Old Oct 29, 2011, 12:13 AM
Oian is offline
Find More Posts by Oian
USA, CA, Selma
Joined Sep 2004
Question
Hacker B40-5l
I just acquired a hacker B40-5L 4.4:1 motor (Kv 6720, Io 3.82, .0044 Ohms).
I can't find a lot of info on the motor, I think it may have been originally intended as a 7 cell motor (pre-lipo). I would like to put it in a free flight model and the actual motor run would be 10 sec. + a couple of seconds to get it launched.
The questions:
Would it be safe to run it on a 3S lipo? I ran the 3S numbers on the calculator on the Neumotor site and came up with the following: 10/6 folder, 85.12A, Watts in about 760, motor rpm 62985, 91.5% eff. The caution that came up: "motor voltage close to limit, check motor case temp".
The generic "instruction sheet B20,B40,B50" (It didn't list this specific motor) that came in the box lists the max. RPM as 60-80K, would the near 63000 be too high? would 12-13 seconds at this power level be OK? Would 3S be too much? I'd like to run 3S due to the lower amps and smaller prop (Large highly powered props can sometimes be problematic trim wise on a free flight)
Any comments would be greatly appreciated.
Thanks, John
Oian is offline Find More Posts by Oian
Old Oct 29, 2011, 03:00 PM
George Shering is offline
Find More Posts by George Shering
Scotland
Joined May 2005
I think this motor is best on 2S. There is a 2S F5B class for which it would be fine. The temperature and no load current would be too high on 3S I fear.
George Shering is offline Find More Posts by George Shering
Sold Hacker B40 5L 4.4:1 $135 shipped FULLSCALE Aircraft - Electric - Power Systems (FS/W) 3 Oct 25, 2011 03:48 PM
FS: Hacker B40-5L FAI Carbon + 6.7:1 PDX Slope Pilot Aircraft - Electric - Airplanes (FS/W) 0 Jan 05, 2005 09:37 PM
Hacker B40 5L in a Smart? GoodTill High Performance 8 Dec 01, 2003 05:43 PM
How good is the Hacker B40-5L? Frank Finley Electric Plane Talk 0 Oct 05, 2002 12:56 AM
How good is the Hacker B40-5L? Frank Finley Electric Plane Talk 0 Oct 05, 2002 12:41 AM
