Old Oct 29, 2011, 04:23 PM
Jonas M. is offline
Find More Posts by Jonas M.
Team Swallow
Jonas M.'s Avatar
Germany
Joined Apr 2006
Build Log
DLG Project - Volume 2: Zone-V2 airfoils and a new fuselage mold
Guys, it's time for a new plane.
A couple reasons for that:
- I need to test Gerald's Zone-V2 airfoils
- I need a better fuselage with more room for servos and ballast
- My old mold is getting worn out and I'm not satisfied with the quality of the parts anymore
What should the new plane have?
- More room for ballast, the old one had the wing set pretty low that there was almost no room for ballast. I managed to get 50g in, but that's it.
- More room for rudder and elevator servos, I don't want to take the bottom part of the case off to get the servo in.
- The front part of the fuse is higher than wide just because I like the looks of it
- Pylon for a hinged horizontal integrated in the fuse
- Horizontal stab should be detachable for better ground handling
- Vertical tail mount usable for both right and left handers, I don't want to have to align the vertical tail at the required 0.6 deg everytime. The mount should guarantee that the vertical is always precisely positioned.
- The Edge airfoils were OK but for my lousy flying they were too little forgiving. I will try out GT's Zone-V2 series, they seem to be awesome from what one can read about them
Now for the fuselage mold:
- Way better surface finish on the plug than on my old one. I knew almost nothing about surface finish at the time. I just sprayed the paint on, waxed the plug and made the mold. This one gets a glass-like finish.
- Using tooling epoxy as first coat, not regular epoxy with black color paste and cabosil.
- This mold has to be lighter, I'm sick of carrying around that 35kg mold, it's completely unnecessary to make the mold that big.
- No three-piece mold this time, it complicates the process of laying up a fuselage and I didn't get very good results because of the separate wing saddle block.
And there will be a couple of smaller detail solutions that I like to share, I have quite a few of them in my back pocket.
I'd like to post lots of pictures, because we all like them, hopefully some videos, because we like those even more
I'll focus on surface finish of the plug, making the mold, making the parts and so on. I will also use spread tow on both fuse and wings. This is new to me, so we'll see how that goes.
Since my CNC mill is still a long way from completed I have to make this plane still with a bagged wing and a hand-shaped fuselage plug. But I don't see this as a downside. Building a really good and solid CNC takes a lot of time and effort if you're trying to design and make as many parts as possible by yourself. I'll take all the time it needs.
OK, let's take a peek at the 3D model.
I designed it with Rhino, really like this software:
As you can see, the fuselage design is different, the wing is a smoothed ZoneV2 2P by Gerald.
Enough babbling, let's start the building process!
To be honest: I've got a little head start already...
Jonas M. is offline Find More Posts by Jonas M.
Old Oct 29, 2011, 08:49 PM
samc99us is offline
Find More Posts by samc99us
Aurora Builder
United States, MD, Lusby
Joined Nov 2003
Looks sweet, I really like your vertical mount bracket idea! You will like the new airfoils, they have proven very much superior to previously published designs, the number of top-level molded airplanes incorporating them makes that pretty clear IMO!
I hope your CNC progress is less painful than mine, I'm just dealing with a simple foam cutter and it is much, much, much more painful than anything I've dealt with (combining hardware+software is never a good idea)
samc99us is offline Find More Posts by samc99us
Old Oct 30, 2011, 03:33 AM
DudleyLeRoux is offline
Find More Posts by DudleyLeRoux
scratch build everything
DudleyLeRoux's Avatar
South Africa, KwaZulu-Natal, Botha's Hill
Joined Aug 2009
If this is anything like your last one Jonas, it's going to be awesome.
DudleyLeRoux is offline Find More Posts by DudleyLeRoux
Old Oct 30, 2011, 08:44 AM
Jonas M. is offline
Team Swallow
Jonas M.'s Avatar
Germany
Joined Apr 2006
A note to wing and tail design: I've drawn the 2P wing just to have something to sit on my fuselage for the Rhino file. I don't know yet what wing I will build. Same goes for the tailgroup.
Making the plug:
I'd like to show you my method of generating templates for the front part of the plug.
After I completed the design and so that all the gear fits in and that I like the looks I extracted the top and the side view:
Both top and side view are being extruded:
Intersection of each surface with the other creates these yellow lines:
Top and bottom are made into surfaces:
Unrolling both surfaces makes them planar:
Along with the sideview (which is NOT unrolled) I now have the templates for top and bottom and the sides:
Old Oct 30, 2011, 08:58 AM
Jonas M. is offline
Team Swallow
Jonas M.'s Avatar
Germany
Joined Apr 2006
Unfortunately I didn't take any pictures of the rough shaping of the plug.
I will try to describe the procedure:
Grab a piece of MDF. Print out the templates. 3M77 the sideview template on the MDF. Cut it out with a hacksaw, band saw, whatever. Shape the sideview accurately by hand, make sure the top and bottom surface are rectangular to the sides. When that's done draw a centerline on both top and bottom surface. 3M77 the top and bottom templates in place. Now you've got a guidance for shaping the contour as seen from above. When that's done the plug looks like this:
From now on, the real shaping begins. I started with a block plane and rounded off the corners. Just make sure you don't alter the shape of the side and top view. The centerline on top and bottom should stay visible!
