Old Sep 15, 2012, 01:55 AM
SoloProFan is online now
Find More Posts by SoloProFan
Fan of just about anything RC
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Originally Posted by Enric Vision View Post
Thanks, but those are the original carrying the heli Solo Pro 270 and I lasted two days. 2 bateries to the trash
Wait a few days, and if you say anything against me decide for these:
http://www.miracle-mart.com/store/in...oducts_id=8947
Regards,
Enric
How long do you fly on a battery? When do you decide it's time to stop flying? When the heli can't keep altitude? I think you drain the batteries too far, and in that case not a single battery will last more than 2 days. I suggest you use a stopwatch to time the flights, and limit these to 5 minutes. Or check the throttle percentage indicator on the display when the heli is in a stable hover. When this percentage has increased by about 10% it's time to think about landing. So say, with a fresh battery you need 45% throttle to maintain altitude, then it's time to stop when you need 55% to maintain the same altitude. The voltage directly after the flight should be around 3.70 volt, or higher.
SoloProFan is online now Find More Posts by SoloProFan
Old Sep 15, 2012, 08:24 AM
Enric Vision is offline
Find More Posts by Enric Vision
Spain, CT, Barcelona
Joined Aug 2012
Thank you very much, I take note of his instructions. I add them to the article about LiPo's http://www.rchelicopterfun.com/rc-lipo-batteries.html of Masen72
2 days of use and improper storage 15 days without use
No use timer to control the duration of flight. When it costs to fly, stop and do not charge batteries
With every Lipo what I used (3) in different helis (4) I have never been careful preservation and not problems. I see you're more modern if required.
Regards, Enric
Enric Vision is offline Find More Posts by Enric Vision
Old Sep 15, 2012, 09:45 AM
dankar04 is offline
Find More Posts by dankar04
Tucson, Az
Joined Feb 2007
My parts from Hobbyking arrieved yesterday. now I can get one of my favorite birds flying again. Wish me luck as parts sure are small and have big hands.
dankar04 is offline Find More Posts by dankar04
Old Sep 15, 2012, 12:49 PM
dankar04 is offline
Tucson, Az
Joined Feb 2007
I installed flybar and put my baby back together and just ran it up. everything seems smooth as ever. I will most likely fly it later , gotta take care of business right now. Just sold several vintage engines !! More $$ for the cause, and half into bank. Got some 160ma Turnigy batteries and try them.
Old Sep 15, 2012, 01:03 PM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Regards, Enric
You may have been lucky so far. One single time of too deep discharge can damage any lipo, whether used in heli, boat or car. Some helis have protection against too deep discharge. For instance the Walkera Mini CP will force the heli to make a smooth landing, and voltage after landing is still above 3.7 volts with no motors running. That's staying on the safe side. If you go lower in voltage, the voltage under load could drop under 3 volts, and then you get into "you really risk to kill your lipo" territory.
Old Sep 20, 2012, 04:49 PM
pavcon is offline
Find More Posts by pavcon
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
guys.. my heli is back in the air.. but one of the two has a problem with the radio. it won' tget any throttle input.. . it has to be the radio because when I try it with the other one it works just fine. i opened the radio but there is not much I can do about it.. any thoughts???
pavcon is offline Find More Posts by pavcon
Old Sep 20, 2012, 07:22 PM
dankar04 is offline
Tucson, Az
Joined Feb 2007
I broke flybar and replaced it. Everything works fine except hardly any foward speed. I have not adjusted any arms on my helis but sure this will need to be done. Looks like both servo arms will need to be adjusted. Any input as which way to adjust arms Screw them down I guess? Never had need to do this. When I attahed bracket to blades one screw striped out. Put a drop of ca. glue in hole and put locktite on screw. It did not hold. Screw is way to short and there is a bushing. Plastic for blades is real garbage and was very gentile with this. I ordered a screw set and new blades but aside from a bad striped hole blades are in great shape. Local Hobby shop is a joke and only place to get these tiny screws are online. I wonder if they sell maintenence kits with asortment of small screws anyware ?? I don't have any birds to canibalize. Quads sure sound better and better as no linkage mess to deal with.
Old Sep 21, 2012, 12:22 AM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Perhaps someone who installed another board, 260 one, or V911 for instance, still has a unused transmitter lying around?
Maintenance kits for these relatively cheap helis are not common. Often the strategy is to get 2 helis, and use the second one for parts, tends to be cheaper than stocking spares.
As for the stripped screw holes, you are talking about the mixer arms, right? Did you unsnap the links on those as well? I use the method of only loosening as less as possible. In case of a flybar replacement that would mean only unsnapping the linkages on the flybar, and remove it. Although material quality can vary, we're still talking about tiny plastic parts, that can only take so much.
