This thread is privately moderated by Twyl, who may elect to delete unwanted replies.
Old Oct 27, 2011, 12:57 AM
Twyl is offline
Find More Posts by Twyl
Trader Rating: 7
Silent Flight
Twyl's Avatar
United States, CA, Cypress
Joined Jul 2005
Trader Rating: 7
Wanted
Speedo Thermal wing cores
I'm sure many guys have cut wing cores for the Speedo and probably cut more than one at a time. Any spares laying around?
Would be interested in pre-bagged wings as well I guess.
Twyl is offline Find More Posts by Twyl
Old Oct 27, 2011, 09:36 AM
Kholder116 is offline
Find More Posts by Kholder116
Trader Rating: 52
United States, NY, New York
Joined Dec 2004
Trader Rating: 52
unfortuntely where I live doesn't accommodate slope flying but that is sure some beautiful view you have.....
Kholder116 is offline Find More Posts by Kholder116
Old Oct 27, 2011, 11:17 AM
Twyl is offline
Trader Rating: 7
Silent Flight
Twyl's Avatar
Joined Jul 2005
Trader Rating: 7
Thanks, I'm blessed to have one of the better cliff slopes not to far from my work in SoCal. As I find myself flying here more often than not, and adding ballast to the Speedo just to keep it stable I'm considering beefing it up so the weight is actually contributing to the strength of the bird. (i.e. better wing, socked fuse)
That said, I just got back from a business trip to the east coast including NJ/NY and I have to say I envy your fall colors, very beautiful. SoCal can be very bland.
Old Oct 27, 2011, 12:17 PM
Mike Furcolow is offline
Find More Posts by Mike Furcolow
Trader Rating: 3
Mike Furcolow's Avatar
Paonia, Colorado
Joined Sep 2004
Trader Rating: 3
I made a up three sets of EPP wings for myself and my friend to fit onto our Speedo's....They have lots of hours on them now, with no damage, and they fly great!! It's well worth doing. I built them with traditional EPP techniques, carbon spars and covered with NewStuff.
refer to Outlaw Speedo Thread, post #227. There are some pictures here;
http://www.rcgroups.com/forums/showp...&postcount=227
Here's a list of materials and where you get them;
New EPP Speedo Wing-
Design concept; A more durable wing design with the same or better flying qualities as stock Speedo wing. It will be made of EPP foam and have carbon fiber spars, cross-weave taping to reduce twist, covered with 5mil NewStuff which is doubled over the leading edge in a D-box design. Ailerons will be balsa, and "full-span", for more positive roll control.
[B][I]Materials[B][I];
Wing Cores; EPP foam 1.9 density, CNC cut by Andrew at www.CanuckEngineering.com
Airfoil; RG15-8.5%
Wingspan; 54" 1371mm (27" per panel) (a little more span than stock)
Root Chord; 6.5" 160mm
Tip Chord; 4.0" 102mm
LE Sweep 2.5" 64mm
Washout 1 degree
Spar slot .240" 6mm
Cost; about $20-25
Wing Spars; Carbon Fiber tubing, .210 diam. Need 2 Cost; 2 x $1.40
http://canuckengineering.com/new/con...-x-140id-x-315
One Carbon Fiber ribbon spar, 60" for drag spar Cost: $7
http://canuckengineering.com/new/con...on-flat-ribbon
One wing joiner tube; fabricate from 1/4" brass tubing from local hobby or hardware store
Covering; NewStuff, 5mil, Cost; $0.36 per foot
http://canuckengineering.com/new/con...mil-cp-12-wide
Shop Materials;
Scotch Extreme cross-hatch tape, M77 Spray Adhesive, GOOP, balsa aileron stock
I wanted a little more wingspan and longer ailerons for better handling. This wing will be STIFF.
Mike Furcolow is offline Find More Posts by Mike Furcolow
Old Oct 27, 2011, 12:38 PM
Twyl is offline
Trader Rating: 7
Silent Flight
Twyl's Avatar
Joined Jul 2005
Trader Rating: 7
Hey Mike, thanks for the link. I've read and reread your Speedo socking thread many times and actually have the carbon sock and resin you recommended on order right now. You should seriously be getting royalties from both companies you plugged as I'm sure their business has seen a bump. The materials should arrive sometime next week so will see how it goes from there. I've been a long time flier but am a real newbie to building, your threads for the Speedo have been a big inspiration so again, thank you very much.
Old Oct 27, 2011, 05:43 PM
steeg is online now
Find More Posts by steeg
Trader Rating: 103
United States, CA, Costa Mesa
Joined Oct 2009
Trader Rating: 103
are going with epp or are you going to skin some foam cores.
i am leaning toward sheeting some foam cores and trying my first
bagging maybe.(for my speedo)
foodsaver probably
steeg
steeg is online now Find More Posts by steeg
Old Oct 27, 2011, 05:52 PM
Twyl is offline
Trader Rating: 7
Silent Flight
Twyl's Avatar
Joined Jul 2005
Trader Rating: 7
foodsaver probably
steeg
Hi Steeg, I was kind of thinking sheeted foam cores as well, although EPP like Mike pointed out might be fun too. Either way I would like to get a sturdier and cleaner wing with full size aileron (flaps would just be silly but...)
What slope do you call home in SoCal?
Old Oct 27, 2011, 07:14 PM
Twyl is offline
Trader Rating: 7
Silent Flight
Twyl's Avatar
Joined Jul 2005
Trader Rating: 7
Steeg, btw I ordered two sets of material for socking the Speedo and as of yet, I only have one Speedo. If you're interested and you can help me out with a wing I can maybe help you out with socking your fuse.
Old Oct 27, 2011, 08:57 PM
steeg is online now
Trader Rating: 103
Joined Oct 2009
Trader Rating: 103
well
first of all im the guy who has been raving about seapoint.
i was thinking if i have strong wings i will need a strong fuse
sounds like a good plan
i think we both could gain some building experience from this
steeg
Old Oct 27, 2011, 11:26 PM
Twyl is offline
Trader Rating: 7
Silent Flight
Twyl's Avatar
Joined Jul 2005
Trader Rating: 7
Sounds like a plan.
I got the sock and heatshrink material today, resin/epoxy probably won't be in till late next week though. Be in touch.
New Product Capture 54 Flying Wing Cores MWCores Flying Wings 18 Nov 03, 2011 10:52 AM
For Sale Rohacell foam 31 and 51! Wing skins! Tail cores! FairlyFaded Aircraft - Sailplanes (FS/W) 0 Oct 20, 2011 04:47 PM
Sold Samari'ish Fuse+Wing Cores $100 Dan.Cummins Aircraft - Sailplanes (FS/W) 6 Oct 09, 2011 10:51 PM
New Product Capture 54 Flying Wing Cores MWCores Aerial Photography 0 Oct 04, 2011 10:56 AM
Sold Tiger 60 foam wing cores freddy s Non R/C Items (FS/W) 0 Sep 21, 2011 04:02 PM
