Old Dec 12, 2011, 01:06 PM
FLY F3B is offline
Find More Posts by FLY F3B
or F, J, K, or even TD
FLY F3B's Avatar
Joined Jun 2007
Originally Posted by jensdk View Post
I'll look forward to that, Hopefully pilots that fly both can tell the big difference.
I believe RCPC here on the groups has experience with both gliders. Most recently the Polaris. Maybe Paul will chime in.
Jens, are you currently flying the TII? Have you compared to other gliders like SALpeter, Concept CX2?? Curious as to your opinion.
FLY F3B is offline Find More Posts by FLY F3B
Old Dec 12, 2011, 01:39 PM
dbone is offline
Find More Posts by dbone
Team ATX Pilot
dbone's Avatar
Phx. Az.
Joined Nov 2004
The Polaris is every bit as good as the Twister 2, T2 is a great glider moves and floats well I have been flying them for a year now. The Polaris I beleive is a better plane in dead air, and ranges well from what I can tell so far. I am still learning the Polaris but it seems to be the most stable DLG I have flown. I also had a Stobel V2 which is a great glider, I would fly any of the three and think I could win contests. What I like most about the Polaris over the others is that if I get in a midair I don't have to worry as much about needing top go to a backup, also easy of repair. You can't go wrong with this glider.
Donnie
dbone is offline Find More Posts by dbone
Old Dec 12, 2011, 02:12 PM
jensdk is offline
Find More Posts by jensdk
Jens Hoffmann
jensdk's Avatar
Denmark, Region Zealand, Herlufmagle
Joined Jul 2006
Yes, have been flying T2 for 1½ year now and I'm absolutely satisfied just got a new one today, compared to what I saw at the worlds, the difference between the topplanes aren't that big, it's more what one preferre pr. conditions.
jensdk is offline Find More Posts by jensdk
Old Dec 12, 2011, 02:13 PM
isoarthenland is offline
Find More Posts by isoarthenland
Russ Young
isoarthenland's Avatar
United States, UT, South Jordan
Joined Mar 2006
Originally Posted by bjue View Post
mike,
where did you put your hingeline for the rudder? Any pictures of gear install?
Brian
... +1
isoarthenland is offline Find More Posts by isoarthenland
Old Dec 12, 2011, 03:14 PM
FLY F3B is offline
FLY F3B's Avatar
Joined Jun 2007
I will take a picture for you.
I measured in 1" from the top and bottom trailing edge of the fin and drew a straight line. I cut through the top of the fin, down to within about 3/4" of the bottom. I sliced from one side only, and cut only through one skin and the foam to, but not through the other skin. I chose to make the hinge on the left side of the fin. Not sure if this is best or not, just what I chose. Even though I did not cut through the outer skin, the glass can't be relied upon as the only hinge material. So I added a layer of tape. My only concern is that there may be some tendancy for that outer skin to delaminate. I will watch this, and add some CA "nails" if necessary to secure the skin and prevent delamination.
By CA "Nails" I mean that I would poke small holes in the fin and rudder along the hingeline about 1/8" offset, and soak with CA so that the skin/foam bond has some depth to it so to speak.
Hope this helps for now.
Old Dec 12, 2011, 04:45 PM
oakman7004 is offline
Find More Posts by oakman7004
Team WC2013 F3K
oakman7004's Avatar
Sweden
Joined Dec 2004
Nice to hear about another succesful maiden!
Now! Throw the cr€&&?!ap out of it in 0 conditions an see if it is worthy the CA air! I'll bet 3min is there!
/jonas ekman
oakman7004 is offline Find More Posts by oakman7004
Old Dec 12, 2011, 05:09 PM
FLY F3B is offline
FLY F3B's Avatar
Joined Jun 2007
LOL Deal Jonas. There will be no more Cr@#$ap in it after my morning test flight ! This weekend for sure.
Cheers.
/jonas ekman
Old Dec 12, 2011, 05:27 PM
cptsnoopy is offline
Find More Posts by cptsnoopy
Where is the lift?
cptsnoopy's Avatar
USA, AZ, Phoenix
Joined Nov 2005
/jonas ekman
The early am air at Eldo is unreal. If you don't get 3min, something is amiss!
just remember that is only before the first round. Once the contest starts the magic air is usually gone...
Charlie
cptsnoopy is offline Find More Posts by cptsnoopy
Old Dec 12, 2011, 08:29 PM
FLY F3B is offline
FLY F3B's Avatar
Joined Jun 2007
So true Charlie.
Old Dec 12, 2011, 10:05 PM
FLY F3B is offline
FLY F3B's Avatar
Joined Jun 2007
2 pictures
Here is a shot of my 2 servo install, and the rudder hinge line.
Old Dec 12, 2011, 10:18 PM
dbone is offline
Team ATX Pilot
dbone's Avatar
Phx. Az.
Joined Nov 2004
Nice install Mike, see you at the JEM.
Donnie
Old Dec 12, 2011, 10:24 PM
FLY F3B is offline
FLY F3B's Avatar
Joined Jun 2007
Thanks Donnie. See you there.
M
Old Dec 12, 2011, 11:18 PM
bjue is offline
Find More Posts by bjue
NorCal
Joined Nov 2009
Thanks for posting the pictures Mike.
What are you guys using for ballast? What are the dimensions of the ballast compartment?
Brian
bjue is offline Find More Posts by bjue
Old Dec 13, 2011, 12:07 AM
NCDLG is offline
Find More Posts by NCDLG
NCDLG's Avatar
United States, NC, Raleigh
Joined Sep 2010
Thanks for the photos Mike, did you have much time on it without rudder, curious?
Looks nice.
NCDLG is offline Find More Posts by NCDLG
Old Dec 13, 2011, 05:41 AM
Goinav8n is online now
Find More Posts by Goinav8n
Jeff Carr
Ft. Mill SC / Charlotte NC
Joined Mar 2001
Nice sete up Mike. Is the reciever behind the servos?? Or under the battery
Jeff
Goinav8n is online now Find More Posts by Goinav8n
Discussion Rudderless launches isoarthenland Hand Launch 19 Sep 15, 2011 10:11 PM
Wanted Bagged, Rudderless DLG Tailset thumbhead Aircraft - Sailplanes (FS/W) 4 Aug 22, 2011 08:22 PM
Sold Twister-1 DLG (ARF + Ballast + Swindell Rudderless) Kai@UCSB Aircraft - Sailplanes (FS/W) 4 Jul 25, 2011 07:34 PM
FS Rudderless Art Hobby Bobolink DLG amike_321 Aircraft - Sailplanes (FS/W) 6 Feb 07, 2004 08:30 PM
