Old Oct 25, 2011, 07:19 PM
heliwill10 is offline
Find More Posts by heliwill10
heliwill10's Avatar
Greensburg, PA
Joined Feb 2008
Pressure bladder with a wing pylon
I’m building a mold for a one piece fuse that has a pylon. Insides of pylons are normally hollow so, how do you incorporate a pressure bladder without blowing the thing out? My plug is just about done, so anything is up for grabs.
A friend and I have come up with two ideas’… Some kind of 3 piece mold (a drawing would be nice). Or some kind of molded insert to block off the opening. Trouble with that is the pylon would not get any benefits of the bladder.
Go slow, I’m still learning
heliwill10 is offline Find More Posts by heliwill10
Old Oct 25, 2011, 09:41 PM
Ward Hagaman is offline
Find More Posts by Ward Hagaman
Ward Hagaman's Avatar
San Diego
Joined Mar 2003
Are you making the bladder out of plastic sheeting? Maybe you can incorporate the pylon shape into that....
Ward Hagaman is offline Find More Posts by Ward Hagaman
Old Oct 25, 2011, 10:27 PM
Jim.Thompson is offline
Find More Posts by Jim.Thompson
Entropy is happening!
Jim.Thompson's Avatar
Australia, NSW, Bellingen
Joined Aug 2008
As Ward says.
I would design the mould so that the pylon will be layed up with with wing seat intact. ie. the mould will be closed allowing the use of a bladder. If you go over to the inflation bladder thread, (which you may already have done), you will find lots of discussion on methods of heat "welding" plastic sheet to form a suitable bladder.
It might require a few attempts to get the bladder template just right, but is doable I think. I would try at least one sacrificial light layup to see if the bladder holds etc. before commiting to a full one with carbon reo etc.
Jim
Jim.Thompson is offline Find More Posts by Jim.Thompson
Old Oct 26, 2011, 07:34 AM
heliwill10's Avatar
Greensburg, PA
Joined Feb 2008
I've been over to the bladder thread, started to make me crossed eyed. I'm going to make the bladder from the drop cloth so cutting the pylon shape shouldn't be a problem.
I like the wing saddle idea closing off the top. I’d have to come up with some way to make sure that is perpendicular to the vertical axis.
Still learning to think backwards
Old Oct 26, 2011, 07:51 AM
tom43004 is offline
Find More Posts by tom43004
Father of Fr3aK, DLG Pilot
tom43004's Avatar
USA, OH, Worthington
Joined May 2002
I use a silicone mold of my pylon (think DLG tail mount) and insert that on top of my wetted cloth in the pylon mold prior to adding the bladder. After the bladder is inflated, it pushes the silicone into the pylon. When you deflate and remove the bladder, you can pull the silicone mold out with hemos or needle nose and reuse it.
tom43004 is offline Find More Posts by tom43004
Old Oct 26, 2011, 11:46 AM
DLGjunkyard is offline
Find More Posts by DLGjunkyard
DLGjunkyard's Avatar
Canada, ON, Morriston
Joined Apr 2010
Im not sure I understand your description of a pylon however I managed to use a poly bladder with success then tried some with party balloons and they also work quite nice. The entry and exit of the pylon allowed the bladders to find a comfy home and seat into the cavity
DLGjunkyard is offline Find More Posts by DLGjunkyard
Old Oct 26, 2011, 11:54 AM
Joined Apr 2010
Old Oct 26, 2011, 02:58 PM
heliwill10's Avatar
Greensburg, PA
Joined Feb 2008
Do you have a picture of this? What psi are you running? If I understand a high psi might pop the insert out?
Old Oct 26, 2011, 03:01 PM
heliwill10's Avatar
Greensburg, PA
Joined Feb 2008
This is close to my pylon, except it has a wing saddle. My mold will have to split vertical.
Old Oct 26, 2011, 03:08 PM
tom43004 is offline
tom43004's Avatar
Joined May 2002
No, the insert goes into the pylon opening. More bladder pressure just presses it harder into the pylon opening.
My current molds don't have the mounts molded in so I don't think I have pics.
Old Oct 26, 2011, 03:20 PM
Joined Aug 2008
I use a silicone mold of my pylon (think DLG tail mount) .....................
I think you mean "plug" here Tom or "insert", not mould. Is that right?
I know the two terms plug and mould are often interchanged which can lead to some confusion.
I have used two pack silicone inserts to support the bladder successfully in the wing fillet/stubs of a fuselage for a two part wing moulded plane.
Jim.
Old Oct 26, 2011, 04:37 PM
tom43004 is offline
tom43004's Avatar
Joined May 2002
Insert is fine.
Mini-HowTo Fuse Molding with an Inflation Bladder wyowindworks Composites Fabrication 987 Mar 08, 2016 10:52 PM
Help! Pressure problem with YS 110 FZ Engine CHUNKSTER 3D / Fun Fly Fuel Planes 2 Jun 17, 2011 10:41 AM
For Sale Relisted... Jibe Pylon F5D racer - full carbon wing with servos, priced to go verticalflight Aircraft - Electric - Airplanes (FS/W) 4 Oct 06, 2008 09:48 AM
For Sale Wing MFG At6 texan pylon racer with pic trades? crashEMhard Aircraft - Fuel - Airplanes (FS/W) 3 Jan 15, 2008 03:57 PM
Wanted Got a pylon wing with no Fuz? I need a wing!! highasakite99 Aircraft - Electric - Airplanes (FS/W) 0 Mar 05, 2006 03:26 AM
