Old Nov 11, 2011, 12:59 AM
kaz1104 is offline
Find More Posts by kaz1104
Dreamer
Australia, TAS, Memana
Joined Aug 2004
Originally Posted by chipp View Post
AHHHH brain wave i finally get what you are talking about now, I was always under the assumption that the motor mount could bolt to either end of the motor
hahahaha ... tends to twist the wires up a little if you anchor the motor by the bell end
kaz1104 is offline Find More Posts by kaz1104
Old Nov 11, 2011, 08:24 AM
BennettOZ84 is offline
Find More Posts by BennettOZ84
Swinger. Heli and planks!
BennettOZ84's Avatar
United States, OR, Foster
Joined Mar 2007
Originally Posted by kaz1104 View Post
Have looked at those Turnigy motors and noticed that people seem to be using them. What propeller do you use?. Are they okay on a 10x4.7 or happier on a 9x4.7?
The Turnigy motors work best it seems on the 9x4.7 with great results, I have ran the 10x4.7 as well and it works fine too, gets a little hot, but not to bad.
BennettOZ84 is offline Find More Posts by BennettOZ84
Old Nov 12, 2011, 09:53 AM
kd4wen is offline
Find More Posts by kd4wen
Just a yard bird
kd4wen's Avatar
United States, TN, Springfield
Joined Mar 2007
Could you get a 12in prop on this frame? I got some new 740Kv motors looking for a Y6 and this looks very promising for the task. Also can the landing skids be replaced or are they part of the frame structure reason being a buddy ordered the new Gorilla Gear Landing Skids for his 500 heili and they are tough as nails and they bouce so they act like a shock absorber.
kd4wen is offline Find More Posts by kd4wen
Old Nov 12, 2011, 04:29 PM
kaz1104 is offline
Dreamer
Joined Aug 2004
Hi kd4wen,
Yes, the frame will happily clear 12" propellers, probably anything up to about 16".
The skids are part of the frame, but they could be cut off. The skids do actually look pretty good though. A fair amount of spring and seems pretty tough.
Mark
Old Nov 13, 2011, 01:47 AM
rifki_bewe is offline
Find More Posts by rifki_bewe
Joined Feb 2011
Carbon?? My understanding was that it was a nylon material and aluminium??
Mark
sorry, i mean 2mm black nylon and 15mm aluminium square tube
thanks
rifki_bewe is offline Find More Posts by rifki_bewe
Old Nov 14, 2011, 01:27 AM
glenncol is offline
Find More Posts by glenncol
Joined Dec 2010
Hi kd4wen,
Mark
Hey Mark
Have you got any further with your Y6? anymore pics?
glenncol is offline Find More Posts by glenncol
Old Nov 14, 2011, 01:53 AM
kaz1104 is offline
Dreamer
Joined Aug 2004
The Y6 is the next thing on the table. Weighing up which flight control board to use.... too many choices. Motors are a question too. Was almost settled on the KDA 20-22L but the CC quad I just finished has rctimer 2830/14 750kv motors swinging 10x4.7 (or 4.5?) Have to say I'm pretty impressed with them. I just shortened the motor shafts so that the propeller collets sit right down onto the motor. Figure there is less risk of bending motor shafts that way. I spend part of the weekend finishing, flying and tuning an openpilot copter control FPV project. Should have some updates on the y6 soon. Its early summer and its not too uncomfortable out in the shed of an evening so I can make a bit of progress if work hasn't been too frantic.
Mark
Old Nov 14, 2011, 01:59 AM
glenncol is offline
Joined Dec 2010
Mark
Hi Mark
There is also this series of motors to choose from
http://www.hobbyking.com/hobbyking/s...URNIGY_XP.html
Old Nov 14, 2011, 02:03 AM
kaz1104 is offline
Dreamer
Joined Aug 2004
Originally Posted by glenncol View Post
Hi Mark
Nooooo ... not more choices.
Old Nov 14, 2011, 02:05 AM
kaz1104 is offline
Dreamer
Joined Aug 2004
I already have some rctimer 2830/14's and some 20-22L's, so I can make progress without waiting on parts (also have all the other bits I need to get the Y6 in the air).
Old Nov 14, 2011, 02:14 AM
glenncol is offline
Joined Dec 2010
LOL sorry mate
What do you think of them?
Old Nov 14, 2011, 02:22 AM
kaz1104 is offline
Dreamer
Joined Aug 2004
The 2836 low kv ones look pretty good, and the way the shart is, makes them good for a y6. I was actually pretty surprised ... i normally look to a motor around 900 - 1100 kv. The 750 kv motor seemed to have plenty of lifting power and hovers a fairly heavy quad at around 1/2 throttle. Maybe the higher kv motors are not actually able to spin the 10x4.7 props at any greater rpm than the 750 kv ones ... interesting. Also curious are the next step 35mm motors. I guess their weight kinda rules them out for smaller quads. Some of the short but 35mm diameter ones are getting close though.
Old Nov 14, 2011, 03:54 AM
glenncol is offline
Joined Dec 2010
I think the 3530/14 looks like a good deal @73g and 1100g of thrust
I understand that working out the lifting power goes pretty much like this, Quad copter with 4 motors add the max thrust together of all motors , so in the case of the above motor
4400g of thrust, so if the copter including the camera gear comes in at around 2200g in theory the copter will hover at around half throttle?
If that is the case with a quad and I assume a X config hex and octo, but with a Y config hex where thy seem to run in a coaxial type set up are you still adding all 6 motors together?
Old Nov 14, 2011, 04:22 AM
kaz1104 is offline
Dreamer
Joined Aug 2004
The comments left under the 3530/14 suggest that the motor only produces 1100g thrust with an 8x4 on 4 cells, ie doesn't have the "balls" to swing a big prop. Sometimes the numbers aren't always useful especially in relation to static vs effective thrust. At 73 grams it is in a realistic weight range.
Yes I will use 6 motors. The heli could be set up as a y4 but then weight distribution, redundency, lifting power, are not as good.
Mark
Old Nov 14, 2011, 04:45 AM
kaz1104 is offline
Dreamer
Joined Aug 2004
I figure it probably makes more sense to talk in the number of amps at a given voltage, or watts ie the amount of energy, required to lift a given weight. There would be a multitude of ways to reach this target, within the range of voltage, propeller size, motor kv, flight time, number of motors etc, etc, that you desire, being aware that each affects the other.
Its like ... More battery = longer flight time ...BUT bigger battery = more weight = shorter flight time. And so around in circles.
For Sale Scorpion S-3008-32 (480 Size Motor) and Scorpion 35 amp ESC bpink43 Aircraft - Electric - Power Systems (FS/W) 4 Oct 31, 2011 01:53 PM
For Sale Scorpion S-3008-32 (480 Size Motor) and Scorpion 35 amp ESC bpink43 Aircraft - Electric - Power Systems (FS/W) 2 Oct 22, 2011 08:06 PM
Sold Himax 6320-250 , Scorpion SII 3026-710 , Scorpion S-3026-12 Dennis Everett Aircraft - Electric - Power Systems (FS/W) 4 Aug 31, 2011 08:51 AM
Sold Scorpion Commander 70A ESC with Scorpion External Switching BEC Gregg28 Aircraft - Electric - Power Systems (FS/W) 2 Mar 29, 2008 10:16 AM
For Sale 25A Scorpion ESC and 35A Scorpion ESC Joe_Curd Aircraft - Electric - Power Systems (FS/W) 3 Feb 03, 2008 11:36 AM
