Old Nov 14, 2011, 05:00 AM
glenncol is offline
Find More Posts by glenncol
Joined Dec 2010
Originally Posted by kaz1104 View Post
The comments left under the 3530/14 suggest that the motor only produces 1100g thrust with an 8x4 on 4 cells, ie doesn't have the "balls" to swing a big prop. Sometimes the numbers aren't always useful especially in relation to static vs effective thrust. At 73 grams it is in a realistic weight range.
Yes I will use 6 motors. The heli could be set up as a y4 but then weight distribution, redundency, lifting power, are not as good.
Mark
Yeah i would stick with the 6 as well, what is the weight of the copter with everything less motors?
glenncol is offline Find More Posts by glenncol
Old Nov 14, 2011, 05:21 AM
glenncol is offline
Joined Dec 2010
Mark
Here is another one the Turnigy Park 480 1020v, here is some great info on it as well http://www.bhabbott.net.nz/Tpark480.html
Old Nov 14, 2011, 05:33 AM
kaz1104 is online now
Find More Posts by kaz1104
Dreamer
Australia, TAS, Memana
Joined Aug 2004
Looks good
kaz1104 is online now Find More Posts by kaz1104
Old Nov 14, 2011, 01:39 PM
spydmobile is offline
Find More Posts by spydmobile
Flying Canada's Arctic
spydmobile's Avatar
Canada, NT, Fort Smith
Joined May 2010
Ok I bit, and ordered one too, looks like it could be a fun project
Franco
spydmobile is offline Find More Posts by spydmobile
Old Nov 15, 2011, 01:08 AM
Dreamer
Joined Aug 2004
Okay, here is a couple of ideas.
Y6 ... one motor fails ... the remaining motor needs to have enough power to fly the heli, and carry the dead motor too.
For efficiency, ideally the lower motor spins at higher revs / runs a higher pitch and ideally a smaller diameter propeller so as to be out of the tip vortex of the upper propeller. This things could be done in a multitude of ways.....
Old Nov 18, 2011, 09:56 PM
chipp is offline
Find More Posts by chipp
Joined May 2011
What model Areodrive motors where they on the Vid?
chipp is offline Find More Posts by chipp
Old Nov 18, 2011, 11:05 PM
Dreamer
Joined Aug 2004
The motors in the clip are these ... http://www.hobbyking.com/hobbyking/s...ner_Motor.html
Old Nov 18, 2011, 11:13 PM
chipp is offline
Joined May 2011
Cool ta
You any closer to showing more pics or flying? I think you have 69,341.5 people waiting to see this
Old Nov 18, 2011, 11:17 PM
Dreamer
Joined Aug 2004
Have decided on the KDA 20-22L motors, but have not made much progress. Prepared all the motors, and will run the speedies (Turnigy plush 18a ... or actually turnigy sentry 18a as that was all they had in stock when I ordered last), on each side of the arms near the center. I was initially planning on running the wires down the arm tubes, but then it gets in the way of the folding mechanism, and finding space for 6 speedies on the lower deck is a bit awkward, so its like one or the other... tidy or functional. Work has been pretty "full on"
Old Nov 18, 2011, 11:26 PM
chipp is offline
Joined May 2011
Cool i hear ya
If you get a chance can you take some close ups of the frame\body, i am thinking if there is a way f adding another level inbetween the battery and the floor above that to add the ESC's on their own level or something like that. I personally hate the idea of having the ESC's attached to the arms
Old Nov 18, 2011, 11:42 PM
Dreamer
Joined Aug 2004
The locking mechanism for the 2 front arms is a bolt that slides out of the way of the arm, letting the arm fold. The bolt just clears the end of the arm when "released". With a fair bunch of wires coming out of arm, there would not be enough room to clear. I'm sure this can be overcome, just have to think it out, otherwise resign to not folding the arms. If the arms were fixed, and not folding, this problem would not be a problem.
Old Nov 20, 2011, 10:52 AM
Frank.T is offline
Find More Posts by Frank.T
Frank.T's Avatar
Netherlands, ZH, Rotterdam
Joined Jul 2010
My setup with Mikrokopter FC, GPS and I2C to PWM converter:
GoPro shot:
In HD Scorpion frame with MK and I2C converter GPS Position hold and flight (6 min 26 sec)
Samsung phone shot:
Scorpion & Mikrokopter FC I2C to PWM (2 min 25 sec)
//Frank
Frank.T is offline Find More Posts by Frank.T
Old Nov 20, 2011, 03:11 PM
Dreamer
Joined Aug 2004
GoPro shot:
http://www.youtube.com/watch?v=cRT9ISxOfek
Samsung phone shot:
http://www.youtube.com/watch?v=GDVtkkb5Uk8
//Frank
Excellent job Frank, Nice build, and some very nice flying !!
Maybe you could share some more details about your build, motors, propellers, etc??
Mark
Old Nov 21, 2011, 12:39 AM
Frank.T is offline
Frank.T's Avatar
Joined Jul 2010
Sorry I forgot to post the details.
I used the Motors and ESC from a Feiyu-tech FY-Y6 that I stripped because the frame is to small for me.
3S Lipo 3200mAmp
Motor: 980kv
ESC: 10 Amp
( I know, low in amp but came with the kit and had never a problem with it but when I had to buy them I select a 20-30amp)
I use a APC 10 x 4.7 . Measured 10amp full power on the bench.
Standard kit build and change some stands to fit the Mikrokopter FC and NAV with the GPS on top.
To use standard ESC's I use a AbuseMark I2C to PWM converter which performed very well in the past.
Because of the small ESC and dito BEC I use a Turnigy external BEC to power the beast.
Next I will put some LED's on, two for the Eyes and on red on the tail picker.
I bought also their Cam mount so I will put that one under it (which build quiet nice!) and post a video from and of it.
//Frank
Old Nov 21, 2011, 12:51 AM
chipp is offline
Joined May 2011
Hey guys
Will a Helicopter canopy fit over the front of these if so what size do you think?
For Sale Scorpion S-3008-32 (480 Size Motor) and Scorpion 35 amp ESC bpink43 Aircraft - Electric - Power Systems (FS/W) 4 Oct 31, 2011 01:53 PM
For Sale Scorpion S-3008-32 (480 Size Motor) and Scorpion 35 amp ESC bpink43 Aircraft - Electric - Power Systems (FS/W) 2 Oct 22, 2011 08:06 PM
Sold Himax 6320-250 , Scorpion SII 3026-710 , Scorpion S-3026-12 Dennis Everett Aircraft - Electric - Power Systems (FS/W) 4 Aug 31, 2011 08:51 AM
Sold Scorpion Commander 70A ESC with Scorpion External Switching BEC Gregg28 Aircraft - Electric - Power Systems (FS/W) 2 Mar 29, 2008 10:16 AM
For Sale 25A Scorpion ESC and 35A Scorpion ESC Joe_Curd Aircraft - Electric - Power Systems (FS/W) 3 Feb 03, 2008 11:36 AM
