Old Jan 01, 2013, 08:27 PM
Mr. Wiz is offline
Find More Posts by Mr. Wiz
Time for me to Fly...
Mr. Wiz's Avatar
United States, MI, Fenton
Joined Jan 2000
One last thing I'm going to try before I completely give up on the idea of flying rudderless, I'm going to try mixing in a little aileron into my rudder stick. Maybe with that I can get over this mental block known as rudderless flying.
Mr. Wiz is offline Find More Posts by Mr. Wiz
Old Jan 01, 2013, 09:35 PM
dbone is offline
Find More Posts by dbone
Team ATX Pilot
dbone's Avatar
Phx. Az.
Joined Nov 2004
I mix 50 percent and it's works a treat. When flying low without a rudder open the circle and fly more flat another thing I do is work the flap stick to increase camber which will help you in the turn. But yes mix the the other stick.
dbone is offline Find More Posts by dbone
Old Jan 02, 2013, 02:34 PM
got2soar is offline
Find More Posts by got2soar
Bruce Davidson
got2soar's Avatar
United States, KY, Shelbyville
Joined Jun 2005
More likely than a double center servo is you have a bit of binding. Check and make sure there is enough clearance for the linkage where it exits the skin, common problem.
Bruce
got2soar is offline Find More Posts by got2soar
Old Jan 02, 2013, 02:37 PM
Mr. Wiz is offline
Mr. Wiz's Avatar
Joined Jan 2000
Bruce
That's what Mattias said in a PM. When I get a chance, I'll give it a look. He also gave me some advice on how to free it up with a small file run down the length of the push rod. We'll see what happens and I'll report back.
Old Jan 02, 2013, 03:08 PM
Mr. Wiz is offline
Mr. Wiz's Avatar
Joined Jan 2000
Ya know, now that I think about it.... When I was putting the aileron control horns on I was having trouble getting the push rods to line up with the control horn holes. I ended up cutting about 3mm off the bottom of the control horns. How far back into the wing do you guys cut into the top of the wing to accommodate the pushrods? Also, I remember thinking the thing was pretty twitchy on the ailerons... even as I dialed in about 40% expo. Maybe I should go back and make new horns and cut further back into the wing top.... Maybe even get some pushrod shrouds and put them on there.
Old Jan 02, 2013, 04:37 PM
like.2.fly is offline
Find More Posts by like.2.fly
Mike M.
like.2.fly's Avatar
United States, UT, Eden
Joined Jan 2010
I relieve the pushrod slots about 3/4" back from the trailing edge into the top wing skins. It allows the pushrods to exit the wing high enough to line up with the holes on the aileron control horns. I would not advise altering the height of the horns. They are made to a specific size for correct geometry (assuming correct servo horn length (4.5mm) as well). Shortening the aileron horns by 3mm will increase surface movement a fair amount (more sensitive), plus put higher load forces on the servo gears and cases.
like.2.fly is offline Find More Posts by like.2.fly
Old Jan 02, 2013, 07:07 PM
rcgeorge is online now
Find More Posts by rcgeorge
usaf3kteam
rcgeorge's Avatar
United States, AZ, Arizona City
Joined Sep 2005
+ flutter if you throw like a man.
rcgeorge is online now Find More Posts by rcgeorge
Old Jan 02, 2013, 09:00 PM
Mr. Wiz is offline
Mr. Wiz's Avatar
Joined Jan 2000
I've got my order in for some new ones from ak79. Ill cut the top back some more for better relief. That's probably the problem with the servo too.
Old Jan 06, 2013, 05:49 PM
wgeffon is offline
Find More Posts by wgeffon
wgeffon's Avatar
United States, IL, Bloomington
Joined Feb 2002
My Polaris showed up yesterday.
im just waiting on some stuff to show up in the mail to be able to finish it.
wgeffon is offline Find More Posts by wgeffon
Old Jan 06, 2013, 05:58 PM
M Seid is offline
Find More Posts by M Seid
M Seid
M Seid's Avatar
Solana Beach, Ca
Joined Sep 2006
I have started a revolution. The third pink polaris has been spotted..... Looks great!
M Seid is offline Find More Posts by M Seid
Old Jan 06, 2013, 09:10 PM
1900 Driver is offline
Find More Posts by 1900 Driver
1900 Driver's Avatar
United States, CA, Santa Barbara
Joined Mar 2009
The pink is rad! And when Mike steals it you'll know!
B
1900 Driver is offline Find More Posts by 1900 Driver
Old Jan 06, 2013, 10:46 PM
FLY F3B is offline
Find More Posts by FLY F3B
or F, J, K, or even TD
FLY F3B's Avatar
Joined Jun 2007
Awesome Wayne! Looks great.
FLY F3B is offline Find More Posts by FLY F3B
Old Jan 08, 2013, 12:55 AM
NorCal Hobbies is offline
Find More Posts by NorCal Hobbies
NorCal Hobbies's Avatar
Joined Feb 2007
What layup is that wing Wayne? Looks legit.
Does MMT do a samurai lay-up? Is this the Standard weight wing? Also whats the average wing weight for a Standard wing? Have a fuse and just ordered a standard layup and trying to figure out what the materials are and weight of the standard wing.Thanks in advance!
NorCal Hobbies is offline Find More Posts by NorCal Hobbies
Old Jan 08, 2013, 08:23 AM
wgeffon is offline
wgeffon's Avatar
Joined Feb 2002
My wing is the standard layup.
It's weighs 147g RTF
Old Jan 08, 2013, 09:23 AM
Joined Feb 2007
ok so 147 is wing,servos in wing and and throwing peg?
Discussion Rudderless launches isoarthenland Hand Launch 19 Sep 15, 2011 10:11 PM
Wanted Bagged, Rudderless DLG Tailset thumbhead Aircraft - Sailplanes (FS/W) 4 Aug 22, 2011 08:22 PM
Sold Twister-1 DLG (ARF + Ballast + Swindell Rudderless) Kai@UCSB Aircraft - Sailplanes (FS/W) 4 Jul 25, 2011 07:34 PM
FS Rudderless Art Hobby Bobolink DLG amike_321 Aircraft - Sailplanes (FS/W) 6 Feb 07, 2004 08:30 PM
