Espritmodel.com Heli Air
Old Dec 14, 2011, 03:32 PM
Australia, WA, Perth
Joined Apr 2006
Originally Posted by Zimodile View Post
Hmmm I wouldn't set too much by those settings. Inverse differential on the ailerons? Perhaps not.
Z
Hi all I have received another set up sheet for Toba & it appears that the differential was a typo..It is 6mm down & 8mm up Cg range is 94-98mm behind LE. Hook 92-96mm behind LE
Ian
Ian Thompson is offline Find More Posts by Ian Thompson
Old Dec 14, 2011, 03:46 PM
T.D.'s Avatar
Vancouver, Canada
"James' foils are freely available from him for anyone to use."
By the way, the JH8, 7.5 and 7 as used on the Typhoon and Strega make for one heck of a thermal duration/F3J wing.
I built a two metre thermal duration wing with them and it flies a bit like the Drela AG40 series.
Sorry for the thread jack Target.
T.D.
T.D. is offline Find More Posts by T.D.
Old Dec 14, 2011, 05:30 PM
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
No worries TD.
R,
Target
target is offline Find More Posts by target
Latest blog entry: Stork 4 Pro X-tail from...
Old Dec 19, 2011, 09:03 PM
Joined Jul 2004
Here is my dry fitting of my Toba. Hope all the pushrods, tow hook and ballast tube can be stuffed properly without binding.
By the way, I have rolled a smaller ballast tube and tailored a servo tray for fuselage.
The 6 pin connectors are fixed to the outside of the fuselage and the female connectors will be glued flush to the wing root.
PB
polar bear is offline Find More Posts by polar bear
Old Dec 20, 2011, 12:44 AM
launch high, go fast
luvF3b's Avatar
Latrobe, Tasmania, Australia
Joined May 2008
Fuselage plugs
I had a lot of trouble with the connectors loosening in the fuselage of my model (too much "precision landing" :-)
Tried cyano, epoxy and even sikaflex to glue them - no luck!
The solution to be tried next is to use double sided circuit board, which has worked well on previous models.
  • Cut a strip of board to match the plug width. Cut this strip to length to exactly match the spacing you need for the plug spacing in the fuselage.Take a notch out of each corner of the board to clear the front and back pins of the connector.
  • Score the copper to form 3 strips on both sides of the strip of board, with a wider center strip. Score the copper from the outer strips in the center.
  • Insert the board between the double pins of the plug. Solder the top 2 pins to the center strip of copper, and the bottom two the other side. Solder the front and back pins to both sides of the board.
  • Add a single power lead to the top, another to the bottom, then 4 signal wires that feed the Rx.
Here's a very crude attempt at a diagram
John
luvF3b is offline Find More Posts by luvF3b
Last edited by luvF3b; Dec 20, 2011 at 01:27 AM. Reason: Hmmm - technological illiteracy?
Old Dec 20, 2011, 01:01 AM
Joined Jul 2004
Wow, thanks for reminding. I may have the connectors glued to the wing while leaving the fuselage side hanging free.
PB
Old Dec 20, 2011, 03:47 AM
Don't milquetoast me!
satinet's Avatar
Warwickshire, England
Joined Sep 2006
John
cool
satinet is online now Find More Posts by satinet
Old Dec 20, 2011, 09:24 AM
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Thats very similar to the gadget that they have in the Fischer Estrella. It works good!
R,
Target
Old Dec 20, 2011, 01:03 PM
Hardware in the loop
vespa's Avatar
Thousand Oaks, CA
Joined Mar 2004
You can just use 5200 to glue the multiplex plugs. It can never come out no matter what but is easy to remove whenever you want. It's also infinitely strong yet extremely flexible. Really a best of both worlds kind of thing but unfortunately it is unbelievably messy.
vespa is offline Find More Posts by vespa
Old Dec 20, 2011, 05:07 PM
I do this for fun!
Sunshine Coast, Australia
Joined Sep 2004
I normally use Gorilla CA for one half to get it aligned quickly and easily with some 'give', and then use Goop for the other half for all the reasons listed above by Vespa.
I'll put my 'precision landings' up against yours any day John
My plugs have never come loose yet.
skyboyken is offline Find More Posts by skyboyken
Old Dec 20, 2011, 05:20 PM
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Just an FYI, they make standard and "fast cure" 3M 5200....
And they also make a 3M 4200, you might look into all of those if you haven't already.
The original 5200 takes a REALLY long time to dry, like a week, can dry underwater, and comes in other flavors besides white.
R,
Target
Old Dec 20, 2011, 05:36 PM
vespa's Avatar
Thousand Oaks, CA
Joined Mar 2004
Yes Goop is pretty similar and more readily available though it's not nearly as flexible and it skins over pretty quickly so it won't flow as nicely as the 5200. Also, many adhesives (RTV for example) will corrode metal contacts if applied directly -- 5200 does not, I don't know about Goop.
"Fast cure" 5200 takes forever to dry. Longer than anything you have ever seen. The regular 5200 takes much much longer. 4200 is the same but just weaker so there is some possibility of removing it later. 5200 is nearly impossible to remove but I have had success with lots of isopropyl scrubbing within the first few days.
Old Dec 20, 2011, 07:02 PM
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
That's pretty funny.
Been working on boats (what 5200 is actually made for) since I was 17. That's 31 years, sonny! :-)
Here's a tip for you, that may, or may not, have molded sailplane applications....
When we were using "52Billion", that's what we called it, in a cosmetic application, to make a nice fillet, we'd use low tack masking tape first on the two surfaces the fillet connected. Then the 52billion was applied carefully from the gun.
Then a gloved finger, dipped periodically in plain old paint thinner was used to "work" the fillet. The goal was to have as much 5200 removed from the masking tape as possible, leaving a thin edge on the fillet.
Then, after a short drying/inspecting period, the tape was carefully peeled back, directly into a trash can.
You might try denatured alcohol, or even WD40 instead, for similar applications.
I've used 5200 before for servo tray installs; works well, but as you said, it tends to get places you don't intend.
Also, 5200 is pretty heavy, so that is something to consider aft of the CG.
R,
Target
Old Dec 20, 2011, 09:09 PM
registered user
Australia
Joined Sep 2008
Is the Toba flying yet ? . .
AlpineDSacro is offline Find More Posts by AlpineDSacro
Old Dec 20, 2011, 09:50 PM
Joined Jul 2004
Just noted that the RC car guys have some Strong thick and flexi CA glue for bonding their wheel and sponge tires. Maybe a good stuff.
