Old Oct 15, 2012, 05:35 PM
kaz1104 is offline
Find More Posts by kaz1104
Dreamer
Australia, TAS, Memana
Joined Aug 2004
Originally Posted by Knut Erik View Post
Okay, that is a KK type board. Go to the page http://www.hobbyking.com/hobbyking/s...dProduct=21977 and click on the "files" tab .... just below where it says "add to cart". There is a bunch of information there. I'm not familiar with this board but it appears that you need a USBasp programmer (also available from hobbyking). There are a couple of programs in the files tab also, KKmulticopter flash tool etc and instructions.
Multirotors are a learning curve, to build, and fly. Read, read, and read some more ... ask questions. Search on this forum under hobbyking v3.0 control board, or in the KK threads and it will all become clear. (as a note ... I am not 100% sure that this board will actually fly a Y6 ... maybe someone can clarify that ??)
Mark
kaz1104 is offline Find More Posts by kaz1104
Old Oct 15, 2012, 05:45 PM
kaz1104 is offline
Dreamer
Joined Aug 2004
Okay ... just answered my own question ... there a bunch of firmware versions for Y6 using this board through the KKmulticopter flashtool v0.63 ....
Old Oct 15, 2012, 06:54 PM
Tunderslimer is offline
Find More Posts by Tunderslimer
Canada, BC, Surrey
Joined Sep 2012
This is the USB tool you will need (or something very similar.)
http://rctimer.com/index.php?gOo=goo...6&productname=
As for programming it and software:
http://lazyzero.de/en/modellbau/kkmulticopterflashtool
And for setup:
http://www.kkmulticopter.kr/index.html?modea=manual
Read everything on these pages, and you should be pretty close.
Or buy one of these: Perfect for noobs (like me - I have two and one like you)
http://www.hobbyking.com/hobbyking/s...rol_Board.html
They work out of the box and are field programmable, no computer required.
Tunderslimer is offline Find More Posts by Tunderslimer
Old Oct 15, 2012, 07:15 PM
twwd is online now
Find More Posts by twwd
twwd's Avatar
Mesa, Arizona
Joined Sep 2009
Chuck,
The orange color will add some orientation help and sort of dress it up a little! It certainly will not hold a candle to what you did to yours! You did some fine work!
To answer your question on the prop balance! I have not got to the part of my construction yet, so I really can't say how well balanced they are right out of the box. But yes, I did purchase my props, motors, and ESC's from RCDude.
Just to pitch RCDude a little, I have used him on several of my projects. He is a wealth of information and he goes out of his way to answer any questions you might have. He has good quality products and he stands behind them.
Rob
twwd is online now Find More Posts by twwd
Old Oct 19, 2012, 07:29 PM
ChuckAdams is offline
Find More Posts by ChuckAdams
ChuckAdams's Avatar
Troy, MI
Originally Posted by twwd View Post
That would be great! If it's not imposing on you! I have seen a couple of youtubes that show some of the setting, but none of them really say this is the way they set up there system.
Hi Rob,
I have attached a pdf document with the setup for the KK2.0 Board.
Chuck
ChuckAdams is offline Find More Posts by ChuckAdams
Old Oct 19, 2012, 10:37 PM
Canada, BC, Surrey
Joined Sep 2012
I'm still getting mine dialed in... 5 props and 4 bent shafts later, I'm still working on it. Once I get a reasonable KK2.0 board setting I'll let you know!
Old Oct 20, 2012, 01:22 AM
kaz1104 is offline
Dreamer
Joined Aug 2004
I'm guessing most of the bent shafts and propellers are on the lower motors ... that's the down side of Y6's .
Old Oct 20, 2012, 11:16 AM
twwd is online now
twwd's Avatar
Mesa, Arizona
Joined Sep 2009
Chuck,
Thank you very much for the PDF! I did PM you, but I am sort of new at the blog stuff so I am still learning! Thank you again for all your help!
