Old Nov 10, 2011, 01:59 PM
kaz1104 is offline
Find More Posts by kaz1104
Dreamer
Australia, TAS, Memana
Joined Aug 2004
These guys have it too ... http://www.goodluckbuy.com/scorpion-...lticopter.html
kaz1104 is offline Find More Posts by kaz1104
Old Nov 10, 2011, 02:00 PM
BennettOZ84 is offline
Find More Posts by BennettOZ84
Swinger. Heli and planks!
BennettOZ84's Avatar
United States, OR, Foster
Joined Mar 2007
I was thinking about using these motors, I have used them in the past and seem to do a good job.
Turnigy 2209 26turn 1130kv 15A Outrunner
BennettOZ84 is offline Find More Posts by BennettOZ84
Old Nov 10, 2011, 02:05 PM
kaz1104 is offline
Dreamer
Joined Aug 2004
Have looked at those Turnigy motors and noticed that people seem to be using them. What propeller do you use?. Are they okay on a 10x4.7 or happier on a 9x4.7?
Old Nov 10, 2011, 05:11 PM
SGsoar is offline
Find More Posts by SGsoar
United States, CA, LA
Joined Aug 2007
Nice videos.. looking forward to seeing more.
Those turnigy motors do look nice. How difficult it is to reverse the shaft? Does it risk damaging the motor?
SGsoar is offline Find More Posts by SGsoar
Old Nov 10, 2011, 08:58 PM
chipp is offline
Find More Posts by chipp
Joined May 2011
Guys
What about the Turnigy 2217/20 one of the reviews said it was better than the AXI 2212/26 or 2217/16
chipp is offline Find More Posts by chipp
Old Nov 10, 2011, 09:27 PM
chipp is offline
Joined May 2011
Originally Posted by kaz1104 View Post
The motors that I have are the Turnigy SK3-2830-1020kv. i thought they should work pretty well on 3 cell on 10x4.7 (or 10x4.5) propellers. i would have to reverse all the shafts in these (or cut them off).
Mark
When you sayt reverse shafts , hoiw do you do this and does ot have ot be done of any motor if not how do youknow which ones have too?
I thougth you just reverse the wires and run the motors in reverse if needed?
Old Nov 10, 2011, 10:25 PM
kaz1104 is offline
Dreamer
Joined Aug 2004
The shaft in the these turnigy motors comes out of the end where the motor bolts down / wires come out of. If is left this way and the motors are bolted back to back, as on a y6, you would need to have them spaced apart so that the shaft ends don't meet. As the shafts are about 12mm or 1/2" long, the motors would end up 1" or 25mm apart ... no good. Looking at the hobbyking site, http://www.hobbyking.com/hobbyking/s...ies_Shaft.html , the replacement shaft does NOT have a second groove at the end of the shaft for the little clip or a second flat on the shaft for a grub screw. For this reason i think I will run with the KDA20-22L See this link and you can see the second groove for the clip when the shaft is turned around http://www.hobbyking.com/hobbyking/s...it_20___L.html. The other option is simply to cut the shaft off and use the bolt-on propeller mount.
I thougth you just reverse the wires and run the motors in reverse if needed? ..... correct, that will reverse the direction of spin, but doesnt fix the shaft sticking out of the wrong end of the motor.
Old Nov 10, 2011, 10:27 PM
kaz1104 is offline
Dreamer
Joined Aug 2004
Originally Posted by chipp View Post
Guys
The 2217/20 looks pretty good but at 71 grams it's no lightweight. Starts to add up when you are looking at 6 of them?
Old Nov 10, 2011, 10:44 PM
chipp is offline
Joined May 2011
Ahh, sorry i still dont get it, i am hopeless if i cant see it if you know what o mean
I assume i am going ot run into the same issue if i doa Y6
Old Nov 10, 2011, 10:54 PM
kaz1104 is offline
Dreamer
Joined Aug 2004
Okay ... the end of the motor that the wires come out of is fixed to the heli .. correct? If the shaft comes out that end too it's going to bang together with the shaft of the motor above or below it ... yeah? Shaft at that end of the motor needs to go away ... either end for end the shaft, push it through to the other side of the motor, or just cut it off. Can do another video if that doesnt make sense?
Old Nov 10, 2011, 11:20 PM
chipp is offline
Joined May 2011
Ahh no i gottcha thanks, so the Turnigy 2213 and 2217 models will not have this issue
Old Nov 10, 2011, 11:37 PM
kaz1104 is offline
Dreamer
Joined Aug 2004
The 2217 and 2213 will both have this issue. The picture on the hobbyking site shows the "base" of the motor where the wires come out of, and this is the same end the shaft extends from too. Shaft will have to be reversed or cut off, then the bolt on propeller mount used on the other end of the motor (looks like it is supplied with one). Cannot see spare shafts for these motors listed and I cannot see a groove in the end of the shaft to enable the shaft to be reversed ... so maybe not a good option. maybe check these out http://www.rctimer.com/index.php?gOo...st.dwt&gcat=40 most have the shafts at the opposite end to the mounting position already.
Like these ..... http://www.rctimer.com/index.php?gOo...4&productname=
Old Nov 11, 2011, 12:09 AM
chipp is offline
Joined May 2011
Can you suggest any from HK as i have a fair amount of credit with them?
Old Nov 11, 2011, 12:31 AM
kaz1104 is offline
Dreamer
Joined Aug 2004
Yes, These http://www.hobbyking.com/hobbyking/s...er_20_22L.html but you will still have to reverse the shaft. Pretty simple job with these. Be quick ... they sell like hotcakes.
You will also only be able to use the propeller holder type that grips onto the motor shaft rather than the bolt on type (both are supplied) I usually rough up the motor shaft with a course file or similar to lessen the chance of them coming off in flight.
Old Nov 11, 2011, 12:55 AM
chipp is offline
Joined May 2011
cool ta
For Sale Scorpion S-3008-32 (480 Size Motor) and Scorpion 35 amp ESC bpink43 Aircraft - Electric - Power Systems (FS/W) 4 Oct 31, 2011 01:53 PM
For Sale Scorpion S-3008-32 (480 Size Motor) and Scorpion 35 amp ESC bpink43 Aircraft - Electric - Power Systems (FS/W) 2 Oct 22, 2011 08:06 PM
Sold Himax 6320-250 , Scorpion SII 3026-710 , Scorpion S-3026-12 Dennis Everett Aircraft - Electric - Power Systems (FS/W) 4 Aug 31, 2011 08:51 AM
Sold Scorpion Commander 70A ESC with Scorpion External Switching BEC Gregg28 Aircraft - Electric - Power Systems (FS/W) 2 Mar 29, 2008 10:16 AM
For Sale 25A Scorpion ESC and 35A Scorpion ESC Joe_Curd Aircraft - Electric - Power Systems (FS/W) 3 Feb 03, 2008 11:36 AM
