Old Sep 24, 2012, 02:34 PM
like.2.fly is offline
Find More Posts by like.2.fly
Mike M.
like.2.fly's Avatar
United States, UT, Eden
Joined Jan 2010
Mine are nylon M3 flat heat countersunk phillips. Good to carry spares in your toolkit, as they love to jump into the grass and hide...
like.2.fly is offline Find More Posts by like.2.fly
Old Sep 24, 2012, 02:47 PM
Mr. Wiz is offline
Find More Posts by Mr. Wiz
Time for me to Fly...
Mr. Wiz's Avatar
United States, MI, Fenton
Joined Jan 2000
Thanks!
mike
Mr. Wiz is offline Find More Posts by Mr. Wiz
Old Sep 25, 2012, 01:19 AM
AlpineDSacro is offline
Find More Posts by AlpineDSacro
registered user
Russia, Tomsk Oblast, Kargasoksky District
Joined Sep 2008
Does anyone have a spare Polaris rudder they want to sell ?? I would like to put one on a bitsa Dlg I have...
AlpineDSacro is offline Find More Posts by AlpineDSacro
Old Sep 27, 2012, 05:09 AM
imack is online now
Find More Posts by imack
Ivan MacKenzie
imack's Avatar
Toronto, Ontario, Canada
Joined Nov 2002
Is everyone using the servo location posted by Donnie here for their top drive installs? And if so, is the 60mm measured from the center of the wing or the at the 75mm point?
Ivan MacKenzie.
imack is online now Find More Posts by imack
Old Sep 27, 2012, 12:34 PM
HHARRIS is offline
Find More Posts by HHARRIS
Where did my plane go???
HHARRIS's Avatar
United States, CA, Tustin
Joined Nov 2008
Yes per MMT instructions.
Either point as its about the same (+/- .5mm)
HUGH
HHARRIS is offline Find More Posts by HHARRIS
Old Sep 27, 2012, 05:50 PM
rwait is offline
Find More Posts by rwait
SE Michigan
Joined Dec 2007
What MMT instructions? I don't see any on their website and I sure never received any with their kit.
rwait is offline Find More Posts by rwait
Old Sep 27, 2012, 06:45 PM
Mike M.
like.2.fly's Avatar
Joined Jan 2010
This is what I have.
There is also a doc posted earlier in this thread with the recommended control surface throws HERE.
Old Sep 27, 2012, 07:07 PM
RCPC is offline
Find More Posts by RCPC
Throw it like you hate it
RCPC's Avatar
United States, CA, Castro Valley
Joined Apr 2007
you want to make sure that the servos are aft enough such that you dont cut the spar when cutting the servo pocket. the back of the spar ends just shy of 60mm back from the LE as measured from the centerline or 75mm outboard. Hugh is right. the difference is only a mm or so. place the servo aft of that dimension (60mm back from the LE).
in terms of how far out to install the servo, you can see some depressions in the wing skin running aft at around 75mm out from the centerline. this is a carbon sock that is inside the wing. it is a rectangular sock and has solid rohacel in the core. i dont know how MMT does this. see attached pictures.
when installing a top-drive setup, you bore through the wing. this channel in the foam weakens the wing slightly so MMT has decided to put a carbon sock in the wing in which you bore the pushrod channel. the carbon sock helps the wing retain much of its strength even with a channel. this sock is centered about 75mm out from the centerline. you want to install the servo such that is is outboard enough that the pushrod runs through this sock. the sock is a rectangular shape so the edges of the sock can be seen in the wing skin if you look at the wing from a certain angle and lighting. this is very hard to explain without pictures so i have attached some from my wing. you will see that my pushrod is centered down the two small depressions both on top and bottom. these two small depressions are the edges of the carbon sock. you should be able to hold it up to the light and see what i am talking about. hope this helps.
paul
RCPC is offline Find More Posts by RCPC
Old Sep 27, 2012, 08:41 PM
danfitz is online now
Find More Posts by danfitz
danfitz's Avatar
United States, CA, Vista
Hey, those are nice looking wing covers you've got there! Who makes them for you?
danfitz is online now Find More Posts by danfitz
Old Sep 27, 2012, 10:13 PM
RCPC is offline
RCPC's Avatar
Joined Apr 2007
why, you do, of course they are excellent wingbags!
paul
Old Sep 27, 2012, 11:46 PM
HHARRIS is offline
HHARRIS's Avatar
Joined Nov 2008
Plus 5 on the wing bags(I have 5 sets;-) )...
They are awesome !
Thanks Dan
HUGH
Oh I'll be needing another set soon :O
Old Sep 28, 2012, 09:18 AM
luv2flyez is offline
Find More Posts by luv2flyez
luv2flyez's Avatar
United States, CO, Denver
Joined Mar 2012
PM sent
luv2flyez is offline Find More Posts by luv2flyez
Old Sep 28, 2012, 04:29 PM
M Seid is offline
Find More Posts by M Seid
M Seid
M Seid's Avatar
Solana Beach, Ca
Joined Sep 2006
since the danfans are posting about the danbags... here is a shot of my box as it arrived in North Carolina for next weeks annual OLEGFEST!! ( lets see if he secretly trolls this thread with his secret polaris envy..) dan also made me some sweet tail bags for the trip, along with new wing bags. Everything arrived in tip top shape.
@ danfitz......Thanks Dan !!!
M Seid is offline Find More Posts by M Seid
Old Sep 28, 2012, 04:43 PM
olgol is online now
Find More Posts by olgol
Oleg Golovidov
olgol's Avatar
Raleigh, NC, USA
Joined Sep 2004
no envy here whatsoever
olgol is online now Find More Posts by olgol
Old Sep 28, 2012, 04:56 PM
M Seid is offline
M Seid
M Seid's Avatar
Solana Beach, Ca
Joined Sep 2006
Ahhahahaaha!! Polaris stalker!
Discussion Rudderless launches isoarthenland Hand Launch 19 Sep 15, 2011 10:11 PM
Wanted Bagged, Rudderless DLG Tailset thumbhead Aircraft - Sailplanes (FS/W) 4 Aug 22, 2011 08:22 PM
Sold Twister-1 DLG (ARF + Ballast + Swindell Rudderless) Kai@UCSB Aircraft - Sailplanes (FS/W) 4 Jul 25, 2011 07:34 PM
FS Rudderless Art Hobby Bobolink DLG amike_321 Aircraft - Sailplanes (FS/W) 6 Feb 07, 2004 08:30 PM
