Old Oct 26, 2011, 07:33 PM
sideburn is offline
Find More Posts by sideburn
sideburn's Avatar
USA, CA, Cardiff-by-the-Sea
Joined Nov 2005
Trying to figure out the correct amps to charge at AGAIN..
Hi guys,
I always have trouble with this. I just got a 180mah 7.4v 20C lipo and I want to figure out what the best amps to charge it at are. I am charging it at .2 amps right now to be safe but I bet I can go a lot higher than that.
I thought it was something like 180mah/1000 = .18 amps (that is 1c?)
but then if i multiply that by 20 (as in 20c) it comes out to 3.6 amps which seems way to high of a charge rate.
Can someone help explain this to me (again)..
Tavis
sideburn is offline Find More Posts by sideburn
Old Oct 26, 2011, 07:38 PM
UlteriorModem is offline
Find More Posts by UlteriorModem
UlteriorModem's Avatar
Joined Aug 2011
Wow thats an odd battery, you sure it's not 1,800mah ?
UlteriorModem is offline Find More Posts by UlteriorModem
Old Oct 26, 2011, 07:41 PM
lipoflyer is offline
Find More Posts by lipoflyer
lipoflyer's Avatar
Australia
Joined Nov 2010
.2 is fine you are correct . 20C is the discharge rate and you should not be charging at 20C.
almost every battery on the market today can be charged at 2C so if i were you i'd be charging at 2C. so .4 would be fine.
Take these for example, you could charge at 10C or 1.6amps. you would be able to buy 2 packs and almost be in the air none stop
http://www.hobbyking.com/hobbyking/s...zone_Etc_.html
lipoflyer is offline Find More Posts by lipoflyer
Old Oct 26, 2011, 07:43 PM
lipoflyer's Avatar
Australia
Joined Nov 2010
acutually they are quite common and used in UM planes and choppers
Old Oct 26, 2011, 09:39 PM
sideburn is offline
sideburn's Avatar
Joined Nov 2005
ya micro stuff..
Old Oct 26, 2011, 09:41 PM
sideburn is offline
sideburn's Avatar
Joined Nov 2005
i use those in my mcp-x
The battery I am dealing with now is the 2s 7.4v 180 for a micro highroller--> http://www.robotcombat.com/products/0-DYN1429.html
Help! I'm trying to figure out what I have to order parts etc , please take a look phranticness Foamies (Kits) 2 Oct 24, 2011 03:32 PM
Help! What AMPS to charge at? big_poppa4904 Batteries and Chargers 9 Sep 03, 2011 10:07 AM
Discussion How many amps should i charge my nimh at? thermal king16 Batteries and Chargers 3 Aug 11, 2011 07:54 PM
Help! Trying to figure out the 9C Butterfly mix Mark Wood Slope 25 Jul 12, 2011 05:06 PM
1200 mah LiPo should charge in 1 hour at 1.2 amps out. Right? Ron D Batteries and Chargers 3 Apr 08, 2004 02:02 PM
