Old Nov 14, 2011, 09:15 AM
shawnc is offline
Find More Posts by shawnc
The ground's the limit.
shawnc's Avatar
Boulder, CO Area
Joined Aug 2008
Originally Posted by like.2.fly View Post
Wow, nice shop isobar!
I'd like to think there are great piles of balsa, foam, and wrecked glider parts just off camera, that were moved just for the photo. I'm sure I'd be wrong though.
Shawn
shawnc is offline Find More Posts by shawnc
Old Nov 14, 2011, 09:56 AM
dbone is offline
Find More Posts by dbone
Team ATX Pilot
dbone's Avatar
Phx. Az.
Joined Nov 2004
Originally Posted by Tommy Wee View Post
Just a small question to Polaris builders:
Is the tape covering the hinge line gap just taped to the non moving part of the wing?
According to Dbones photos of his Polaris wing he doesn't have tape at all? Or have I just missed it?
I am doing another dlg and started thinking about that tape. Is it needed at all or would it be enough that it covers the gap when the ailerons are at neutral position?
The Polaris looks great, I am tempted to order one. Sweden isn't that far off, when you live in Finland!
Tommy
I removed the tape on mine then replaced it. Hinge tape is a must on this place.
Donnie
dbone is offline Find More Posts by dbone
Old Nov 14, 2011, 11:47 AM
samc99us is online now
Find More Posts by samc99us
Aurora Builder
United States, MD, Lusby
Joined Nov 2003
Originally Posted by NCDLG View Post
I'm in, can we carpool to the alps...?
Nice Polaris, 273grams... of hotness.
If someone has a jet and money for fuel I have a place we can crash at slope side...
Otherwise there's always WV!
Any photos of the hinge gap sealing tape and installation? Is it just taped to the top of the wing forward of the hinge line? I recall it being more sophisticated than that, but didn't have a chance to snap some photos.
samc99us is online now Find More Posts by samc99us
Old Nov 14, 2011, 12:07 PM
like.2.fly is online now
Find More Posts by like.2.fly
Mike M.
like.2.fly's Avatar
United States, UT, Eden
Joined Jan 2010
You can't just run a piece of tape over the gap, or it will stick to the surfaces on both sides of the gap. So you make the back half of the tape not sticky by dusting it with talc powder, running a piece of cassette tape down the length, or my personal favorite of just putting two pieces of transparent tape together sticky side to sticky side overlapping each other 1/2 way. The sticky part then sticks to the wing in front of the aileron hinge line, and the non-sticky part overlaps the gap and a bit onto the aileron. On some hollow molded wings you can actually 'tuck' the non-sticky part of the seal down into the hinge line. It's tough to get pictures because the transparent tape doesn't show up well. But I've seen pics in other threads here that show it with the cassette tape method.
like.2.fly is online now Find More Posts by like.2.fly
dbone is offline
Team ATX Pilot
dbone's Avatar
Phx. Az.
Joined Nov 2004
The plane comes with hinge tape installed from MMT. But if you need more info I can help out when I get off work tonight.
Donnie
Old Nov 14, 2011, 12:29 PM
Tommy Wee is offline
Find More Posts by Tommy Wee
Tampere, Finland
Joined Oct 2009
Thanks for the info.
The reason I asked my question is that the plane I am building does have the tape installed. It is fixed to the aileron and goes inside the fixed part (like in an F3J/F3B plane) BUT makes awful noice doing it (it is crushed as the aileron goes up) AND it pops out a bit too early (when using aileron as a brake). It actually limits the brake movement because of that.
I think I will modify it, to be like the ones in Polaris. Thanks for help.
Sorry for hijacking the thread...
Tommy
Tommy Wee is offline Find More Posts by Tommy Wee
Old Nov 14, 2011, 12:53 PM
oakman7004 is offline
Find More Posts by oakman7004
Team WC2013 F3K
oakman7004's Avatar
Sweden
Joined Dec 2004
[QUOTE=like.2.fly;19872331]You can't just run a piece of tape over the gap, or it will stick to the surfaces on both sides of the gap. So you make the back half of the tape not sticky by dusting it with talc powder, running a piece of cassette tape down the length, or my personal favorite of just putting two pieces of transparent tape together sticky side to sticky side overlapping each other 1/2 way. The sticky part then sticks to the wing in front of the aileron hinge line, and the non-sticky part overlaps the gap and a bit onto the aileron. SNIP [QUOTE]
The Polaris have the cassette tape version. with the old Abba songs! Mine do have 'take a chance on me' and I did in the WC!
