Old Oct 25, 2011, 02:22 PM
SoloProFan is online now
Find More Posts by SoloProFan
Fan of just about anything RC
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
New Product
Solo Pro 270, successor to the Solo Pro V1/V2 and Bravo SX
Nine Eagles apparently decided to revamp the Solo Pro, and is coming with the Solo Pro 270.
The head setup seems more similar to the Trex 100, mSR and GW9958, but a closer study reveals the swash connects directly to the blades, and not first to the flybar, like on the other helis mentioned.
The swash plate now has the guidance pin pointing backwards, and not angled 45 degrees sideways. Stock lipo is 150 mAh and the main shaft seems metal now. How this translates to flying performance, no idea. But any news is welcome in this topic.
The manual can be downloaded as well. This reveals a dampened feathering shaft with 0-rings, so no more sheared off blade pivots. The battery is inserted the same way as on the Bravo SX, connector facing forward. And the swash also has a ball in the center, to keep it more locked on the main shaft, just like on the Xtreme metal swash.
Transmitter can be changed from mode 1 to mode 2, but not as easily as on the "classic" Solo Pro TX, with just one single screw to be loosened and fixed again after moving the antenna. Both sticks can be removed as a single unit, after removing 4 screws, and then turned 180 degrees, and put back again.
SoloProFan is online now Find More Posts by SoloProFan
Old Oct 25, 2011, 06:40 PM
Brosol is offline
Find More Posts by Brosol
Brosol
Brosol's Avatar
Canada
Joined Dec 2010
The NE 270 reminds of a Bravo SX based build with Xtreme feathered shaft head & metal swash ball as stock features. Maybe NE 270 parts can be used to upgrade stock Solo Pro/Bravo SX....cheaper than Xtreme parts.
I wish they used a Bell Hiller FB instead but perhaps moot if a FBL version is released to match the MSR X.
Brosol is offline Find More Posts by Brosol
Old Oct 26, 2011, 01:14 AM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
The swash might be usable, although you would have to relocate the guidance pin, which is facing straight backwards of the 270, but sideways at 45 degree on the Solo Pro "classic". Perhaps you can build a "Frankenswash" from a 270 and V2 swash.
I doubt NE will release a true Bell Hiller version, this would have been the moment to do that. I expect the next incarnation of the SP at this size to be FBL indeed.
Old Oct 28, 2011, 02:15 AM
Daryoon is online now
Find More Posts by Daryoon
Team WarpSquad
Daryoon's Avatar
United States, CA, San Diego
Joined Dec 2010
Actually, it's pretty easy to move the swash pin guides on the Solo Pro/Bravo SX frame.
Just remove swash pin guide from frame. Then smooth out the notch that mate with the groove in the frame. Now, twist the swash pin guide till it is centered. CA in place. Should be a solid hold.
I feel like the 270 has it's place...but it should have came out during the time the Trex100s debut. Now, FBL seems to be the way to go. Nine Eagles has all the pieces of the puzzle. Not sure what they are waiting for. Coming out after Horizon Hobby will always give Nine Eagle that stigma of being a copy cat.
Daryoon is online now Find More Posts by Daryoon
Old Oct 28, 2011, 06:15 AM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Doesn't the location of the guidance pin affect the behaviour of the cyclic response?
Old Oct 30, 2011, 06:38 AM
bb42 is offline
Find More Posts by bb42
bb42's Avatar
Berlin, Germany
Joined Oct 2009
Guidance
The guidance pin's only job is to avoid the swash turning; from the friction forces of the bearing, which are quite low.
It is not part of the liver mechanics of the actual steering - so the new position should not make any difference (whereas other changes in the rotor might).
bb42 is offline Find More Posts by bb42
Old Nov 01, 2011, 11:40 AM
bobepine is offline
Find More Posts by bobepine
bobepine's Avatar
Joined Jun 2011
Is it just me or does the clearance between the tail boom and the flybar seems insufficient as per the NE's tradition to have flybar strikes on their FP helis? Hard to tell from the picture, but I do remember looking at the 328 in my hands and thinking that there was no way the flybar would strike to tail boom. But no, once you have the heli in the air, g force bends the flybar and tock tock tock. Flybar strikes, especially when forcing left banked turns. It's an abomination in design repeated heli after heli....
I sold all my NE helis. The 328, the SP, the Bravo SX and the Free Spirit 220a. Two are in Australia, one is in Paris and the other is in Arizona. I had them all modded, and frankly, they are fun helis but after using a decent TX, the stiff sticks on the toy like NE TXs really bummed me out, and more importantly, I never flew them enough so my batteries were going to go bad on me. Having to buy batteries again just for the odd flight wasn't appealing. So off they went to their new owners who apparently enjoy them in their turn. I do not miss them, though...