I have just about got the paint work done on the frame, then I can start the build on my Y650. I also have a Quad build as well that I am into about half way. My thought is it would make for a better learning process before I tackle the Scorpion. I am using the same KK2.0 board on it as well.
Thanks again!
Rob
Old Oct 21, 2012, 02:23 AM
Baca is offline
Find More Posts by Baca
Baca's Avatar
Melbourne , Australia
Joined Jun 2006
Like to share video of my Scorpion's flight.
KK2 1.2 board,RCTimer 20A flashed ESC, SunnySky 2212-13 kV980 motors.
Flight of the Scorpion (4 min 8 sec)
Baca is offline Find More Posts by Baca
Old Oct 21, 2012, 07:18 PM
twwd is online now
twwd's Avatar
Mesa, Arizona
Joined Sep 2009
Baca,
That was a great video! Really like the close up shots! There sure are some great looking Scorpions on this blog. I am moving along with mine as well as the Quad I am building.
Here is another photo of the finished parts that I have painted. Paint work complete, so now I can start the build!
Description:
Old Oct 21, 2012, 08:03 PM
kaz1104 is offline
Dreamer
Joined Aug 2004
Man ... that's bright .... orientation will not be a problem with that bright orange paintwork ...
Old Oct 21, 2012, 08:48 PM
twwd is online now
twwd's Avatar
Mesa, Arizona
Joined Sep 2009
Hi Mark,
I going to need all the help I can get to keep the Scorpion on tract! Now that the paint work is completed I will start the build process. I am also making headway on my Quad! As you know this will be the machine I do my learning on before I attempt to fly the Scorpion.
Rob
Old Oct 22, 2012, 09:54 AM
ChuckAdams's Avatar
Troy, MI
Nice Flying Baca. The KK Board is a nice flying board in the Scorpion. Your's looks real stable.
Old Oct 26, 2012, 06:06 PM
Canada, BC, Surrey
Joined Sep 2012
Hehehehe... you're right. I did still manage to bend one top shaft - but, the shafts are quite long, so I'm blaming that.
Chewin through props like crazy, but loving it.
Old Oct 26, 2012, 06:44 PM
kaz1104 is offline
Dreamer
Joined Aug 2004
Most motors have shafts that are too long. Here is what I do .... drill a hole in a piece of cardboard and push it onto the motor shaft (after removing the prop adapter, of course). This acts to stop any debris going into the motor. Next, use an angle grinder and cut off wheel and lop off the excess shaft, so that the prop adapter sits down onto the motor bell. Tidy up the burrs, and rough up the motor shaft with some coarse sandpaper. This helps avoid bent motor shafts, reduces vibration, and gives the collet prop adapters a good grip on the motor shafts. Angle grinder sounds brutal but it only takes a second and any heat generated is minimal. Just avoid any debris getting into the motor.
For Sale Scorpion S-3008-32 (480 Size Motor) and Scorpion 35 amp ESC bpink43 Aircraft - Electric - Power Systems (FS/W) 4 Oct 31, 2011 01:53 PM
For Sale Scorpion S-3008-32 (480 Size Motor) and Scorpion 35 amp ESC bpink43 Aircraft - Electric - Power Systems (FS/W) 2 Oct 22, 2011 08:06 PM
Sold Himax 6320-250 , Scorpion SII 3026-710 , Scorpion S-3026-12 Dennis Everett Aircraft - Electric - Power Systems (FS/W) 4 Aug 31, 2011 08:51 AM
Sold Scorpion Commander 70A ESC with Scorpion External Switching BEC Gregg28 Aircraft - Electric - Power Systems (FS/W) 2 Mar 29, 2008 10:16 AM
For Sale 25A Scorpion ESC and 35A Scorpion ESC Joe_Curd Aircraft - Electric - Power Systems (FS/W) 3 Feb 03, 2008 11:36 AM
