Old Oct 25, 2011, 08:33 PM
Voguna is offline
Find More Posts by Voguna
Norway, Oslo
Joined Jun 2010
How do you feel that your plane is tailheavy?
Is there any way to "feel" that the plane is tailheavy? My CG is right, but it kinda feels like its a little tail heavy..:P
Voguna is offline Find More Posts by Voguna
Old Oct 25, 2011, 08:40 PM
Bear_Pants is offline
Find More Posts by Bear_Pants
United States, NJ, Manchester
Joined May 2011
If you put your 2 fingers under the COG of the wings you can tell by that. If you are flying and you let of go of the sticks the plane will try and tilt back to climb. Nose heavy > tail heavy
Balancing it perfectly at CoG is what you want.
Bear_Pants is offline Find More Posts by Bear_Pants
Reply With Quote  (Disabled)
Old Oct 25, 2011, 08:54 PM
galaxiex is offline
Find More Posts by galaxiex
my karma ranover my dogma
galaxiex's Avatar
Edmonton,Canada Eh
Joined Jun 2007
Tail heavy usually flys somewhat to VERY sensitive in pitch axis.
I once put too light a battery in my EZ Star (making it VERY tail heavy) and had about 30 seconds of excitement!
Very difficult to keep the plane level. The tiniest twitch on the elevator had a HUGE effect.
galaxiex is offline Find More Posts by galaxiex
Old Oct 26, 2011, 02:06 AM
Toysrme is offline
Find More Posts by Toysrme
Toysrme's Avatar
Birmingham, Alabama
Joined Jun 2002
1) experience
2) calculate the CG/MAC
3) age old adage, "nose heavy planes fly fast and poorly (like a brick), tail heavy planes don't fly long"
nose heavy planes:
stall nose down
(in LOS flying) are typically trimmed to fly level at 1/2-WOT, and decend with the AOA decreasing at lower throttle settings
tail heavy planes:
become very sensitive in pitch
can become snap happy at low speeds
when elevator throw is too much at any flying speed, can show a preference to stall one wing & cause a snap
severely tail heavy planes will simply try to backflip as speed decreases
obviously every plane is different, but many standard layout (wing in front, stab in back) mostly straight wing planes balance somewhere around the max thickness of the wing.
Toysrme is offline Find More Posts by Toysrme
Old Oct 26, 2011, 06:15 AM
camship is offline
Find More Posts by camship
Resistance is Futile
camship's Avatar
United States, FL, Panama City Beach
Joined Oct 2001
How to test for correct COG in flight.
!. Get as close to calculated COG as possible.
2 Fly it and trim elevator for level flight at cruise speed. (NOTE: ALL stabilization/gyros OFF)
3. Climb to sufficient altitude for an approx 2-3 second 45 degree dive.
4. Perform 45 degree dive and watch for plane to steepen the dive or begin to pull out without any stick input.
Results;
Increasing dive as speed rises = Tail-heavy
Steady 45 degree dive no change with speed = Ideal
Pulling out by itself = Nose heavy.
Hope this helps,
Rob
camship is offline Find More Posts by camship
Old Oct 26, 2011, 07:09 AM
banzi28 is offline
Find More Posts by banzi28
United States, WI, Eau Claire
Joined May 2011
Isn't that backwards? A nose-heavy plane will push the nose down, increasing the dive?
banzi28 is offline Find More Posts by banzi28
Old Oct 26, 2011, 08:14 AM
HF_ATL is offline
Find More Posts by HF_ATL
Portugal
Joined Nov 2009
No, it isn't...
In a nose-heavy plane you need to have up trim (elevator) and then when the plane is in a dive this up trim cause it to going up thus recovering...
HF_ATL is offline Find More Posts by HF_ATL
Old Oct 26, 2011, 09:39 AM
banzi28 is offline
Joined May 2011
Ah gotcha! Going to try this out! Many thanks!
Discussion How do you mount your fpv camera without a metal box? Voguna FPV Talk 10 Sep 19, 2011 04:47 PM
Discussion How do you hang your plans? Graham Lane Dock Talk 16 Sep 18, 2011 09:37 AM
Discussion How do you fly your plane so far away? GreenAce92 FPV Aircraft 6 Aug 11, 2011 11:35 AM
Discussion How do you transport your plane acdii Electric Warbirds 47 Jul 13, 2011 03:13 PM
