Espritmodel.com Heli Air
Old Aug 09, 2012, 08:17 AM
United States, New York, Queens
Joined Dec 2009
My Y650 Setup
This is my Y650 Scorpion build from HobbyKing. I missed a few pictures because I was anxious to complete it. Parts list below. Enjoy!
HobbyKing Y650 Scorpion Kit
HobbyKing Quad Power Distribution Board
HK Single 4mm Male to 4x3.5mm Female Adapter
305mm Gold Bullet Connectors
DJI-NAZA and GPS
6 RcTimer 2212/15 930kv Motors
6 RcTimer 30Amp ESC's
Extra Cable to Extend ESC's
3Cell 5000Mah 25c LIPO
GAUI 10" Props
Any suggestions for prop size? I’m only getting 5 min flight time. I hear that if the upper props are larger that it will increase efficiency.
Maybe a few more things but who's counting. Hopefully not my wife lol.
Y650 SCORPION HOBBYKING BUILD (3 min 44 sec)
louisxp1 is offline Find More Posts by louisxp1
Old Aug 10, 2012, 01:13 AM
my wife supports my hobby
Joined Sep 2011
Originally Posted by ChuckAdams View Post
Can you take a picture of how your landing feet attach to the legs and post? I like the double feet on the Y650 looks like they add to the stability of the aircraft.
Chuck
here's the picture
pnoy is offline Find More Posts by pnoy
Old Aug 11, 2012, 01:41 AM
Darwin
Joined Aug 2002
Is this kit from HK come with nuts and bolts plus spacers if not
NO GOOD to me because I did not get any.
Another for the caboard bin xxxxed OFF
CrocEnd is offline Find More Posts by CrocEnd
Old Aug 11, 2012, 03:03 AM
Darwin
Joined Aug 2002
Thanx pnoy
That's the kit I got BUT no screws and spacers
Old Aug 11, 2012, 11:03 AM
on the edge
franke's Avatar
United States, IL, Peoria
Joined Jul 2012
Has anyone found the empty frame weight to be considerably higher than the 410 grams that is advertised?
I am working on combing two of these airframes into a Hex. I am not using all parts from both kits but the empty weight is already at 985 grams weighing all of the frame parts I will be using. This thing is going to be a flying brick.
franke is offline Find More Posts by franke
Old Aug 15, 2012, 03:57 AM
Darwin
Joined Aug 2002
Scorpion where are you gone
Old Aug 17, 2012, 09:46 AM
Cello62's Avatar
Italy, Emilia-Romagna, Novellara
Joined Aug 2012
Motor direction
Hi all.
Sry for newbie.
I've got the scorpion frame and now i'd like to know which motors to install because i don't understand well which is the problem to put the bottom motors.
I can't simply to reverse the motors and fix it like those above?
Perhaps the shaft must rotate in the same way, is it so?
Hobbyking reccommanded Turnigy SK3, but reading the post i have (or can) in the bottom motors to cut the shaft off and use the bolt-on propeller mount, right? Can you learn me why please?
Thanks again
Cello62 is offline Find More Posts by Cello62
Old Aug 17, 2012, 05:42 PM
Tasmania, Australia
Joined Aug 2004
Originally Posted by Cello62 View Post
Hi all.
Sry for newbie.
Thanks again
Hi Cello62,
With the y6 the motors mount back to back, so there is not enough space if the motors have a shaft coming out of the "fixed" (or mounting end) of the motor. You need to use a motor with a bolt on, or a shaft coming out of the bell end of the motor.
Collets or bolt on propeller mount are fine.
To reverse motor direction just swap any 2 of the 3 motor wires.
The bottom motors should spin the correct direction when viewed from above the Y6 and the propellers should be mounted with the writing on them facing the sky (upwards).
Hope this helps.
