Old Jun 03, 2012, 12:00 PM
usa.alex is offline
Find More Posts by usa.alex
Alex USA
usa.alex's Avatar
Joined Oct 2011
Pnoy,
what motors, esc and props did you use ?
Thank you
usa.alex is offline Find More Posts by usa.alex
Old Jun 03, 2012, 07:11 PM
Steph280 is offline
Find More Posts by Steph280
1.21 Gigawatts!
Steph280's Avatar
Irvine, CA, USA
Joined Oct 2000
My scorpion is the fiberglass g10 version I got from eBay. I suspect both the plastic and g10 are concurrently being produced, just sold through different dealers with different price point.
Steph280 is offline Find More Posts by Steph280
Old Jun 03, 2012, 07:49 PM
kaz1104 is offline
Find More Posts by kaz1104
Dreamer
Australia, TAS, Memana
Joined Aug 2004
Some comments have suggested the cheapest HK version is fiberglass, but also suggested that it is very heavy? Mine came off ebay some time ago and was one of the nylon ones with the "soak off" paper sort of skin on the parts.
kaz1104 is offline Find More Posts by kaz1104
Old Jun 04, 2012, 03:28 AM
pnoy is offline
Find More Posts by pnoy
my wife supports my hobby
Joined Sep 2011
Originally Posted by usa.alex View Post
Pnoy,
Thank you
motor emax 2215/25 950kv
hobbyking 30A esc
8x4.5 prop
http://www.hobbyking.com/hobbyking/s...dproduct=15205
pnoy is offline Find More Posts by pnoy
Old Jun 05, 2012, 08:40 AM
usa.alex is offline
Alex USA
usa.alex's Avatar
Joined Oct 2011
hobbyking 30A esc
8x4.5 prop
Is it stable with this configuration ?
What battery do you use ?
I am keep on working with Quad X - 30A, similar motors - a bit smaller but 1200kV, props 8x4 battery 4S 3300 - when is heavier (using 4S instead of 3S) feels better and stable. I'm not using full throttle because I'm a rookie ...
It dried my battery after ... 4-5 minutes ...
Old Jun 05, 2012, 06:22 PM
kaz1104 is offline
Dreamer
Joined Aug 2004
I am using 6 of the Kda20-22L motors and 10x4.7 propellers on 3 cells. Good combination with plenty of reserve power. The idea is that the Y6 will still happily fly if one motor stops working for whatever reason, allowing a safe landing with my precious camera. I get pretty good flight time with a 3300, or 5000mAh battery.
Old Jun 06, 2012, 04:11 AM
maximal is offline
Find More Posts by maximal
AutoQuad OS developer
maximal's Avatar
near Ithaca, NY, US
Joined Aug 2004
http://www.ecalc.ch/xcoptercalc_e.htm
Invaluable tool. So far it has been very accurate for me (compared to real world results). Just plug in your data. If your motor is not already listed, you can probably look up the numbers here http://www.progressiverc.com/media/p...ess_Motor.html or do a Google/RCGroups search. I personally aim for hover @ around 50-60% throttle, although the calc will say you're OK all the way up to 80%.
Cheers,
-Max
maximal is offline Find More Posts by maximal
Old Jun 07, 2012, 05:18 AM
pnoy is offline
Joined Sep 2011
2nd test flight of my scorpion y650
enjoy!!!
scorpion y650 2nd test flight (5 min 16 sec)
scorpion with 450 canopy
Old Jun 10, 2012, 09:15 AM
usa.alex is offline
Alex USA
usa.alex's Avatar
Joined Oct 2011
enjoy!!!
http://youtu.be/T5ZWIM6tUdM
Nice, very nice !
Old Jun 16, 2012, 06:34 AM
douglas4 is offline
Find More Posts by douglas4
"If it ain't broke,fly again"
douglas4's Avatar
Canada, ON, Greater Sudbury
Joined Aug 2006
single rotors...?
I'm new to this multi-rotor thing but it has really peaked my interest. Way better than fixing and setting up r/c helicopters....and less expensive in a crash. I have a question...:
I want to use the electronics from this:
http://thequadman.com/DJI-450-Bind-F...-dji450BNF.htm
minus one esc and 1 motor.
Will it work with this scorpian frame without any weight issues....? BTW I want to use single propellers only not the double ones everybody else is using.
doug
douglas4 is offline Find More Posts by douglas4
Old Jun 16, 2012, 07:58 AM
kaz1104 is offline
Dreamer
Joined Aug 2004
doug
The quad you are showing the link to, has a KK board that should fly a Y6 or if you want to reduce the number of motors, a Y4. For some control over yaw, you will need to be able to tilt the rear motor (not easy on this frame), or use a pair of motors back there with counter rotating propellers. The KK will control yaw this way. Power should be adequate for the scorpion frame on 10x4.5 propellers and 3 cell battery.
I would not consider the scorpion frame easy to repair, or overly durable.
Mark
Old Jun 17, 2012, 02:39 PM
douglas4 is offline
douglas4's Avatar
Joined Aug 2006
hmmm
Thank you for the good info. The main reason why I wanted to use the scorpion frame was the looks of it. The other reason was I can't find anywhere online that sells some kind of "fuselages" for these things.I'd would so love to stick a 450 size heli fuselage on it but I'm thinking maybe making my own heli fuselage out of some kind of light foam..like the kind you use for insulating the outside of your house, would be a better idea. Any thoughts...?
Old Jul 26, 2012, 04:39 PM
franke is offline
Find More Posts by franke
on the edge
franke's Avatar
United States, IL, Peoria
Joined Jul 2012
I liked this air frame so much that I have two of them on the way. I am going to turn it into a hex, add a level or two, reconfigure the landing gear and throw about 280 LEDs on it. I'll be using the 8 channel LED outputs on the Rabbit FC connected to 8 relays to run the LEDs. It should be interesting.
franke is offline Find More Posts by franke
Old Aug 02, 2012, 03:05 PM
ChuckAdams is offline
Find More Posts by ChuckAdams
ChuckAdams's Avatar
Troy, MI
Hey Pnoy
Can you take a picture of how your landing feet attach to the legs and post? I like the double feet on the Y650 looks like they add to the stability of the aircraft.
Chuck
ChuckAdams is offline Find More Posts by ChuckAdams
Old Aug 07, 2012, 06:36 AM
CrocEnd is offline
Find More Posts by CrocEnd
CrocEnd's Avatar
Darwin
Joined Aug 2002
Yeh Pnoy
Close up pic's Please
Thanx
Croc
CrocEnd is offline Find More Posts by CrocEnd
For Sale Scorpion S-3008-32 (480 Size Motor) and Scorpion 35 amp ESC bpink43 Aircraft - Electric - Power Systems (FS/W) 4 Oct 31, 2011 01:53 PM
For Sale Scorpion S-3008-32 (480 Size Motor) and Scorpion 35 amp ESC bpink43 Aircraft - Electric - Power Systems (FS/W) 2 Oct 22, 2011 08:06 PM
Sold Himax 6320-250 , Scorpion SII 3026-710 , Scorpion S-3026-12 Dennis Everett Aircraft - Electric - Power Systems (FS/W) 4 Aug 31, 2011 08:51 AM
Sold Scorpion Commander 70A ESC with Scorpion External Switching BEC Gregg28 Aircraft - Electric - Power Systems (FS/W) 2 Mar 29, 2008 10:16 AM
For Sale 25A Scorpion ESC and 35A Scorpion ESC Joe_Curd Aircraft - Electric - Power Systems (FS/W) 3 Feb 03, 2008 11:36 AM
