Old Nov 25, 2012, 12:18 AM
eltreato is offline
Find More Posts by eltreato
"Unappreciative tosser"
eltreato's Avatar
Canada, BC, Vancouver
Joined Oct 2011
Originally Posted by ROLLING CIRCLE View Post
That elevator may have a bit too much Welders on it. Maybe cut and redo it and then the same old servo might work fine. Just a thought. We have cheapo HK orange servos in that plane. Seem to be working fine.
Thanks for the suggestion, I'm actually using floppy disk hinges, and they're just that, floppy. I scavenged the servos from an old e-flite CP Pro2 someone gave to me that wasn't worth restoring, so it's not like they're the best to begin with. I was thinking of using a tiny vise drill to put another small hole on the control surface horn a millimeter or so closer to the elevator to get a bit more throw. If that doesn't work I'll grab some of those orange servos on my next HK order. In the meantime I've got to figure out this lack of hovering busineess..
eltreato is offline Find More Posts by eltreato
Old Nov 25, 2012, 10:23 AM
Razors edge 29 is offline
Find More Posts by Razors edge 29
QuAd FaNaTiC
Razors edge 29's Avatar
Canada
Joined Aug 2009
How old is your motor.?
Try some different lipos
Unless yours is really heavy it should hover
Could be speed controller as well
Razors edge 29 is offline Find More Posts by Razors edge 29
Old Nov 25, 2012, 02:37 PM
eltreato is offline
eltreato's Avatar
Joined Oct 2011
Hi RE,
My motor is brand new. I also tried other known good Nanotech 350s that have a UMX adapter on the balance tap, that also work great in my 130x. These batts have xt60s on them as well, so I might go xt60 on the speed controller.
When you got your esc did you have to adjust the timing setting from low to medium or high to get more power as the instructions suggest? It doesn't seem to make a lick of a difference when I try.
I've posted in the power systems section and hope to get some other feedback there as well.
Thanks!
Old Nov 25, 2012, 05:38 PM
eltreato is offline
eltreato's Avatar
Joined Oct 2011
So.....uhh.....my prop was on backwards. Yep that's right, I never thought to check it, figured there was no camber on these props. If you're ever bored, try flipping your prop then flying, it's not too easy. Flew two packs through it with the prop on correctly and it is amazing. RE29, your suggested power combo is perfect. I can't wait to get more time to fly this thing, it's going to be perfect for the small parks in my area.
All the best!
Old Nov 25, 2012, 07:25 PM
QuAd FaNaTiC
Canada
Joined Aug 2009
Lol
Glad you're up in the air now
Now have fun and make some vids if you can
Old Nov 26, 2012, 01:46 AM
eltreato is offline
eltreato's Avatar
Joined Oct 2011
Well I probably won't have any footage anytime soon, I'm a one man show without a hatcam. My flying isn't much to watch either, but I've attached a couple photos, not all that different from anyone else's, except you can see the disk hinges, oh yeah, and the prop is on backwards.
Old Nov 26, 2012, 06:36 AM
QuAd FaNaTiC
Canada
Joined Aug 2009
Looks good
Old Dec 05, 2012, 04:23 PM
eltreato is offline
eltreato's Avatar
Joined Oct 2011
The more I fly this thing, the more I love it. It's turning out to be perfect for the small elementary school fields in my heavily populated neighborhood. It's sooo quiet too, which is a huge plus. Way quieter than the 2s micros I've been flying lately that would be a lot of work to keep flying in these tight areas I just got some 9047 props in the mail from when I was having my, ahem "thrust" issue. This thing hovers awesome with the prop mentioned in RE's review, I expect it to be even floatier with this one.
Old Dec 05, 2012, 04:50 PM
QuAd FaNaTiC
Canada
Joined Aug 2009
Glad your enjoying it
I should try those props
Old Dec 05, 2012, 05:11 PM
eltreato is offline
eltreato's Avatar
Joined Oct 2011
PM me your address and I'll send you one. It's the least I can do for all your help.
Old Dec 05, 2012, 10:20 PM
QuAd FaNaTiC
Canada
Joined Aug 2009
Thanks for the offer, but I tried one tonight actually at indoor
it worked the motor more than it seemed to like. but, mine is heavy now with all the extra glue.
I need a new one airframe me thinks.
I may try to recreate one out of depron or FFF and build it lighter using 5 gram servos and 6A esc.
Mine is a porker now and doesn't wanna fly slow anymore
she is a tough broad though - been flown hard all summer, a real testement to the design and nature of EPP.
I should've ordered some more EPP with my depron
Discussion Dynamic Foamy Concorde SST info Art Schmitz Pusher Prop Jet Models 1 Dec 22, 2012 09:21 PM
Mini-Review Review: Dynamic Foamy ultra-micro Yak-55 kit RealGambler Scratchbuilt Indoor and Micro Models 151 Jul 02, 2012 02:28 PM
New Product ******NEW YAK-55 Micro by DYNAMIC FOAMY******* DynamicFoamy Scratchbuilt Indoor and Micro Models 47 Mar 10, 2012 02:48 PM
Discussion Nano Warbirds from Dynamic Foamy matthew954 Scratchbuilt Indoor and Micro Models 9 Sep 22, 2011 06:53 PM
Discussion First Foamy Jet Flies - Dynamic Foamy F22 Buckeye95 Pusher Prop Jet Models 4 Apr 10, 2010 01:13 AM
