Old Oct 25, 2011, 04:42 PM
billy2100 is offline
Find More Posts by billy2100
Joined Oct 2011
Question
SKY706 Simulator port
Is it possible to get a ppm signal (like the FUTUBA) from the SKY706 simulator port, in order to use it with simulators such as pheonix?
I realise the simulator port provides a USB output, but there appears to be more pins on the port than are required for USB.
I thought maybe the additional pins would provide a ppm output?
billy2100 is offline Find More Posts by billy2100
Old Oct 26, 2011, 05:37 AM
Parkflying is online now
Find More Posts by Parkflying
United States, MI, Auburn Hills
Joined Dec 2008
Thanks for this good question. I will check with the factory and update with an answer here.
Personally having setup thousands of these when we bench test before shipping to our customers, unless your Tx is setup for standard 4 channel Airplane type operation, I recommed using a separate simulator controller. Because CCPM control is done in the Tx programming it becomes a problem to use them with many of the flight simulator programs.
However I will check with the factory to see if any of the pinout combinations will give you PPM output
Regards
Max
www.parkrcmodels.com
Parkflying is online now Find More Posts by Parkflying
Site Sponsor
Help! Cable For Dynam Hawk Sky Simulator Port andrew99 Power Systems 1 Aug 24, 2011 02:07 PM
Discussion DX6 Trainer/Simulator port itplachy DIY Electronics 3 Aug 11, 2011 09:01 PM
Wanted:Simulator Cable w/usb Port for futaba to pc Bookstar75 Aircraft - General - Radio Equipment (FS/W) 6 Feb 26, 2005 04:48 PM
need old serial port TX interface cable for Realflight simulator 1g1yy Simulators 1 Mar 27, 2004 07:38 PM
Need old style serial port cable for Realflight simulator 1g1yy Aircraft - Electric - Airplanes (FS/W) 2 Mar 27, 2004 05:44 PM
