Hi, Ian-
Mine is close to maidening.... I just need to get some new wing servo covers (flat will work), and finalize the fuse install. I was happy when the plane weighed @ 70oz before checking the CG; But much to my chagrin it looks like it will need about 8oz in the nose to balance it. That is with the lighter LiFe batery though. I still wish the tails were lighter. 30g from the tails together would mean about 70g from the nose for a savings of 100g total. Total would then be @ 76oz, that would be nice. The carbon is .060 CF from http://www.goodwinds.com/merch/list....lidroundcarbon The teflon is #11 from http://www.tailboom.com/teflon.php R, Target |
Latest blog entry: Stork 4 Pro X-tail from...
Gonna use some of my buddy Merrill's clear covers, eventually to be painted red inside.
They make installation very easy, and have a proper sized bump for the servo arm. R, Target |
Joined Sep 2007
very promising for light condition, we'll soon see how it goes ballasted!
Cedric, |
Joined Feb 2012
The next flight with different settings are really promising. Curves are similar to a ping pong ball.
This is a really easy glider in flight. As said cedric, I will make a rectangular compartment ballast for reasons of space and to use the ballast of my Miraj 30.80. JB |
I would really lioke to see your ballast arrangement in the fuse, JB.
Did you use the servo tray that came with the Toba? Also, what is the unballasted ready to fly weight of your Toba? Thanks, R, Target |
Joined Feb 2012
Exactly Cedric, good memory, between 2.350 and 2.400 kg. I used the servo tray comes with the TOBA and a 1500mAh NiMH battery.
I think I would do my commands later as explained above to gain a little weight. 98mm is safe for the first flight but I think we can move the CG back I will post pictures when I have 5 minutes ... JB |
Thanks, JB.
R, Target, headed out to set his CG at @ 102 with permanent lead. I'll add some trim lead to get it to 98mm to start. |
