Midair damage first aid:
1. Cleaned the wound thoroughly. 2. Disinfected with thin CA. 3. Bandaged with clear packing tape. 4. Injected PU Gorilla glue & water mix with a syringe through the tape. Glue expanded to fill the void to shape of wing. Cured overnight, then removed bandage. 5. Slathered surface with light weight spackling compound. When dry, leveled and sanded smooth with a block. 7. Surgically applied skin graft after removing paint around edges so it would bond carbon to carbon. Cloth saturated with West finishing resin. Covered with clear packing tape while wet, then clamped between foam blocks overnight while the resin set. Tape removed. All done, except for some touchup paint... maybe... Looks kinda cool as is, and reminds me of TS round 15 when the stakes were high, and she didn't let me down even when wounded .Mike
São Paulo, Brazil
Joined Dec 2009
You just never know! P.S. - Loving my Polaris! Can't wait for the new ones to arrive!
I used Gorilla Glue (see HERE), specifically the fast drying one that is white in color (HERE). But any "polyurethane" (PU) glue will do. It foams up and expands when coming in contact with a bit of water. |
São Paulo, Brazil
Joined Dec 2009
![]() Hope to meet you again next year!! |
When using the Gorilla glue a trick to make the finished product smooth as glass is the use the back side "The Non sticky" side of the 2" wide clear packing tape and form in place so as the glue expands it is held to shape by a jig, or whatever. When you pull the tape off the glue has a smooth as glass finish. Play with the glue a bit before using so you get used to how it reacts with different amounts of water. Its great stuff!
Latest blog entry: Swith in battery chemistry for all my...
| Thread Tools | |
| Discussion Rudderless launches | isoarthenland | Hand Launch | 19 | Sep 15, 2011 10:11 PM |
| Wanted Bagged, Rudderless DLG Tailset | thumbhead | Aircraft - Sailplanes (FS/W) | 4 | Aug 22, 2011 08:22 PM |
| Sold Twister-1 DLG (ARF + Ballast + Swindell Rudderless) | Kai@UCSB | Aircraft - Sailplanes (FS/W) | 4 | Jul 25, 2011 07:34 PM |
| FS Rudderless Art Hobby Bobolink DLG | amike_321 | Aircraft - Sailplanes (FS/W) | 6 | Feb 07, 2004 08:30 PM |