I'll wait to hear user's report on this heli and I might be interested in one for indoor flying and odd outdoor escapades if NE finally addressed the flybar strikes that are a drain on the SP, the 328 and the Bravo SX experience. As for the Free Spirit 220a, it needed a new rotor head every 3 flights at best so that's quite reprehensible.
I notice that the SP 270 went back to a straight tail boom like the first version of SPs. They moved the tail motor above the boom on this one, though. Maybe this is to address the flybar strikes while retaining better flight characteristics noted in the second version of the SP with the angled tail boom which elevates the tail motor.
All in all, I think this will be a good entry level heli as NE tends to be affordable and quite durable. But hopefully NE ironed out the bloody flybar strikes.
And what is that I hear about a new TX for this heli? Any pictures available? I couldn't find any.
Regards,
Chris
bobepine is offline Find More Posts by bobepine
Site Sponsor
Old Nov 01, 2011, 12:48 PM
helicopcat is offline
Find More Posts by helicopcat
helicopcat's Avatar
Joined Jan 2011
Originally Posted by bobepine View Post
[...]And what is that I hear about a new TX for this heli? Any pictures available? I couldn't find any.
Regards,
Chris
Should be the same of this one for the new Bell 206 (328 with scale fuselage)
helicopcat is offline Find More Posts by helicopcat
Old Nov 01, 2011, 10:50 PM
zadaw is offline
Find More Posts by zadaw
Hong Kong
Joined Jan 2010
NE has really got to get their act together. They have now potentially got 3 badly received releases in a row: 328, 180D and possibly the 100D. Their brand image has been seriously affected by this. Not only that, the Solo Pro, which is their bread and butter, is being seriously challenged as well by very cheap clones.
zadaw is offline Find More Posts by zadaw
Old Nov 02, 2011, 02:38 AM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
I think on the FP helis they are too focused on the head design of the "classic" Solo Pro, not realizing it doesn't work that well when scaling up (328). The 100D suffers a little from the Genius CP, which even seems to surpass the praised mCP-x. Hard to match that on a first CP release. I think their best move would be to release a flybarless version of the Solo Pro/270.
Old Nov 02, 2011, 07:26 AM
zadaw is offline
Hong Kong
Joined Jan 2010
There are other problems as well, such transmitter not compatible between different models, and also having one model memory only. Sure the Genius CP didn't help and not did the reduction of the MCPx RTF price to $170. But it seems that the 100D is not really ready for release. There seems to be at least 3 different versions with either metal or CF main shaft, and fixed or pop-in main gear. What I think Nine Eagles need is to get a few really good partners to help out.
Old Jan 03, 2012, 11:53 PM
smail853 is offline
Find More Posts by smail853
Joined Jan 2012
Hi,
I'm planning on buying a 4 channel heli. Should I wait for the Solo Pro 270 or just get the Solo Pro v2?
smail853 is offline Find More Posts by smail853
Old Jan 04, 2012, 12:14 AM
bytemuncher is offline
Find More Posts by bytemuncher
Tokyo
Joined Jan 2010
Flybar=FAIL
Where is Nine Eagle's answer to the MSR x???
*edit* smail, just get the v2. It flies very well (I own 2) and you can get cheap replacement parts from the v911.
bytemuncher is offline Find More Posts by bytemuncher
Old Jan 05, 2012, 12:13 AM
smail853 is offline
Joined Jan 2012
Sorry, I'm new, but are there going to be any major flight characteristic differences between the Solo Pro and the Solo Pro 270?
Old Jan 05, 2012, 12:22 AM
Tokyo
Joined Jan 2010
I don't know anyone who has flown the the 270 so difficult to say. However, if I were you I would pass on the solo pro and get the v911. It can bind to a turnigy 9x radio which is programmable. Even if you don't need this or even care about this in the beginning it is important as it will allow you to progress in this hobby should you want.
New Product Nine Eagles Solo Pro 100D / Solo Maxx 3D Frank_fjs Micro Helis 1873 Jan 17, 2016 01:29 AM
Build Log neRecv - Solo/Solo Pro TX as HID Joystick or PPM simulator controller kile DIY Electronics 51 Jul 09, 2013 06:36 AM
Discussion Solo Pro or Solo Free Spirit 220a frekin Micro Helis 7 Jun 04, 2011 05:35 PM
Sold Nine Eagles Solo Pro/SOLO/Free Spirit/BRAVO III Battery Charger palomo Aircraft - Electric - Helis (FS/W) 0 Feb 17, 2010 06:38 PM
