Old Dec 02, 2012, 08:20 PM
HHARRIS is offline
Find More Posts by HHARRIS
Where did my plane go???
HHARRIS's Avatar
United States, CA, Tustin
Joined Nov 2008
Originally Posted by Mr. Wiz View Post
Hugh,
I haven't installed anything yet. It's all just set in there. I don't want to start fastening things down until I know what's all going to go in there... as in how much lead and how much space does it take up.. That said, I intended to install the stuff like the guy did that built my first Polaris. That being, battery all the way forward, servo in about the middle of the hatch opening and then the RX tucked in under the aft part of the hatch. Now the old plane has a switch jack between the battery and the servo but I want to use my Shred battery and avoid the necessity of the switch jack. I suppose I could go to a 1 cell lipo and use the switch jack but what's the advantage? Not having to open the canopy to turn on and off the plane... That's not much of an advantage for an additional failure point and a more crowded pod.
I RARELY go into my hatch after planes are built. I'm not a Shred guy but my setup is 600ma 1S LiPo in the nose. Elevator servo pushed all the way up to the battery(holds the battery in place and is still removable). . 3/32" tungsten rods on top of the battery . Receiver on top of tungsten(on top of battery) in front of the servo. My switch jack(sorry) is on top of the forward part of the servo holding the receiver and wires in place. I chose to go with a switch jack because I think plugging in and unplugging wires that were not intended for this repeated process is not good in the long run(just my personal opinion). With this set up my heavy layup CG at 68mm (with a heavy full carbon vertical) comes in at 280gr , a click under 10oz.. The key is to push everything as far forward as possible.
HUGH
HHARRIS is offline Find More Posts by HHARRIS
Old Dec 02, 2012, 08:45 PM
pmackenzie is online now
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
You can't buy lead shot any more, can you? I might have a little left from my old skeet shooting days. I'll have to go digging.
Mcmaster Carr sells it.
pmackenzie is online now Find More Posts by pmackenzie
Old Dec 02, 2012, 11:34 PM
SteveJF is offline
Find More Posts by SteveJF
SteveJF's Avatar
Joined Nov 2004
Lead Shot and Rubber Cement
Mix the lead shot with rubber cement. It's more secure and compact than the plastic bag and you can easily remove a bit with a screwdriver, unlike epoxy.
SteveJF is offline Find More Posts by SteveJF
Old Dec 03, 2012, 08:20 AM
Mr. Wiz is offline
Find More Posts by Mr. Wiz
Time for me to Fly...
Mr. Wiz's Avatar
United States, MI, Fenton
Joined Jan 2000
Interesting. The only reason I have to go into the hatch is to access the jumper on the Shred. What 600mah 1 cell do you use and where to you get that tungsten?
HUGH
Mr. Wiz is offline Find More Posts by Mr. Wiz
Old Dec 03, 2012, 10:09 AM
Mr. Wiz is offline
Mr. Wiz's Avatar
Joined Jan 2000
Alright, Hugh... With the help of a friend I located some 3/32" tungsten welding rod.
http://weldingdirect.com/10pactc2cert.html
I still have a switch jack from my pre Shred days but what I don't have is a source for single cell 600 mah lipo that I think will fit. in the pod. I like the idea of taping the hatch closed and not having to get in there but once every so often to inspect things.
Old Dec 03, 2012, 10:30 AM
HHARRIS is offline
HHARRIS's Avatar
Joined Nov 2008
I use the Lectron pro 600mah batteries. Also you can use the Eflite 500mah battery. I fly comfortably for 1.5hrs with either of those. The tungsten is what I use. I make 4 small pieces to add up to the weight that I need. Then I tape them to the top of the battery as far forward as possible. The middle two pieces will hang off the battery a bit in the front.
HUGH
Old Dec 03, 2012, 11:30 AM
Mr. Wiz is offline
Mr. Wiz's Avatar
Joined Jan 2000
That sounds like a good solution.
Thanks Hugh!
Old Dec 03, 2012, 01:55 PM
HHARRIS is offline
HHARRIS's Avatar
Joined Nov 2008
Thanks Hugh!
No problem! Also if your winter drags out to long ship that thing to me and I'll break her in nice and easy for ya... That's right, I'm a giver
HUGH
Old Dec 03, 2012, 02:12 PM
Mr. Wiz is offline
Mr. Wiz's Avatar
Joined Jan 2000
Oh gee... Thanks for the generous offer but I think I'll have to decline.
Old Dec 03, 2012, 05:41 PM
austinhlg is online now
Find More Posts by austinhlg
United States, MD, Baltimore
Joined Feb 2007
For cheap tungsten check out derby car sites like this. http://www.derbychamp.com/Pinewood-D...ights-s/51.htm
I wrap the slugs in putty and press them into the nose cone. This usually puts the entire weight farther forward than I can get the battery.
austinhlg is online now Find More Posts by austinhlg
Old Dec 04, 2012, 03:28 AM
Joe W is offline
Find More Posts by Joe W
launch low, fly high
New Zealand, Hawke's Bay, Havelock North
Joined Dec 2004
I am using a nanotech 1200 mAh 1S (23g) battery in the nose. Works perfect with no added noseweight. More capacity than I can use without taking a break...
Joe W is offline Find More Posts by Joe W
Old Dec 04, 2012, 09:12 AM
Mr. Wiz is offline
Mr. Wiz's Avatar
Joined Jan 2000
Joe,
Are you using one of their round lipos? I'd much rather carry a bigger battery than a hunk of otherwise useless metal.
Old Dec 04, 2012, 10:11 AM
NorCal Hobbies is offline
Find More Posts by NorCal Hobbies
NorCal Hobbies's Avatar
Joined Feb 2007
that is indeed a round Lipo.
NorCal Hobbies is offline Find More Posts by NorCal Hobbies
Old Dec 04, 2012, 11:53 AM
Mr. Wiz is offline
Mr. Wiz's Avatar
Joined Jan 2000
Thanks...
It's also out of stock. I'm going to try to get a couple of the 900 mah ones.
Old Dec 05, 2012, 08:12 PM
scootertrash340 is offline
Find More Posts by scootertrash340
Mark Gauding
USA, MO, Wentzville
Joined Apr 2002
New Polaris Maiden!
I was able to finally maiden my Polaris today!
What a great flying airplane even without a rudder! I set mine up as per the Jonas setup sheet and she flies great. It is a medium layup with the molded in servos and am using a MKS 65 for the elevator with pushrod. With the Craig Robinson seagull peg it came out to 9.8oz balanced at 69mm. It felt like I could move the cg back a little more, will have to try that later. What it the farthest aft cg anybody is using for the Polaris?
Looks like I am going to have to order another one and sell my Stobel's!
The receiver and 2 cell lipo are in the nose with the PLD regulator just in between the servo. I am using Airtronics and was able to put one antenna behind the servo on the floor and the other one taped to the hatch. No range issues what so ever!
Mark Gauding
scootertrash340 is offline Find More Posts by scootertrash340
Discussion Rudderless launches isoarthenland Hand Launch 19 Sep 15, 2011 10:11 PM
Wanted Bagged, Rudderless DLG Tailset thumbhead Aircraft - Sailplanes (FS/W) 4 Aug 22, 2011 08:22 PM
Sold Twister-1 DLG (ARF + Ballast + Swindell Rudderless) Kai@UCSB Aircraft - Sailplanes (FS/W) 4 Jul 25, 2011 07:34 PM
FS Rudderless Art Hobby Bobolink DLG amike_321 Aircraft - Sailplanes (FS/W) 6 Feb 07, 2004 08:30 PM
