Old Dec 08, 2012, 09:27 AM
dankar04 is offline
Find More Posts by dankar04
Tucson, Az
Joined Feb 2007
The 270A while slow is a very nice flyer. Fly it anyware you want and go for precision landings. Many ways to enjoy it. Velvet smooth and nice banked turs etc. The 260A is more agressive and smooth also. My 260A has xtreme l/g and works well. Even funky TX works fine and has dual rates. Newbies will find 260A a lot to handle. Its nice to fly both and just enjoy them. If you want a hot heli get a Walkrea Super F/P fbl/ MSR-X. They are fast agile and a handful. Terrible in ground affect a c/p handles better.
dankar04 is offline Find More Posts by dankar04
Old Dec 15, 2012, 04:45 AM
Cralis is offline
Find More Posts by Cralis
I love FPV!
Cralis's Avatar
Eastern side of Australia
Joined Jan 2007
My Solopro 270 is basically useless since I got it. Won't go forwards fast at all. Infact, won't really go forwards, unless I am turning. Is there a fix?
Cralis is offline Find More Posts by Cralis
Old Dec 15, 2012, 10:12 AM
rcstringfellow is offline
Find More Posts by rcstringfellow
NE solo free spirit V2
The Netherlands, NB, Eindhoven
Joined Mar 2012
Maybe it is tail heavy? You could check the centre of gravity of your heli.
rcstringfellow is offline Find More Posts by rcstringfellow
Old Dec 17, 2012, 09:28 AM
dywanesko is offline
Find More Posts by dywanesko
Joined Jun 2011
hello. im into this topic since it started, and i havent seen a reply for my question:
When im adding the throttle, the engine starts when the throttle is 7%. Is it normal?? or can i fix it somehow? My friend has a Trex100, and it is running smoothly from the 1% throttle.
The second thing is, that i have equiped my 270A with xtreme parts, and i must say it is more stable, and the flybar more more persistent. And the good thing about it is the abillity of changing weight on it, so with the full weight it gains stability during the outside flying.
dywanesko is offline Find More Posts by dywanesko
Old Dec 20, 2012, 04:38 PM
Joined Jun 2011
i change my question, because i know that i can trim the throttle, that it starts with 1%,
but i would like to know, why 270a even on low rates at the 1% throttle is behaving like it would like to go up just in the same moment, and trex100 for example starts smooth and is standing still at 1%, and starts beeing unstable on the ground after 5 or 6% ??
is this the lack of adjusting the curves on the TX ?? or is this only my version ?
Old Dec 23, 2012, 11:22 AM
SoloProFan is online now
Find More Posts by SoloProFan
Fan of just about anything RC
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Check if the links between and swash and head are on the longest balls, I've seen some 270s being shipped with the links on the shorter balls, reducing swash action. Also, check if you don't have excess vertical play on the main shaft, if you you, part of the servo movement when going forward, is being used to pull the shaft down before the swash starts moving.
The throttle curve on the J4 transmitter is a little odd. It goes to hover rpm pretty fast, then reduces the response for the middle section of the throttle stick's movement, and then the response gets faster as throttle is increased. It's not as linear as on the 260. Benefit is, it's easier to maintain altitude as the throttle is less twitchy around hover rpm, but as a result it's less smooth above and below hover rpm.
SoloProFan is online now Find More Posts by SoloProFan
Old Jan 04, 2013, 04:07 AM
bugpat is offline
Find More Posts by bugpat
Master of the world !
bugpat's Avatar
France, PACA, Ménerbes
Joined Nov 2005
270 + 911...
Hi guys,
I'm not posting very often here... but I'm reading a lot...
I'm the proud owner of a SoloPro 270 for one month.
This litlle heli flies perfectly, is strong enough (never broke anything on it), but like others, I think it isn't fast enough, especially when flying outdoors with very little wind.
So, after having read this long post, I ordered a WL 911 (combo) at Banggood (was shipped yesterday), and I'll install the RX on my 270.
I will try to bind it with my children radios too (Turnigy 6) just too see if that's possible...
And I will put the 270 RX on the 911, so my children can use it too (and let me play with the 270 )
bugpat is offline Find More Posts by bugpat
Old Jan 04, 2013, 05:25 AM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Did you check if the links from swash to blades are already on the longer balls on the swash? That's an easy way to get more cyclic and forward speed. Also, shifting the battery forward or adding a little weight in the nose will help. The 270 is a little tail heavy, less than the Bravo SX or V911, but still. The 260 has more weight in the front, and as a result is much zippier in forward flight.
If the Turnigy 6 is the new transmitter, I doubt it will bind, they changed protocol between 9x and newer transmitters...
Old Jan 04, 2013, 07:08 AM
bugpat is offline
bugpat's Avatar
Joined Nov 2005
Yes, the links to the blades are already on the longer arms of the swashplate...
I played a little with subtrims, but if I can go fast forward, I can't have speed on rear trajectories...
It doesn't matter if the 6X can't bind with 911 RX, I planned to use the 911 TX anyways.
I'll giving news here when I'll receive the 911...
Old Jan 04, 2013, 08:39 AM
bugpat is offline
bugpat's Avatar
Joined Nov 2005
Another thing, SoloProFan :
What do you think about using flybar paddles instead of weights, like that ?
I saw this mod on the WL911 thread...
post #1000...
Old Jan 05, 2013, 02:02 AM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
post #1000...
Haven't seen it used on the 270 before, if I recall well. It's not a drop in fit like the mSR flybar on the V911, as I understand. But I believe Xtreme has seperate mSR paddles for their CF flybar for the mSR, those will be a lot easier to fix on the 270 flybar.
Old Jan 05, 2013, 06:03 AM
erdnuckel2 is offline
Find More Posts by erdnuckel2
erdnuckel2's Avatar
Joined Mar 2009
Well, here is my take on it:
http://www.rcgroups.com/forums/showt...591898&page=12
Old Jan 09, 2013, 03:41 AM
bugpat is offline
bugpat's Avatar
Joined Nov 2005
Very interesting...
For the moment, I'm waiting for the V911, and after having installed his RX in the 270, I'll see if I'll try the paddle mod...
Old Jan 09, 2013, 07:01 AM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Originally Posted by erdnuckel2 View Post
Interesting. Though this is done on a V911/270 hybrid it appears to be worthwhile. What were the exact improvements on flight? And did you also try a stock 270 head on your V911 before doing this flybar mod to paddles?
Old Jan 09, 2013, 09:58 AM
erdnuckel2's Avatar
Joined Mar 2009
You mean because of the weighted flybar ... or why else? I tried the V911 with the stock (complete) head, but the weighted flybar - which is as flexible as the original one - plus the fact that the V911 main shaft is a tad shorter than the SP270 main shaft makes it even more prone to get flybar strikes than original (and that is already bad in my book). So for the V911, if you do NOT want to go with the CF one, it is not really the most brilliant idea ...
New Product Nine Eagles Solo Pro 100D / Solo Maxx 3D Frank_fjs Micro Helis 1873 Jan 17, 2016 01:29 AM
Build Log neRecv - Solo/Solo Pro TX as HID Joystick or PPM simulator controller kile DIY Electronics 51 Jul 09, 2013 06:36 AM
Discussion Solo Pro or Solo Free Spirit 220a frekin Micro Helis 7 Jun 04, 2011 05:35 PM
Sold Nine Eagles Solo Pro/SOLO/Free Spirit/BRAVO III Battery Charger palomo Aircraft - Electric - Helis (FS/W) 0 Feb 17, 2010 06:38 PM