You could try getting a screw set for the Losi Micro T buggy though, it's very small 1/36 scale, and uses tiny screws of various lengths. Or get a new 270, sell the TX to pavcon, and keep the heli.
Old Sep 21, 2012, 05:34 AM
pavcon is offline
Joined Jan 2010
Originally Posted by soloprofan View Post
perhaps someone who installed another board, 260 one, or v911 for instance, still has a unused transmitter lying around?
maintenance kits for these relatively cheap helis are not common. Often the strategy is to get 2 helis, and use the second one for parts, tends to be cheaper than stocking spares.
you could try getting a screw set for the losi micro t buggy though, it's very small 1/36 scale, and uses tiny screws of various lengths. Or get a new 270, sell the tx to pavcon, and keep the heli.
Old Sep 21, 2012, 10:16 AM
dankar04 is offline
Tucson, Az
Joined Feb 2007
I had a old DOA co-ax from hobbyking and took a couple screws out of . Screws are longer and same diameter. Just need to taper front of screw. mess with it later. Anyway anybody have idea of adjusting arms from servos to increase foward speed? Are they mixed as to adjust both, like I said never did this ?
Thanks ,Dan
As much as I like this 270A I don't want another one.
Old Sep 21, 2012, 04:52 PM
ScrapDaddy14 is offline
Find More Posts by ScrapDaddy14
United States, TN, Crab Orchard
Joined Aug 2012
I'm new to rcgroups so I would like to say hi. The Solo Pro 270 is my first heli and I have just started reading the begining of this thread but I just couldn't resist posting a few pics of my 270. By no means is it stock I have made a few upgrades and mods to it. Name: 2012-09-19_19-39-12_874.jpg
Description: Solo pro 270
Description: Solo Pro 270 with V911 receiver, extreme metal swash and mixing arms.
Description: v911 reciever with connectors soldered on for solo pro 270. I came across this rx swap by way of Armattan on youtube. I apologize if this isn't the proper thread for this but like I said I'm new.
ScrapDaddy14 is offline Find More Posts by ScrapDaddy14
Old Sep 21, 2012, 06:13 PM
Daryoon is online now
Find More Posts by Daryoon
Team WarpSquad
Daryoon's Avatar
United States, CA, San Diego
Joined Dec 2010
Welcome ScrapDaddy14. Armattan goes by the username of Bobepine on here.
Nice job. I assume the v911 RX makes the 270 fly better? What's your impression?
Daryoon is online now Find More Posts by Daryoon
Old Sep 21, 2012, 09:42 PM
Joined Aug 2012
Thank you for letting me know that. After reading thru a few pages I realized that Lol. Well like most people have said the servo throw is quite limited with the 270 rx which for a beginner like myself wasn't really an issue it's stable and a good learner. My aileron servo was actually binding so I said what the heck let's play around a bit that's when I found Bobepine's vid on YouTube. I just had to try it.
Old Sep 21, 2012, 11:43 PM
bobepine is online now
Find More Posts by bobepine
bobepine's Avatar
Joined Jun 2011
ScrapDaddy,
I received your message on YouTube. Nicely done on the RX swap, and congrats, you now have the best flybarred, micro, fixed pitch heli that can be had.
And welcome to RCG!
Best,
Chris
bobepine is online now Find More Posts by bobepine
Site Sponsor
Latest blog entry: Armattan F1 Lineup Revealed
Old Sep 22, 2012, 01:42 AM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Thanks ,Dan
The key to more forward speed is using a good battery for good motor rpm (which is good when using the stock 150 mAh battery) and getting more throw on the forward elevator. I used a spare 260 receiver to achieve this, but there are other ways. You could shorten the elevator arm on the swash, there are a few guides on youtube on how to do this, mostly about the mSR, but the procedure is identical.
New Product Nine Eagles Solo Pro 100D / Solo Maxx 3D Frank_fjs Micro Helis 1873 Jan 17, 2016 01:29 AM
Build Log neRecv - Solo/Solo Pro TX as HID Joystick or PPM simulator controller kile DIY Electronics 51 Jul 09, 2013 06:36 AM
Discussion Solo Pro or Solo Free Spirit 220a frekin Micro Helis 7 Jun 04, 2011 05:35 PM
Sold Nine Eagles Solo Pro/SOLO/Free Spirit/BRAVO III Battery Charger palomo Aircraft - Electric - Helis (FS/W) 0 Feb 17, 2010 06:38 PM
