Old Oct 27, 2011, 05:48 AM
rcguy1958 is offline
Find More Posts by rcguy1958
USA, NY, Poughkeepsie
Joined Mar 2010
Question
Help making a "hot wire cutter" from soldering iron
I recently had an idea and am wondering if it is feasible. I have a Radio shack soldering iron, that has digital temperature control, and I'm wondering if this can be used as a "hot wire" controller. It does have 4 wires feeding the iron, didn't want to disassemble it without knowing if it's a viable idea.
Any help with this would be greatly appreciated
rcguy1958 is offline Find More Posts by rcguy1958
Old Oct 27, 2011, 08:02 AM
jkettu is offline
Find More Posts by jkettu
Joensuu, Finland
Joined Mar 2002
Most likely two of those wires are for heating element power and the other two for a temperature sensor feedback. I don't immediately see how and where you would install the temp sensor.
jkettu is offline Find More Posts by jkettu
Old Oct 27, 2011, 11:31 PM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
You don't say how many watts it is, but I don't think you have enough power. There's a good video on YouTube on how to build one for pretty cheap. What type of cutting are you doing? How big (wide)of a bow do you need?
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Oct 28, 2011, 04:15 AM
Joined Mar 2010
Actually it's a moot point now...I own a Icharger that has the control built into its software( after posting my question checked out the similar threads at the bottom...found a how to on using the Icharger software )
Thanks for the responses guys.....this iron will remain for cutting grooves for strengthening spars.
Help! Hot wire cutter kiranprasad Electric Motor Design and Construction 23 Jul 27, 2011 03:59 PM
Help! Hot wire cutter kiranprasad 3D Foamies 12 Jun 13, 2011 03:23 PM
Discussion Making your own planes with a CNC hot wire foam cutter dberladyn Foamies (Scratchbuilt) 14 Aug 20, 2009 11:14 AM
Discussion Need advise making hot wire foam cutter Fuelman DIY Electronics 7 Nov 22, 2008 12:04 PM