Mark
kaz1104 is offline Find More Posts by kaz1104
Old Aug 17, 2012, 09:54 PM
twwd's Avatar
Mesa, Arizona
Joined Sep 2009
Need some advice,
I am going to order up the y650 Scorpion frame from Hobby King and I would like to use the Turnigy D2836/8 1100KV motor with the 30 Amp Blue series ESC, and the 10X6 props. Also I was thinking about the HK Atmega 328 PA Control Board with the USB AVR Programming device, and the HK distribution board. I hope with the Turnigy motors I do not have to be reversing shafts!!
I realize this is a lot to go over, but any advice would sure be helpful. I see a lot of different set ups being used on this frame. I am looking for something easy to fly and not to complicated. One last stipulation! I want to purchase all Hobby King parts so I eliminate a lot of running around and additional freight!
Thank you all for any input you could give me! It is appreciated!
Rob
twwd
twwd is offline Find More Posts by twwd
Old Aug 17, 2012, 10:33 PM
Tasmania, Australia
Joined Aug 2004
Originally Posted by twwd View Post
Need some advice,
Rob
twwd
The combination that you describe sounds good. The Hobbyking KK2 flight control board is getting some good comments and is pretty easy to set up.
Shafts would not need to be reversed on the D2836/8 motors that you mentioned. Just use the collets, and if need be, cut the motor shafts a little shorter so that the collets sit down onto the motor bell. Rough up the shaft with some coarse sand paper will give the collets a little better grip.
Old Aug 18, 2012, 12:43 AM
twwd's Avatar
Mesa, Arizona
Joined Sep 2009
Mark (hope I have your name right)
Thank you for getting back to me! This really seems t be a great build blog for the y650 Scorpion, with some very good people that are willing to share there knowledge and expertise on this frame! I know I will be back with a lot more questions as I progress on my Scorpion!
Thank you again for taking the time to give me your input!
twwd
Rob
Old Aug 18, 2012, 01:05 AM
Tasmania, Australia
Joined Aug 2004
No worries Rob,
The only comment with the motors that you mentioned is that they are on the upper end of the size for this Y6. But ... it does mean it will continue to fly happily after loosing 1 motor (would actually fly with 2 out if they were the right 2), as there is plenty of reserve power.
Mark
Old Aug 18, 2012, 02:50 PM
twwd's Avatar
Mesa, Arizona
Joined Sep 2009
Mark or,
How does this look for the motors and ESC,s set up for the Scorpion!
RCTimer BC 2212/12-930KV motors
RCTimer 30A ESC
I have never used any RCTimer products, what do you guys think!?
twwd
Rob
Old Aug 18, 2012, 03:57 PM
Cello62's Avatar
Joined Aug 2012
Originally Posted by kaz1104 View Post
Hi Cello62,
Hope this helps.
Mark
Ty for reply
So if i understand well
this is the problem right?
And this one would be fine right?
Sunnysky X2212-980KV
RCTimer 2830-14 750KV
Ty again
Old Aug 18, 2012, 05:22 PM
twwd's Avatar
Mesa, Arizona
Joined Sep 2009
Ty,
That is what Mark was talking about! No shaft protrusion.
Rob
For Sale Scorpion S-3008-32 (480 Size Motor) and Scorpion 35 amp ESC bpink43 Aircraft - Electric - Power Systems (FS/W) 4 Oct 31, 2011 01:53 PM
For Sale Scorpion S-3008-32 (480 Size Motor) and Scorpion 35 amp ESC bpink43 Aircraft - Electric - Power Systems (FS/W) 2 Oct 22, 2011 08:06 PM
Sold Himax 6320-250 , Scorpion SII 3026-710 , Scorpion S-3026-12 Dennis Everett Aircraft - Electric - Power Systems (FS/W) 4 Aug 31, 2011 08:51 AM
Sold Scorpion Commander 70A ESC with Scorpion External Switching BEC Gregg28 Aircraft - Electric - Power Systems (FS/W) 2 Mar 29, 2008 10:16 AM
For Sale 25A Scorpion ESC and 35A Scorpion ESC Joe_Curd Aircraft - Electric - Power Systems (FS/W) 3 Feb 03, 2008 11:36 AM