When the planing is done start sanding. Always with a firm sanding block to even out high and low spots.
Old Oct 30, 2011, 09:14 AM
Jonas M. is offline
Team Swallow
Jonas M.'s Avatar
Germany
Joined Apr 2006
The boom part:
I liked the rear part of my last fuselage so I decided to make only the boom part in my old mold and attach it to the new front part. I made the boom from 3 layers of 160 gsm fiberglass. No need to waste carbon on something like that I made it of 3 heavy layers just to have something to sand away later on.
For the attachment to the MDF I drilled a hole in the end, put a wooden dowel in, smeared lots of epoxy with microballoons and foaming agent inside the boom, aligned everything on a flat table and let it cure. The epoxy grew so fast before curing that half the length of the boom is now filled with epoxy-microballoon-foam.
After sanding away the excess epoxy I soaked the MDF with regular epoxy.
Brush on lots of epoxy, heat with a heat gun until all the gloss is gone and repeat that about 3-4 times.
There was also a bit of spackling necessary to create a nice transition from boom to MDF.
Old Oct 30, 2011, 09:31 AM
The_Builder is offline
Find More Posts by The_Builder
God Created me to Create
The_Builder's Avatar
Joined Nov 2009
Nice work my friend !
Luap
The_Builder is offline Find More Posts by The_Builder
Old Oct 30, 2011, 10:23 AM
jfrickmann is offline
Find More Posts by jfrickmann
Jesper Frickmann
jfrickmann's Avatar
Raleigh, North Carolina, USA
Joined Aug 2005
Looking good
jfrickmann is offline Find More Posts by jfrickmann
Old Oct 30, 2011, 10:30 AM
Jonas M. is offline
Team Swallow
Jonas M.'s Avatar
Germany
Joined Apr 2006
Thanks Paul and Jesper!
If any of you guys have questions or anything else please chime in.
Next step is to create a wing dummy.
How wired using just the bottom part of the cutting templates. Bagged with the approximate amount of cloth the wing will have.
Old Oct 30, 2011, 02:45 PM
RudolfE is offline
Find More Posts by RudolfE
South Africa, GP, Centurion
Joined Dec 2008
Hi Jonas,
Would my two fuselages be the old one or the new one?
Either way I'm going to order two of these again soon.
Rudolf
RudolfE is offline Find More Posts by RudolfE
Old Oct 30, 2011, 04:46 PM
Jonas M. is offline
Team Swallow
Jonas M.'s Avatar
Germany
Joined Apr 2006
Since I will be using a hinged stab this time I will include a stab mount on the plug.
I leveled the plug on its wing saddle area so that the boom part is also perfectly horizontal:
The rear part of the boom gets a piece of waxed chipboard located at the right distance from the boom:
A generous amount of bondo is added to form the pylon:
After that has cured I sanded it round until the shape looked fine.
Old Oct 30, 2011, 04:51 PM
Jonas M. is offline
Team Swallow
Jonas M.'s Avatar
Germany
Joined Apr 2006
Wing saddle:
The plug is carved out more than actually needed. I use a dremel with a drum sander:
Old Oct 30, 2011, 05:01 PM
Jonas M. is offline
Team Swallow
Jonas M.'s Avatar
Germany
Joined Apr 2006
To create a really smooth surface on the wing dummy I painted it with gelcoat and finished it. More on surface finish later...
This piece gets a coat of wax to ensure a good release. It is then placed under the fuse and everything is set right:
To create the wing saddle I simple put a good bead of bondo on the plug and pressed the very well aligned fuse onto the wing dummy.
To prevent having trapped air between wing dummy and bondo, I put the bondo in a ridge-like shape on the plug. When the plug is pushed down the wing piece makes first contact with the bondo in the center of the fuse. Excess bondo is then squeezed out from the middle to the sides:
Old Oct 30, 2011, 05:02 PM
Dbox is offline
Find More Posts by Dbox
One Idiot is plenty...
Dbox's Avatar
United States, OR, Portland
Joined Jun 2005
Jonas,dont leave the tail boom as a "straight boring stick".
On Your drawing its curved ,but not on Your plug.Correct me if I am wrong.
Looking forward to see Your next great work.
Yuri.
Dbox is offline Find More Posts by Dbox
Old Oct 30, 2011, 05:12 PM
Jonas M. is offline
Team Swallow
Jonas M.'s Avatar
Germany
Joined Apr 2006
Yuri, it's the other way around. The transition from mdf plug to oval FG boom is pretty smooth. The bottom has a slight curvature, approx. 10cm in length, after that it's a straight boring stick
Contest Homebuilts Using Zone/Edge/Drela Airfoils at 2011 Arizona Contests BavarianCharles Hand Launch 0 Apr 06, 2011 06:19 PM
Build Log Project Muy Thai: F5D fuselage mold Troy Composites Fabrication 13 Sep 11, 2010 08:12 PM
Discussion Zone and Zone Airfoils Flight Reports brentrob Hand Launch 27 May 29, 2010 03:52 PM
Wanted DLG Pod Mold/Fuselage j.m. Aircraft - Sailplanes (FS/W) 5 Feb 14, 2010 02:21 PM
Discussion KF Airfoils and a possible Project DLG Gull Wing Flying WIng GreenAce92 Sailplane Talk 1 Feb 22, 2009 01:23 AM
