Old Oct 25, 2011, 06:15 PM
PMDRACER is offline
Find More Posts by PMDRACER
SoCal, California
Joined Feb 2009
HiTec X4-AC charger
I'm considering the purchase of a HiTec X4-AC charger. I'm drawn to this unit because of the AC/DC power and having 4 ports to use.
http://www.hitecrcd.com/products/new...4-ac-plus.html
I will only be charging LiPo batteries, specifically my inventory of two 2S-4000mAh, four 2S-5000mAh and two 2S-8000mAh.
Anyone have any experience with this unit (or the DC-only cousin)? Thank you in advance.
PMDRACER is offline Find More Posts by PMDRACER
Old Oct 25, 2011, 08:01 PM
Duster_360 is offline
Find More Posts by Duster_360
Texas
Joined Aug 2006
Search in the batteries and charger forum - there's experience in there with that charger. It is limited to 50watt per port and the charge rate is also limited by the wattage. You won't be able to charge you 8000mah 2S at 1C using that charger.
That charger will charge an 8000mah 2S, it will just take longer. Their dual charger, Hitec X2, may be a better choice with its 200watts and 10amps max charge rate per port. Whichever you go with, make sure you get a PS with enough power to run all ports at rated power if your plan is to use it that way.
Duster_360 is offline Find More Posts by Duster_360
Old Oct 25, 2011, 10:41 PM
PMDRACER is offline
SoCal, California
Joined Feb 2009
I appreciate the feedback and definitely will look there.
If you don't mind the dumb questions:
1. How do you figure Watts/mAh/Amps, etc to determine if a charger will keep up? I understand that my 5000mAh battery will need 5A to charge at 1c, while my 8000mAh battery will need 8A to charge at 1c, but how do I relate those numbers to the charger I'm looking at?
2. If I am charging a battery (any battery) at 1c, does that equate to the charging process taking 1 hour (well, more or less, taking into account the way the final part of the charge process takes a little more time)?
Please take it easy on me. Electrical theory goes over my head in a hurry. Thanks again.
Old Oct 25, 2011, 11:23 PM
PMDRACER is offline
SoCal, California
Joined Feb 2009
OK, I think I found the answer to my questions (post #47 about the HiTec).
# cells (S) x volts per cell (4.2) x Amps (mAh/1000) = Watts.
So, assuming 50W per port
2s 5000:
2x4.2x5 = 42W (51 minute charge)
2s 4000:
2x4.2x4 = 33.6W (41 minute charge)
2s 8000:
2x4.2x8 = 67.2W (80 minute charge)
Am I correct? If so, I find this completely acceptable. I'm currently using a PolyCharge4 that only charges at a max of 3A and takes 4+ hours to charge the 2s-8000mAh batteries!
Old Oct 26, 2011, 05:50 PM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
That's close, you also have to account for the efficiency of the charger, so you'll probably see a bit under 50w of actual output.
wparsons is offline Find More Posts by wparsons
Discussion Hitec X4 Charger Save Data Gripe zero2444 Batteries and Chargers 5 Dec 18, 2011 06:40 PM
New Product BRAND NEW! Hitec X4 AC Plus Charger - in stock at ServoCity! ServoCity ServoCity.com 0 Oct 19, 2011 08:48 AM
Discussion Need Hitec X4 Charger Balance Board For Eflite 3S 11.1V 3200Ah Lipo? itsme2 Batteries and Chargers 2 Jul 22, 2011 10:38 AM
Sold Hitec X4 Charger Near New lgibjones Aircraft - Electric - Batteries & Chargers (FS/W) 2 Jun 11, 2011 12:39 PM
Sold brand new in box hitec x4 multi charger gravediggermax Cars - Accessories (FS/W) 2 Apr 15, 2011 07:33 PM
