Old Nov 14, 2011, 05:10 PM
vulpina is offline
Find More Posts by vulpina
France
Joined May 2006
There is this nasty static thing that pull the cassete tape up before you bring the tape down , you just have to be quick
vulpina is offline Find More Posts by vulpina
Old Nov 14, 2011, 06:04 PM
rdjay is offline
Find More Posts by rdjay
Blind Hawk
rdjay's Avatar
Seattle, WA USA
Joined Dec 2006
What tape do you find works best? I've tried this with plain old "Scotch" tape and first moisture on it and it pulls away. Maybe Blenderm? Sorry for the off topic....
Thanks, RdJay
rdjay is offline Find More Posts by rdjay
Old Nov 14, 2011, 08:04 PM
NCDLG is offline
Find More Posts by NCDLG
NCDLG's Avatar
United States, NC, Raleigh
Joined Sep 2010
Thanks, RdJay
I use the clear scotch tape (the glossy stuff) 1/2" wide and cassette tape (Jonas likes ABBA I went for AC\DC), never an issue like that. To better help keep finger prints off it, and help it adhere even better try to take a long section and reverse it sticky side up, then tape it to a flat work surface to apply the cassette tape. You then can easily apply it to cover the gap, finger print free.
Roydor's method sounds good as well, between one of those your sure to have success.
Sorry for the details, just trying to help the Polaris Brotherhood...Rock On!
Now on with the 65gsm layup pictures....LOL
NCDLG is offline Find More Posts by NCDLG
Old Nov 14, 2011, 09:44 PM
Buddy Roos is offline
Find More Posts by Buddy Roos
It's a mere flesh wound!
Buddy Roos's Avatar
Woodstock,Ga.
Joined Jun 2004
Thanks, RdJay
The molds or mylars that were used to make your wing had a release agent on them. Wipe off the area where you are going to stick the tape with a little alcohol and try the tape again.
Buddy
Buddy Roos is offline Find More Posts by Buddy Roos
Old Nov 15, 2011, 11:48 AM
rdjay is offline
Blind Hawk
rdjay's Avatar
Seattle, WA USA
Joined Dec 2006
Thanks. Classic rock here (sorry ABBA does not qualify!), something kickin for sure, that's gotta help launch height.
I do wax my mylars, hadn't thought about that, great point.
RdJay
Old Nov 15, 2011, 12:20 PM
HHARRIS is offline
Find More Posts by HHARRIS
Where did my plane go???
HHARRIS's Avatar
United States, CA, Tustin
Joined Nov 2008
Done! It came in at 9.6oz with the CG at 67mm which is my starting point. I will post more about the build process later. I should be able to get out tomorrow for the maiden. Sorry for the crappy picture.
HUGH
HHARRIS is offline Find More Posts by HHARRIS
Old Nov 15, 2011, 08:43 PM
onio condor is offline
Find More Posts by onio condor
onio condor's Avatar
United States, OH, Cincinnati
Joined Jan 2006
Very Nice......
But I also see a Gary Wright E3D in the background....a wonderful plane.
onio condor is offline Find More Posts by onio condor
Old Nov 15, 2011, 08:48 PM
dbone is offline
Find More Posts by dbone
Team ATX Pilot
dbone's Avatar
Phx. Az.
Joined Nov 2004
HUGH
Ya thats pretty much BAD ASS!
dbone is offline Find More Posts by dbone
Old Nov 15, 2011, 09:16 PM
RCPC is offline
Find More Posts by RCPC
Throw it like you hate it
RCPC's Avatar
United States, CA, Castro Valley
Joined Apr 2007
i agree. just looking at a polaris makes me want to fly. i havent flown since the BSoAZ and am really itching to get out with the polaris again. i love that plane!
paul
RCPC is offline Find More Posts by RCPC
Old Nov 15, 2011, 09:26 PM
cptsnoopy is offline
Find More Posts by cptsnoopy
Where is the lift?
cptsnoopy's Avatar
USA, AZ, Phoenix
Joined Nov 2005
paul
Well,
Git-er-done DUDE!!!
Charlie
cptsnoopy is offline Find More Posts by cptsnoopy
Old Nov 16, 2011, 12:37 AM
HHARRIS is offline
HHARRIS's Avatar
Joined Nov 2008
Originally Posted by onio condor View Post
Very Nice......
Wait What??
HUGH
Old Nov 16, 2011, 01:04 AM
jcats is offline
Find More Posts by jcats
Launch high. Fly low.
United States, CA, Lake Elsinore
Joined Aug 2003
Put an altimeter on that plane. I'd like to know if you're launching it higher. It really seemed like I was launching it higher at AZ blue skies.
Jun
paul
jcats is offline Find More Posts by jcats
Old Nov 16, 2011, 10:53 AM
Oystmyr is offline
Find More Posts by Oystmyr
Sweden
Joined Sep 2005
This is how I do it.
1. Cut the hole for the servo
2. Measure wing centre to servo disc centre
3. Mark the same dimension on top skin (wing centre to pushrod centre)
4. Take a 1.5mm music wire or drill and make the channel from the pushrod exit hole to the servo disc.
5. Increase with bigger diameter music wire
6. Bend servo end of pushrod and push trough channel
7. Fit to servo disc
8. Mark position for aileron bend where wanted
9. Remove pushrod and make aileron bend
10. Glue wing servo
11. Fit pushrod and glue aileron horn
An improvement from Jonas installation is also to make some more bends on the push rod to get the forces inline with the servo disc and aileron control horn. Unfortunately I don't have any pictures available right now. The simple U-bent rod can flex between servo and aileron. Not worthy on a full carbon glider :-)
Regards
Mattias
Originally Posted by bjue View Post
I have a general technique question, but related to the Polaris since the Polaris is designed as top driveÖ How do you align and drill the hole (in the wing) for the top drive control rod. Iíve done this once before on another solid core foam wing, and totally missed, but my building skills admittedly suck .
And then, do you bend the control rod while it is in the wing? L-bends on both sides? Z-bend? If so how do you get good bends in the wire in the wing? Obviously you can bend one side outside the wing but what about the other side? You donít make the hole big enough to fit the wire with bent end through or do you? Or clevis on one side? Or...?
Brian
Oystmyr is offline Find More Posts by Oystmyr
Old Nov 16, 2011, 11:51 AM
bjue is offline
Find More Posts by bjue
NorCal
Joined Nov 2009
10. Glue wing servo
Regards
Mattias
Thanks Mattias, that helps a lot!
Brian
bjue is offline Find More Posts by bjue
Old Nov 16, 2011, 12:31 PM
jensdk is offline
Find More Posts by jensdk
Jens Hoffmann
jensdk's Avatar
Denmark, Region Zealand, Herlufmagle
Joined Jul 2006
Brian
Instead of an u-bent, I recommend the j-bent, as pr. Mr. Naton.
It seems to better lock in place at the servohorn.
jensdk is offline Find More Posts by jensdk
Discussion Rudderless launches isoarthenland Hand Launch 19 Sep 15, 2011 10:11 PM
Wanted Bagged, Rudderless DLG Tailset thumbhead Aircraft - Sailplanes (FS/W) 4 Aug 22, 2011 08:22 PM
Sold Twister-1 DLG (ARF + Ballast + Swindell Rudderless) Kai@UCSB Aircraft - Sailplanes (FS/W) 4 Jul 25, 2011 07:34 PM
FS Rudderless Art Hobby Bobolink DLG amike_321 Aircraft - Sailplanes (FS/W) 6 Feb 07, 2004 08:30 PM