/Jonas Ekman
oakman7004 is offline Find More Posts by oakman7004
Old Nov 14, 2011, 01:27 PM
bjue is offline
Find More Posts by bjue
NorCal
Joined Nov 2009
I have a general technique question, but related to the Polaris since the Polaris is designed as top driveÖ How do you align and drill the hole (in the wing) for the top drive control rod. Iíve done this once before on another solid core foam wing, and totally missed, but my building skills admittedly suck .
And then, do you bend the control rod while it is in the wing? L-bends on both sides? Z-bend? If so how do you get good bends in the wire in the wing? Obviously you can bend one side outside the wing but what about the other side? You donít make the hole big enough to fit the wire with bent end through or do you? Or clevis on one side? Or...?
Brian
bjue is offline Find More Posts by bjue
Old Nov 14, 2011, 01:28 PM
Tampere, Finland
Joined Oct 2009
/Jonas Ekman
OK. Thanks. I may also use Abba, 'winner takes it all' might be good
Tommy
Old Nov 14, 2011, 01:30 PM
Tampere, Finland
Joined Oct 2009
Brian
Here is how the Swede (Oakman/Ekman) does the top drive, works well. Helped me, tack Jonas!:
http://www.rcgroups.com/forums/showthread.php?t=1353941
Tommy
Old Nov 14, 2011, 01:42 PM
bjue is offline
NorCal
Joined Nov 2009
Tommy
Thanks Tommy, but that is with a hollow molded wing which seems a bit easier to me, since you just need the exit hole, and you can adjust where you glue in your servo for a straight run. In a solid core wing, like the Polaris, you have a to drill a hole from the servo control horn to the exit in front of the Flapperon control horn. Or am I missing something in my thinking...?
Brian
Last edited by bjue; Nov 14, 2011 at 01:44 PM. Reason: Edit: plus in a hollow wing, it's easier to pre-bend the push rod
Old Nov 14, 2011, 02:54 PM
Thermaln2 is offline
Find More Posts by Thermaln2
Transplant Chey WY from Reno
Thermaln2's Avatar
Reno Nevada
Joined Oct 2007
/Jonas Ekman
You guys are always coming up with some modification that is SOOO clever!
Thermaln2 is offline Find More Posts by Thermaln2
Old Nov 14, 2011, 03:10 PM
bbbp is offline
Find More Posts by bbbp
a.k.a. Bob Parks
Glendale, AZ
Joined Jun 2008
The Paul Naton wasy was to use a bend at the servo, pre bent before installing, & a soldered on clevis at the flaperon horn. He even ground down the top & bottom of the clevis flanges to make it a bit more streamlined.
By using the solder method, adjustment is very easy & is re-adjustable later.
The pushrod should be striaght, but I do not think the hole needs to support the pushrod, so it may be a bit off or overiszed.
BP
bbbp is offline Find More Posts by bbbp
Old Nov 14, 2011, 04:11 PM
roydor is online now
Find More Posts by roydor
In F3J size does matter!
roydor's Avatar
Israel
Joined Nov 2006
I use cassette tapes as well (don't know the songs though)
I tape the cassette tape over the gap at both ends and place the tape over it and on to the fixed part of the wing. I then trim it and itís done. can be done in a few minutes. The hardest thing was to find an old cassette player
roydor is online now Find More Posts by roydor
Old Nov 14, 2011, 04:41 PM
J_Arner is offline
Find More Posts by J_Arner
Limbo with 30,000V...
J_Arner's Avatar
United States, UT, Roy
Joined Apr 2008
Thank you for sharing that method roydor.
J_Arner is offline Find More Posts by J_Arner
Discussion Rudderless launches isoarthenland Hand Launch 19 Sep 15, 2011 10:11 PM
Wanted Bagged, Rudderless DLG Tailset thumbhead Aircraft - Sailplanes (FS/W) 4 Aug 22, 2011 08:22 PM
Sold Twister-1 DLG (ARF + Ballast + Swindell Rudderless) Kai@UCSB Aircraft - Sailplanes (FS/W) 4 Jul 25, 2011 07:34 PM
FS Rudderless Art Hobby Bobolink DLG amike_321 Aircraft - Sailplanes (FS/W) 6 Feb 07, 2004 08:30 PM
