Old Oct 28, 2011, 04:38 PM
oren_ben_nun is offline
Find More Posts by oren_ben_nun
Joined Aug 2011
I have a problem to collaborate open pilot through AURORA 9
to run them through AURORA 9
I'm building a new quad copter with an open pilot board. After installing the hardware and
updating the firmware to 110819 version, I had some difficulties with connecting the remote to the board.
1. The board is connected to the computer properly because there is a reject (there is a link) between the board and the computer and when I move the board I can see movement on the screen.
2. I have already set up a model in the transmitter and binding them with the receiver.
I know it works properly because the motor was connected directly to channel 3 in the receiver.
I have a problem with running the calibration. When I check the "run calibration" box I hear beeps from all the ESC's and nothing happens in the software on the screen, unlike the film ("get start") that shows that the sticks move. I can't make the motors work through the remote, however, I can work them through the output screen in the software.
What do I need to do in order to make the motors work through the remote???
** I tried to configure the reciver type PWM and PPM . and also I tried to change in the transmitter the model to heli and aero.
oren_ben_nun is offline Find More Posts by oren_ben_nun
Old Oct 28, 2011, 04:54 PM
Dolby is offline
Find More Posts by Dolby
Needs more bacon!
Dolby's Avatar
United States, WI, Milwaukee
Joined Jan 2011
The receiver type for Aurora 9 should be PWM. Did you update the firmware on your board? What firmware file did you use?
It is normal for the ESCs to beep when you run the input calibration. Once done with calibration click the [save] button. Then you should be able to move the sticks around on your TX and the red dots on the screen should move in the correct direction.
If you still have problems can you post some screen shots of the config screen for Aircraft & Input?
Dolby is offline Find More Posts by Dolby
Old Oct 28, 2011, 05:20 PM
Joined Aug 2011
firmware
Old Oct 28, 2011, 05:28 PM
Joined Aug 2011
http://youtu.be/DBg1ESGJrmU
Old Oct 28, 2011, 11:53 PM
daign is offline
Find More Posts by daign
My RC builds in my profile.
daign's Avatar
Joined Feb 2011
should post this at the OpenPilot Official forums. I reckon you'll get immediate help.
http://forums.openpilot.org/
daign is offline Find More Posts by daign
Old Oct 29, 2011, 02:03 AM
Joined Aug 2011
i already posted http://forums.openpilot.org but i still whiting for answer
Old Oct 29, 2011, 09:49 AM
Joined Aug 2011
Help
Old Oct 29, 2011, 03:00 PM
Joined Aug 2011
Old Oct 29, 2011, 06:12 PM
Gary Mortimer is offline
Find More Posts by Gary Mortimer
Gaftopher
Gary Mortimer's Avatar
Nottingham Road South Africa/Bedford UK
Joined Feb 2007
Are the servo leads plugged in the right way up on the receiver?
Gary Mortimer is offline Find More Posts by Gary Mortimer
Old Oct 30, 2011, 02:52 AM
Joined Aug 2011
Thank you
I feel like an idiot I was to be used in a file that comes with the installation and not with another file
I did not know that during the installation created directory containing the file PWA
The problem was solved thanks to everyone
Old Oct 30, 2011, 03:46 AM
Gaftopher
Joined Feb 2007
Good, pleased to hear it, you will always get a faster and more accurate response on the OpenPilot forums.
Discussion i have problem in my Hitec Aurora (SOLVED). Nobel0 Hitec/Multiplex USA 1 Jul 27, 2011 04:29 PM
Found Have DX8, want Futaba 8FG, Hitec Aurora 9 or better Roswalt Aircraft - General - Radio Equipment (FS/W) 14 May 02, 2011 01:01 PM
Discussion People have encountered a small problem with Hitec's Aurora 9 radio Enguneer Electric Heli Talk 9 Apr 17, 2011 11:37 AM
Help! Aurora 9 problem? Jacco Hitec/Multiplex USA 17 Apr 02, 2011 05:59 PM
