Oh, one more thing. I mentioned that I thought I had a left hand vertical. I don't. I mistook the dark color on the LE of the blade and around one end for the CF reinforcement layer. It's not. I held it up to the light and I saw the reinforcement in the proper location based on the shape.... Duh. And the Kevlar hinge is in the right place too. Everything is absolutely perfect!
Brandon |
I agree those big carbon patches on the tail seem like overkill. They could be be much smaller, and done with light glass instead. Or left off completely. I did one of mine with light glass, and the other with no reinforcement at all. Neither one has ever popped off. Still, 10.2 oz is a very good weight for a heavy layup Polaris with a rudder. It should be just fine as is.
I pulled the CF patches back off. They actually came off too easy. Makes me wonder if they would have done much good. But here is the kicker, guys. That moved the CG a whopping 1.5mm forward with all else being the same... 2 servos in the pod and .6 ounces of lead in the nose. Ill bet I didn't save much more than a gram of weight total. So while I can and likely will add the light glass back. This didn't really change a thing. I'm guessing that 10.2 oz is just about what this plane ought to weigh. I'm still undecided about the rudder installation. I think I'm going to forego that for now. I like simple and I already have it built rudderless.
What's your favorite method of adding nose weight that can later be removed? I'm thinking about sticking some fishing sinkers in up there and glueing in a hunk of foam rubber to hold them up there. |
HUGH
I haven't installed anything yet. It's all just set in there. I don't want to start fastening things down until I know what's all going to go in there... as in how much lead and how much space does it take up.. That said, I intended to install the stuff like the guy did that built my first Polaris. That being, battery all the way forward, servo in about the middle of the hatch opening and then the RX tucked in under the aft part of the hatch. Now the old plane has a switch jack between the battery and the servo but I want to use my Shred battery and avoid the necessity of the switch jack. I suppose I could go to a 1 cell lipo and use the switch jack but what's the advantage? Not having to open the canopy to turn on and off the plane... That's not much of an advantage for an additional failure point and a more crowded pod. |
But I tend to leave the little bag of shot in there permanently. |
Latest blog entry: er9x heli 450 heli set up (flybar)
| Thread Tools | |
| Discussion Rudderless launches | isoarthenland | Hand Launch | 19 | Sep 15, 2011 10:11 PM |
| Wanted Bagged, Rudderless DLG Tailset | thumbhead | Aircraft - Sailplanes (FS/W) | 4 | Aug 22, 2011 08:22 PM |
| Sold Twister-1 DLG (ARF + Ballast + Swindell Rudderless) | Kai@UCSB | Aircraft - Sailplanes (FS/W) | 4 | Jul 25, 2011 07:34 PM |
| FS Rudderless Art Hobby Bobolink DLG | amike_321 | Aircraft - Sailplanes (FS/W) | 6 | Feb 07, 2004 08:30 PM |
