Old Nov 22, 2011, 04:34 PM
Phalanx-0 is offline
Find More Posts by Phalanx-0
Hulk likes flying things
Phalanx-0's Avatar
United States, IN, Kokomo
Joined May 2008
What do you guys think about powering this with 3 2830 13 870kv
Phalanx-0 is offline Find More Posts by Phalanx-0
Old Nov 23, 2011, 12:26 AM
kaz1104 is online now
Find More Posts by kaz1104
Dreamer
Australia, TAS, Memana
Joined Aug 2004
3 x 2830 13 870kv??? this frame doesn't have the means to control yaw with a Y3 setup. maybe a Y4?
kaz1104 is online now Find More Posts by kaz1104
Old Nov 23, 2011, 03:04 AM
rifki_bewe is offline
Find More Posts by rifki_bewe
Joined Feb 2011
Originally Posted by kaz1104 View Post
Hi kd4wen,
Yes, the frame will happily clear 12" propellers, probably anything up to about 16".
The skids are part of the frame, but they could be cut off. The skids do actually look pretty good though. A fair amount of spring and seems pretty tough.
Mark
12x4.5 is fit. but better to move the "tail" of scorpion.
the tail too soft
rifki_bewe is offline Find More Posts by rifki_bewe
Old Dec 06, 2011, 11:47 AM
spydmobile is offline
Find More Posts by spydmobile
Flying Canada's Arctic
spydmobile's Avatar
Canada, NT, Fort Smith
Joined May 2010
My Build has begun:
http://lab.westernwillow.com/model/fleet/503
Franco
spydmobile is offline Find More Posts by spydmobile
Old Dec 06, 2011, 03:15 PM
Dreamer
Joined Aug 2004
Nice build log spydmobile ...... neat feature is that the battery tray is reversible .... forward if the camera gimble is not used, or back if the camera setup is fitted, balancing the Y6 nicely.
Mark
Old Dec 06, 2011, 04:37 PM
spydmobile's Avatar
Joined May 2010
Mark
Thanks mark, did you grab that FunJet Gimbal? I did not notice it listed here....
F
Old Dec 07, 2011, 12:56 AM
Dreamer
Joined Aug 2004
F
Yes I did. looks good, fits together really well. Servos supplied are pretty ordinary. Will try them out and see how they go. There is some play in the gimbal around neutral, but maybe a rubber band to "pre-tension" will fix that. time will tell.
Old Dec 07, 2011, 09:38 AM
georgebinns is offline
Find More Posts by georgebinns
Multirotors blow
georgebinns's Avatar
Peterborough, England
Joined Dec 2006
Great feature Franco! Well done. I will be following your every move!
georgebinns is offline Find More Posts by georgebinns
Old Dec 07, 2011, 09:42 AM
Multirotors blow
Joined Dec 2006
Protective paper - best way to remove it?
I've just received my kit and I'm trying to remove the paper without scratching the material. I've tried soking in water and then removing it with a non scratch scourer and although it works its hard not to mark the surface. Anyone got a better idea?
George
Old Dec 07, 2011, 10:26 AM
spydmobile's Avatar
Joined May 2010
Nice, are you twisting a GoPro with it? How about a picture onboard?
I am posting pics from last nights build session, its not flying yet but maybe one more session and she can fly. when the pics are up I will repost my link, had to drill my own holes for TMF Pro FC since the frame is predisposed to KK style 45 degree off mounting
Thanks!
Franco
Old Dec 07, 2011, 10:29 AM
spydmobile's Avatar
Joined May 2010
George
I was using a nail brush, the little white kind you use to get dirt out from your fingernails, I was also using .60 Nylon guitar pick (Jim dunlop type) that worked well but if you are not carefull is marks it. You could alwyas use a pressure washer
Franco
Old Dec 07, 2011, 10:30 AM
spydmobile's Avatar
Joined May 2010
Thanks George, new pics will be up in about 20 mins, and I will post again when they are...
Franco
Old Dec 07, 2011, 11:32 AM
spydmobile's Avatar
Joined May 2010
Ok, wow, I must have been tired last night LOL
RD24: The Build Continues
Franco
Old Dec 07, 2011, 03:15 PM
Dreamer
Joined Aug 2004
George
Use hot water out of the tap, and some dish washing detergent in the water. leave the pieces for 15 mins or so and the paper just falls off. A finger nail will deal with whats left.
Old Dec 07, 2011, 03:18 PM
Dreamer
Joined Aug 2004
Thanks!
Franco
I have the choice of either a canon still camera or a contour hd video camera. The frame has direct mounts for the openpilot board, so simply bolt on nylon spacers and go.
For Sale Scorpion S-3008-32 (480 Size Motor) and Scorpion 35 amp ESC bpink43 Aircraft - Electric - Power Systems (FS/W) 4 Oct 31, 2011 01:53 PM
For Sale Scorpion S-3008-32 (480 Size Motor) and Scorpion 35 amp ESC bpink43 Aircraft - Electric - Power Systems (FS/W) 2 Oct 22, 2011 08:06 PM
Sold Himax 6320-250 , Scorpion SII 3026-710 , Scorpion S-3026-12 Dennis Everett Aircraft - Electric - Power Systems (FS/W) 4 Aug 31, 2011 08:51 AM
Sold Scorpion Commander 70A ESC with Scorpion External Switching BEC Gregg28 Aircraft - Electric - Power Systems (FS/W) 2 Mar 29, 2008 10:16 AM
For Sale 25A Scorpion ESC and 35A Scorpion ESC Joe_Curd Aircraft - Electric - Power Systems (FS/W) 3 Feb 03, 2008 11:36 AM
