Sorry, I meant I bevel on side of the hinge
ie not top and bottom just one side, but on both sides of hinge! Quote:
Latest blog entry: Estes Rubber Band Condor gets powered...
I';ll have to look into these piano-hinge-style hinge.
I've used a similair type hinge made my dubro - they were okay. Quote:
No problem
Do you understand what I mean? I dont actually mean 45 (bevel) top and bottom on control surface, but just both sides of hinge line. For example for the ailerons you bevel the aileron flap itself underneath, then do the same to the underside of the wing. BUT if your using CA or floppy disk hinges, I wouldn't make a complete sharp point on top side of the bevel. You need foam to use the hinge material UNLESS, like myself and others use glue hinges. I think Bert actually has a pic in build video of this bird if I an not mistaken. Shows a close up of hinge itself. just want to make sure I'm not confusing you. |
No problem
Glad I could help |
No you just need good elastics or rubber o rings to hold it down
The elastics that come with motor aren't the best The prop hub does seem sloppy on motor yes; believe or not this is normal. I use rubber o rings which can be bought in plumbing section at hardware stores |
no probs
let us know how maiden goes |
pretty crappy weather around these days
![]() You'll need less elevator that you think lol It could be the esc settings making you think it is lack luster in thrust, or, maybe need better batts. Mine is heavy as its been re glued many times and still hovers. good luck when you get a chance Quote:
Mine are just jst
Is your motor new? Mine works fine on 2S nano tech 370s Perhaps you need to set throttle range on your esc or your order esc is bad First esc I ran in mine was a older plush 6 but it was pooches and exhibited similar behavior as yours did. Then I upgraded to plush 10 which works better with the 9 gram digit servos I am using anyways |
That elevator may have a bit too much Welders on it. Maybe cut and redo it and then the same old servo might work fine. Just a thought. We have cheapo HK orange servos in that plane. Seem to be working fine.
Latest blog entry: Nall happens 3
| Thread Tools | |
| Discussion Dynamic Foamy Concorde SST info | Art Schmitz | Pusher Prop Jet Models | 1 | Dec 22, 2012 09:21 PM |
| Mini-Review Review: Dynamic Foamy ultra-micro Yak-55 kit | RealGambler | Indoor and Micro Models | 151 | Jul 02, 2012 02:28 PM |
| New Product ******NEW YAK-55 Micro by DYNAMIC FOAMY******* | DynamicFoamy | Indoor and Micro Models | 47 | Mar 10, 2012 02:48 PM |
| Discussion Nano Warbirds from Dynamic Foamy | matthew954 | Indoor and Micro Models | 9 | Sep 22, 2011 06:53 PM |
| Discussion First Foamy Jet Flies - Dynamic Foamy F22 | Buckeye95 | Pusher Prop Jet Models | 4 | Apr 10, 2010 01:13 AM |
