Old Oct 26, 2011, 01:06 AM
QiW is offline
QiW
Find More Posts by QiW
QiW
south east asia
Joined Mar 2009
can i "brick" my KK board ?
i was flying fine with my quad ... running KR 2.3 X-copter firmware
decided that i wanna try out the KK 4.7X
flashed my KK 5.5d using a USBASP device and LZ's flash tool
no error message ... read and confirmed fine by flashtool
so proceeded to calibrate throttle/ESCs ... that went without any hiccups
now ... the problems comes
tried to arm the FC ... nothing happened
tried moving trims for yaw and throttle ... nothing happened
tried moving throttle ... motors spins up equally without the FC arming
re-flashed the FC ...
same thing happens
re-flashed the FC with a different firmware (tried FW for quads and tricopter)
same thing happens
is my KK 5.5d FC bricked ??
QiW is offline Find More Posts by QiW
Old Oct 26, 2011, 01:23 AM
LazyZero is offline
Find More Posts by LazyZero
Master of Flash
LazyZero's Avatar
Alsdorf/Eifel, Germany
Joined Jun 2005
No I think you have the YAW pot still on zero position.
Chrsitian
LazyZero is offline Find More Posts by LazyZero
Old Oct 26, 2011, 01:52 AM
QiW is offline
QiW
QiW
south east asia
Joined Mar 2009
Chrsitian
i turned pot full CW as per KK 4.7 instructions for calibrating ESCs
throttle stick up .. power on
beep beep of ESCs .. then throttle down .. ESCs confirm beep
moved the yaw pot to around 50% after calibrating the ESCs with the FC
the result is the same ... board does not arm ... motor spins up evenly and normally when i throttle ...
or is my yaw pot broken maybe ?
how do i check for this ? there is no physical damage on board and this FC has never crashed before
when yaw pot is at ZERO ... the FC cannot arm ?
Old Oct 26, 2011, 02:07 AM
timecop is offline
Find More Posts by timecop
Joined Dec 2010
Yea sounds like its in esc calibration mode.
Measure resistance around yaw pot.
timecop is offline Find More Posts by timecop
Reply With Quote  (Disabled)
Old Oct 26, 2011, 02:45 AM
LazyZero is offline
Master of Flash
LazyZero's Avatar
Joined Jun 2005
And take a look at the solder joints of that pot.
Old Oct 26, 2011, 04:32 AM
QiW is offline
QiW
QiW
south east asia
Joined Mar 2009
thanks for your replies
will have a look at the board later for those issues ...
Old Oct 26, 2011, 06:15 AM
QiW is offline
QiW
QiW
south east asia
Joined Mar 2009
ok .. had a looked at the YAW pot
solder had a cold joint .. tapping it a little got the solder loose
re-soldered it back on .. and IT'S ALIVE !!!!!
THANKS GUYS !!!
ps .. still have that issue of motor #4 running at slower speed than the others though
Discussion Can a KK Controller Board Ruin My ESCs? rtbchris Multirotor Talk 8 Aug 25, 2011 01:11 AM
Help! Did I just brick my KK board? tomeparker Multirotor Talk 5 Aug 19, 2011 08:23 AM
For Sale KK KR1.7 ,ESC Board and KK Frame terriwang Aircraft - Electric - Multirotor (FS/W) 3 Jul 26, 2011 04:22 PM
Discussion KK firefly next on the virtual board vintage1 Control Line 5 Jun 22, 2010 07:18 AM
Discussion can my minumun brick habdle the 2 SS/MF motors? trust416 Micro Ready-to-Fly 7 May 03, 2008 03:32 PM
