Old Mar 18, 2012, 05:46 PM
Never trust laughing dolphins
Joined Feb 2011
Originally Posted by thwaitm View Post
I just tested and the RX802 binds no problem out of the box to the Devo7.
Just plug the BEC/ESC into THRO, a servo in to ELEV/AILE/RUDD whatever and power up the TX then RX - no problems.
I tried first with Devo 7 -- OK
then with Devo 8 -- OK
then again with Devo 7 -- OK (to check if binding a 6 digit random code then a 5 caused any issues - apparently not)
Which makes it even weirder that your rx801 doesn't bind in exactly the same way.
Devo 6,7,8,10 or 12 should not matter at all.
PHMX is offline Find More Posts by PHMX
Old Mar 23, 2012, 10:26 AM
Joined Feb 2012
and what is your Devo7 firmware version?
Datos is offline Find More Posts by Datos
Old Mar 23, 2012, 10:27 AM
Currently living to fly...
Japan, Tokyo
Joined Jun 2011
v0.1A
thwaitm is offline Find More Posts by thwaitm
Old Mar 23, 2012, 10:53 AM
Joined Feb 2012
v0.1A
thank you. the reason to ask is because I've ordered rx802 and already have Devo7 with 0.1A firmware. Awaiting Align TRex 450 Sport V2 to use with it. Have you used bind-plug in order to make it bind - or it is so simple as you have described here?
Old Mar 23, 2012, 05:48 PM
Japan, Tokyo
Joined Jun 2011
With the 802, I just plugged a motor+ESC with BEC and a servo into the RX, turned on TX, plugged battery to ESC and it bound without any trouble.
The bind plug is, in my experience, only required to reset the RX after using a Fixed ID.
Old May 05, 2012, 10:56 AM
Joined May 2012
Mine is working fine!
Hey guys,
Just binded my Devo 7 V0.1A with a RX-801 with two different ESCs.
One is a walkera ESC and binding took about 2 seconds. With a hobbyking ESC, it worked fine too.
Going to order some more.
Cheers.
mrenaud is offline Find More Posts by mrenaud
Old May 06, 2012, 07:27 AM
Japan, Tokyo
Joined Jun 2011
Originally Posted by mrenaud View Post
Hey guys,
Cheers.
You didn't bind it to a Devo 8, 10 or 12 beforehand I guess. I wonder if it's a 5 digit code vs 6 digit code difference... anyway good for you.
Old May 09, 2012, 12:09 PM
Joined May 2012
Thatīs correct. I got a new RX801 from the box and binded it directly with the Devo 7.
I am using RANDOM ID, and when I try with FIXED ID I will post the results.
Cheers.
Old May 10, 2012, 02:47 AM
Australia, WA, Perth
Joined Feb 2012
Devo 7 and RX2610S
Can anyone advise if its possible to bind the RX2610S receiver with the DEVO 7 transmitter?
many thanks
ozcopter is offline Find More Posts by ozcopter
Old May 10, 2012, 03:09 AM
wlee1017's Avatar
Joined Jul 2011
many thanks
No. rx2610s can't bind to Devo 7. only walkera rx /w suffix D like rx2622V-D can bind to devo tx.
wlee1017 is offline Find More Posts by wlee1017
Old May 10, 2012, 04:47 AM
Joined Feb 2012
Appreciate the quick reply.
Old May 11, 2012, 03:56 PM
Joined Feb 2011
That really doesn't make any sense though as it changes nothing to the receiver and obviously both are compatible. When clearing the fixed ID it really deletes any information, whether 5 or 6 digits. It's also the same firmware that controls all Devo type receivers, so there's no reason for the Devo 7 not to bind. Bear in mind that the Devo 7 binding with the RX802 also uses only 5 digits for fixed ID, so there's no difference there...
Old May 11, 2012, 06:46 PM
Japan, Tokyo
Joined Jun 2011
I agree. Maybe I have an older RX801 and they made a V1.1 firmware but I have no way to check.
Anyway, it seems that the D7 might well be compatible with all Rx-D now.
Old May 13, 2012, 09:41 AM
Japan, Tokyo
Joined Jun 2011
It's looking like it might well be my RX801. It doesn't appear to pair with another Devo TX either.
Old May 13, 2012, 10:44 AM
Joined Feb 2011
Hmm I don't understand, didn't you claim it binding to a Devo 8?
For Sale Fs: Mint- ko propo pds-2123 7.2-7.4v lipo compatible servo sir Cars - Accessories (FS/W) 5 Nov 09, 2011 04:11 PM
For Sale Walkera Devo 7 TX/Devo RX2625H Combo for sale Tom Z Aircraft - General - Radio Equipment (FS/W) 0 Oct 06, 2011 12:33 PM
For Sale Walkera Devo 7 TX/Devo RX2625H Combo for sale Tom Z Aircraft - Electric - Helis (FS/W) 0 Oct 05, 2011 11:38 AM
For Sale Spektrum DX5e with DSM2 compatible AR6110 like rx *PENDING* justplainold Aircraft - General - Radio Equipment (FS/W) 0 Oct 02, 2011 06:38 PM
Off Site Hitec 7-channel RX, Airtronics compatible, on ebay jim breese Aircraft - General - Radio Equipment (FS/W) 0 Jun 08, 2011 12:23 AM
