Espritmodel.com Heli Air
View Poll Results: Which is better ARC or MEGA?
ARC 28-58-1 6 28.57%
MEGA 16-40-1 15 71.43%
Voters: 21. You may not vote on this poll
Old Oct 25, 2011, 02:45 AM
Joined Jul 2011
ARC 28-58-1 vs MEGA 16-40-1
I was wondering if anyone out there knows which of these two motors (ARC 28-58-1 or MEGA 16-40-1) would be best suited for a 70mm setup running 6s?
Thank you all for your time!
xTIBSx is offline Find More Posts by xTIBSx
Old Oct 26, 2011, 11:45 PM
Joined Jul 2011
Or how about just ARC vs MEGA in general? Which is better?
Old Oct 27, 2011, 03:47 AM
Peter M's Avatar
Newcastle, New South Wales, Australia
Joined Sep 2007
Depends on what criteria you are comparing them on?
If I couldn't afford a Mega, I would buy an ARC
If I wasn't worried about bending or breaking shafts, I would buy an ARC
If I wasn't worried by the end shield coming loose from the casing and eventually having to drill and pin to secure them myself, I would buy an ARC.
If I'm not worried about having a wide range of kV's to choose from, I'd buy an ARC.
Frankly if you can't afford the cost or the wait for a Mega, I would suggest you look at HET's before you consider an ARC.
Hope this helps!
Regards
Peter
Peter M is offline Find More Posts by Peter M
Old Oct 27, 2011, 01:56 PM
Joined Jul 2011
Hope this helps!
Regards
Peter
Helps alot!Thank you! So ARC's aren't very high in overall build quality...I'm new to EDF so I thought ARC and MEGA were on par with each other.
Old Oct 27, 2011, 02:00 PM
Joined Jul 2011
Just to clarify, what I mean by "better" is:
1. Which has higher quality
2. Which will withstand being run harder, and run above their specs
3. Which runs more efficiently
4. If two motors with similar ratings were (such as the 16/40/1 and 28-58-1) were run in identical setups, which would give the most output?
-I understand that the ARC 28-58-1 has a higher kv (3180) than Mega 16/40/1 (3150kv) but when put under load, which would be closer to it's kv rating?
Old Oct 27, 2011, 02:11 PM
Team White Llama!
gundamnitpete's Avatar
1. mega has higher quality, but the arcs are of high qaulity. Mega's generally run 1.5-2times the cost of an equal ARC motor, so not exactly a fair comparison.
2. The mega
3. the mega
4. the mega.
The mega is more efficient, can generally handle more power, and because of it's efficiency, would prolly turn the fan at more RPM than the ARC.
However, the mega costs more money. and i hate to say it, but performance vs price matters, otherwise all of my aircraft would prolly be $5K turbines.
The arc's are outstanding value. A cut above anything else in it's price range. only thing that comes close for the price, IMHO, are HET's. and honestly, I would take an arc over an HET anyday of the week.
I've run the ARC's on 6S in wemo's and DS-30's and HET's. you are looking at 95-110 amps and 2100-2300 watts, depending on fan, batteries, etc.etc. Both motors are burst use only at this level.
I personally, would buy an ARC. There is NOTHING wrong with the 28-58-1 on 6S. I'll gladly give up 2-3% efficiency for 40-50% cost savings ($90 vs $150). I love all my ARC/HET combos.
here's my ARC 28-47-1 with HET fan in an HET super sniper. fun little edf:
HET Super Sniper with ARC 28-47-1 (2 min 20 sec)
gundamnitpete is offline Find More Posts by gundamnitpete
Old Oct 28, 2011, 07:00 AM
Joined Jul 2011
2. The mega
3. the mega
4. the mega.
http://www.youtube.com/watch?v=aZVQe52KOn0
Thanks for the reply Pete! Yea, I'm kinda leaning toward the ARCs myself. I was just hesitant though, because of all the shaft issues ARC has (or so I've been hearing)
AWESOME VIDEO BTW!!
Old Oct 28, 2011, 08:24 AM
Team White Llama!
AWESOME VIDEO BTW!!
haha thanks!
The shaft issues for the ARC's are with the prop guys. I've grenaded many fans with a 28-58-1 and never had any shaft issues.
Old Oct 28, 2011, 11:50 PM
Hemet, California, United States
Joined Aug 2001
Hi,
I have a 28-58-1 in a 6S 70mm set up with about 30+ flights on it. No problems so far and I would buy another in a heartbeat.
Mickydee
mickydee is online now Find More Posts by mickydee
Old Oct 29, 2011, 01:40 AM
Joined Jul 2011
Originally Posted by mickydee View Post
Hi,
Mickydee
Sweet, I'm building a 70mm EDF. What ESC are you running and how many amps are you drawing?
Old Oct 29, 2011, 09:40 AM
Joined Aug 2001
Hi,
Castle 125 amp. 6S Turnigy 5000 40C batteries, (2X3 cell packs.) I have no idea on the amp draw but I set the timer for 4:30 and land with about 15-20% left in the packs.
Mickydee
Old Nov 15, 2011, 05:44 PM
Joined May 2011
Amps
If I run a 6S/4000 mah/65C LiPo to the 28-58-1/ DS30 Rotor/TJ70 Fan.How many watts will this system be producing?? 2000?? 2100??
ZACATTACK is offline Find More Posts by ZACATTACK
Old Nov 15, 2011, 06:36 PM
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
Hi Pete... just a pedantic professor taking you (gently) to task.
Your explanations are wonderfully lucid, but the use of "prolly" for "probably" simply drives me up the wall.
And you are by no means the only one to use this term, which surely cannot be found in the Oxford or even Webster's.
Here endeth the lesson.
Cheers, Phil
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Nov 22, 2011, 06:00 PM View Post
ZACATTACK
A moderator felt this post violated the following rule: Personal Attack. Show it to me anyway.
Old Dec 30, 2011, 04:25 PM
Joined Dec 2008
Then why does effluxrc state that both the Arc and the Mega put out 5.5 lbs of thrust out of the same alloy wemo fan unit? I'll prolly get the arc when it's time to shop .
pencon is offline Find More Posts by pencon
Discussion Arc 28-58-1 Boogie_ Electric Ducted Fan Jet Talk 79 Dec 24, 2012 11:09 PM
Discussion Mega 16/40/1 compared to 16/40/2 sebbe High Performance 9 Sep 15, 2011 06:23 AM
Wanted arc 28-58-1 motor onefastxp Aircraft - Electric - Power Systems (FS/W) 0 May 25, 2011 12:19 PM
Wanted ARC 28-58-1 motor keithj-pilot Aircraft - Electric - Power Systems (FS/W) 1 Apr 23, 2011 08:11 AM
Wanted Mega 16/15/3 or equal, will buy or swap ARC 28-47-1.5 GyroRon Aircraft - Electric - Power Systems (FS/W) 6 Dec 15, 2008 11:46 PM
