Old Oct 26, 2011, 09:37 PM
SNice is offline
Find More Posts by SNice
SNice's Avatar
Philadelphia, PA
Joined Aug 2009
BIG 48" Sbach 342 - Full Fuse, True Airfoil, 3D - Video Added!!!
UPDATE: 2nd FLIGHT....Man, I LOVE this hobby!!!!!!!!
SNice Sbach 342 - 48" R/C Scratchbuild (11 min 36 sec)
I'm well into this project and it is going great so far! This is a 48" version of my 34" Sbach 342 3D -- aka the "SNice-bach". The main difference between the two is that this one is much larger and sports a built up wing with a symetric airfoil. Can't wait to get this one in the air!
Here is the thread for the 34" version:
http://www.rcgroups.com/forums/showthread.php?t=1425930
I am finally at the point where the project is starting to resemble the model I am intending to build so I have posted a few pics below.
This is the largest and most scale plane I have built so far. It is also the first time I have used a built up wing.
More to follow -- Including plans, wing templates, videos, and build pics...
SNice is offline Find More Posts by SNice
Old Oct 26, 2011, 10:46 PM
rchank is offline
Find More Posts by rchank
I used to like trees
rchank's Avatar
United States, WA, Spokane
Joined Jul 2011
Looks good SNice. I recently finished the box fuse SBach and love it. Will the wings be detachable on the 48"?
rchank is offline Find More Posts by rchank
Old Oct 26, 2011, 10:51 PM
planecrazy1969 is offline
Find More Posts by planecrazy1969
Gone Fly'n
planecrazy1969's Avatar
USA, NV, Las Vegas
Joined Jan 2007
Very cool...I'm watch'n
planecrazy1969 is offline Find More Posts by planecrazy1969
Old Oct 27, 2011, 12:36 AM
pccdtk is offline
Find More Posts by pccdtk
Chitila / Romania
Joined May 2008
Beautiful ....
....Sbach .....I starting my own ( using 3D model as plan ) at 48" ws. Look forward to see yours...( for inspiration )
pccdtk is offline Find More Posts by pccdtk
Old Oct 27, 2011, 01:10 AM
djacob7 is offline
Find More Posts by djacob7
Zen in the art of foam
djacob7's Avatar
United States, CA, Fremont
Joined Jan 2009
Very nice build! Was the pink foam hot wired or carved?
djacob7 is offline Find More Posts by djacob7
Old Oct 27, 2011, 09:38 AM
SNice is offline
SNice's Avatar
Philadelphia, PA
Joined Aug 2009
Thanks Guys,
To answer a few of the questions...
Yes, the wings will be detachable -- with a 48" wingspan, that will be the only way I could safely transport it and store it. I would really like the tail to be removable too but that might be more trouble than it's worth.
The foam I have used in this plane is Dollar tree foamboard, 3/4" pink insulation foam, and white insulation foam (I think it is EPP (?)). I only have a small, handheld wire cutter so I am limited in what I can cut. The wire is only about 5-6" across. So it is mostly carving and sanding, and wire cutting when I can. When I post fuse pics, you will be able to see details of the fuse construction much better. In a nutshell, the lower half of the fuse is box fuse construction, and the upper part of the fuse and the nose are carved.
Old Oct 27, 2011, 07:18 PM
RedRanger is offline
Find More Posts by RedRanger
Did you say up or down?
RedRanger's Avatar
Canada, ON, Brampton
Joined Mar 2011
Subscribed
Please don't take this the wrong way but I think I love you
E.
RedRanger is offline Find More Posts by RedRanger
Old Oct 28, 2011, 03:40 PM
SNice is offline
SNice's Avatar
Philadelphia, PA
Joined Aug 2009
lol!...added pics showing fuse progress. Also added the wing panels to the plans. The plan is just a blown up version of my 34" Sbach. I did the nose a bit different with this on and I also made it much sturdier.... Once I can clean them up a bit more, I will post the full plan...
Old Oct 28, 2011, 09:40 PM
RedRanger's Avatar
Joined Mar 2011
I thought that piece of styrofoam behind the box fuse was your version of a lizard monster Took me a minute to figure out it was your rough canopy structure
I give you the next two days off work to spend on this plane!
Lookin' good!
E.
Old Oct 28, 2011, 10:37 PM
SNice is offline
SNice's Avatar
Philadelphia, PA
Joined Aug 2009
Lol! Thanks, RedRanger! I does look like a lizard monster! That pic was taken as the rough fuse halves were being glued together. The "legs" of the monster are just foam scraps that I used to protect the fuse from damage while I held them together with tape. I really would like to do a "glass" canopy but I need to read up on the process!
Pics below show size comparison next to the 34" Kfm4 version...
Old Oct 28, 2011, 10:50 PM
RedRanger's Avatar
Joined Mar 2011
Awwww, isn't that cute! The little one is flexing his wings
E.
Old Nov 01, 2011, 10:25 AM
pccdtk is offline
Chitila / Romania
Joined May 2008
Inspired by Scott Sbach I started my own . Some build pics ( with Scott permission - thank's ) :
Build Log SNICE Sbach 342 3D - 34" Full Fuse - PLANS FINALLY ADDED!!! SNice Foamies (Scratchbuilt) 65 Jul 10, 2014 08:51 PM
Discussion Sbach 342 Full fuse Free Plans bbjsw10 Foamies (Scratchbuilt) 142 Apr 07, 2012 02:48 PM
Discussion 51" Sbach 342 -- Full Fuse -- Airfoil -- 6mm Depron PinkYakRC Foamies (Scratchbuilt) 50 Aug 06, 2011 06:31 PM
Discussion Built-Up 40" Full Fuse Sbach 342 with Airfoil -- 6mm Depron PinkYakRC Foamies (Scratchbuilt) 8 Jun 21, 2011 12:33 PM
