Old Oct 08, 2012, 07:08 PM
Ian Thompson is offline
Find More Posts by Ian Thompson
Australia, WA, Perth
Joined Apr 2006
Have done the modifications to the controls.
Before CG @ 98mm : Fuselage with supplied pushrods : 653g
pushrods as fitted 39.68g
After CG @ 98mm : Fuselage with teflon tubes & carbon rods : 594 g
Weight saving 59 g
Has certainly tidied up the nose a bit :-)
I haven`t flown it yet so I dont know if there will are real time dramatic improvements but every little bit should help ..
I will get around to weighing the whole model sometime
Ian
Ian Thompson is offline Find More Posts by Ian Thompson
Old Oct 08, 2012, 07:55 PM
target is offline
Find More Posts by target
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Thanks for the report, Ian.
I'm happy to know that it saved you that much weight.
Its weight that didn't really enhance the model in any way; provided that the pushrod tubes stay glued securely to the fuse sides, you may even notice BETTER tail precision from the plane.
R,
Target
target is offline Find More Posts by target
Old Jan 27, 2013, 12:30 PM
Deguelle JB is offline
Find More Posts by Deguelle JB
Joined Feb 2012
Hi all,
After one year of use, what is your feeling about the Toba?
What are your settings?
Personally, after the V-Tail rigidified it goes much better.
In flight it gets complicated! I feel the Toba like ballast. Unfortunately it is too soft. Its flight envelope is very reduced!
I just stiffen the fins. I'll let you know after my next flight.
See you soon
JB
Deguelle JB is offline Find More Posts by Deguelle JB
Old Jan 27, 2013, 03:42 PM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
JB-
What did you do to make the V-tails more stiff?
Regards,
Target
Old Jan 28, 2013, 05:25 AM
Joined Feb 2012
Hello,
I placed a balsa reinforcement under the lip of waterproofing. I did the same thing on the ailerons. Winning is important but not absolute. The rudders are still a little soft.
My biggest problem concerns the rigidity of the fuselage.
I think it is a good glider but too soft to show what it is capable.
JB
Old Jan 28, 2013, 06:50 AM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
OK, thank you.
R,
Target
Old Feb 03, 2013, 07:40 AM
Joined Feb 2012
Hi,
I just made a flight this morning with the changes. It is incomparable! The glider is much more accurate trajectories and also more reactive. I loved it!
JB
Old Mar 04, 2013, 02:28 AM View Post
olerc
A moderator felt this post violated the following rule: Excessive Advertising (Over-competition). Show it to me anyway.
