Did some more building on the Toba.
I knew that the geometry on the ailerons was less than ideal, and I should have changed the horns from the beginning, but I wanted to have a RTF plane for the weekend. As soon as I switch from my soft bench test CP1300 x 4 battery to a 2S LiFe, Poof(!) went a 761 on unregulated 2S Life. After that happened, I resolved to change out the aileron horns, and probably the flap horns as well. The aileron horns were very short, and the hole was @ 2-2.5mm ahead of the hinge line, giving great up aileron, but terrible down aileron. If I were to only use this plane on the slope, it probably would have been OK, but since its an F3B plane, it will need a decent amount of down aileron for launch camber, and the geometry was really bad for holding that position under load anyway.... So it needed to change, and, I knew I wasn't going to pull the original servo, and leave the horns so short. I also finalized the fuse install with radio gear and nose weight, etc. Came in at exactly 80oz at 98mm. I am almost certain I will bring the CG back though. Pics....
Toba is pretty much ready to maiden.
Also, I have ordered brass bars for ballast from www.speedymetals.com My thought is that even though the wing ballast slot doesn't start until after the CG, maybe by adding some slugs to the forward (or aft) cavity of the wing joiner, the CG will be retained (!?) I hope. I'll report after the brass gets here and I get time to cut it (probably a couple of weeks. I have opted to NOT use the stock bulged covers.... So Vespa, you have won this argument. I used Merrill's "Servo Bumps" painted red on the inside for the flaps, and he's supposed to hook me up with some flat servo covers that have a tunnel for the aileron linkage. But I don't have them yet. Here's some pics of the finished (except the aileron covers) plane on my new back yard paving stones. R, Target |
Well-
I was bushed after a long two days offshore blowing stuff up, and I have to be back at work tonight, so, instead of going to the slope race and wasting time waiting for wind, I decided to be productive and cut up the brass bars I bought for ballast for Toba. The plane holds 3 large slugs in each wing, and 3 slender slugs in both the joiner cavities. Total ballast is 40.5 oz, or 1150g.... So, with the empty weight at 79.5oz or 2254g, the full weight moves to 120 oz or @ 3400g full. I think that is good enough for sportsman F3B or F3F. If one went to molded lead, you could likely add about another 10 oz or a little more. The CG moves from my empty CG of 100mm to 101mm if I fill up the after cavity in the joiner, while filling up the wings. The CG moves to 99mm if I fill up the forward cavity of the joiner as I fill up the wing. The CG moves to 97.5mm if I fill both joiner cavities and the wings. See attached pics. One point I don't think I covered, is that I used the "male" MPX Plug (female plastic housing) in the wings, and the "female" (male plastic molding) on the fuse. The plugs stick out of the fuse, but since the fuse was molded with a nice little recess, just opening the hole for the pins means they will NEVER push into the fuse, and that there is plenty of clearance in the fuse for the wires.... Why I have EVER done it differently is unknown to me....
I will not guess just yet at the RTF weight Chris, but you might be close indeed.
The fuse is nice and light; I wish the tails were a bit lighter, but I will wait and see how the build goes, before casting judgement.... There are several things that I like about this design. R, Target |
Latest blog entry: Stork 4 Pro X-tail from...
I hear you on the aileron hinging, but I'm not certain that I agree on the bulged covers...At first, I thought the same as you, but after a while, I see the logic.
If your servo choice requires a bulged cover, you are good with these. Remember, this plane is aimed at the entry-level or budget F3B guys, so just maybe, they will be using 761 or 368's or some other selection that won't fit flush?? That's my thought. If RCRCM wanted to go with two sets of covers included, then a set of flat covers would be a good addition, and cover the option of thinner servos... Just my thoughts. R, Target |
