'm going to Slovakia....
Palo, are there lots of RC Sailplaners in your area?
How long have you been flying?
Old Nov 10, 2011, 01:40 AM
tender is offline
tender
tender's Avatar
Europe - Slovakia
You are welcomme... Best choice for your trip is August 2012. Five days from seven in the air :-)
August 18/19th - Dubnica - Open SVK national - F5J
August 21/21st - Dubnica - SVK FAI F5J - demo competitions and trainig
August 23/24th - Trnava - F5J (F5J tour - final)
Around 12-15 boys in my area, approx. 50 e-gliders competitors in my country. Not much, bud good quality :-)
I start flying with RC-gliders in the begin of year 1969 (one channel bang-bang radio) :-).
You can see my "personal chronicle": http://www.rivamodels.sk/chronicle_en.html
Old Nov 10, 2011, 06:00 PM
USA, LA, Broussard
Joined Jan 2011
Wow, that's quite a history Palo.
So it's not just that Slovakia has the best thermaling in the world. It has more to do with experience than anything. Great planes help as well.
Glad to have you flying with us!
Old Nov 10, 2011, 06:38 PM
pilottube's Avatar
Spain
Joined Jun 2008
Andre Borschberg
Glider/plane name: solar impulse (63m wingspam)
Date and Time of flight: 8 July 2010, 5 am GMT
Duration of flight: 26 hours
Solar plane completes maiden flight (5 min 10 sec)
Sorry, I should have posted it in July... so I guess it is out of the contest.
Discussion The October BIG SKY Longest Duration Contest for all Electric Launched Gliders JumpySticks Electric Sailplanes 45 Nov 05, 2011 07:09 PM
Contest The September BIG SKY Longest Duration Contest for all Electric Launched Gliders JumpySticks Electric Sailplanes 94 Oct 02, 2011 08:30 AM
Contest The August BIG SKY Longest Duration Contest for all Electric Launched Gliders JumpySticks Electric Sailplanes 94 Sep 04, 2011 10:29 PM
Contest The July BIG SKY Longest Duration Contest for all Electric Launched Gliders JumpySticks Electric Sailplanes 92 Aug 02, 2011 06:27 AM
Discussion The june big sky longest duration contest for all electric launched gliders aeajr Electric Sailplanes 62 Jul 09, 2011 08:53 AM
