Old Oct 24, 2011, 10:48 PM
perschek is offline
Find More Posts by perschek
GEEBEE Can't WAIT!
perschek's Avatar
USA, OR, Seaside
Joined Dec 2010
Hobbyking Durafly Slick 360 Micro 3D 490mm (PNF)
Check this puppy out, I'm sure someone has one on here let me know how it is I'm interested in buying it. Have a spare 6100 rx, thinking of making a harness for 2x 200mah mcpx batteries for it. 69.99 + s/h isn't bad at all for a small 2s 3d plane!
A genuine 3D capable Micro? You better believe it! The Durafly Slick 360 has a spec sheet that is hard to beat, 2s power, real servos and a brushless motor put it head and shoulders above the rest!
The lightweight construction of this model, coupled with large control surfaces make it a brilliant 3D micro. Many models of this size are often limited by linear servos or cheap components, but not the slick! featuring pre-installed, fully proportional HK-5320 Digital servos, a Turnigy ESC and an AP05-3000kv brushless motor The build quality is just fantastic. Fully hinged ailerons are another example of why the slick stands out from the crowd. This is a fast model to put together, the motor and ESC are pre-installed, leaving you to glue on the wing and cowl then go and fly!
Performance is of course what 3D models are all about and this Slick is no slouch! Power is delivered courtesy of the powerful Turnigy Brushless motor running on 2s, for reliability a Turnigy ESC is pre-fitted and the servo/ESC connectors are all compatible with the 4 Channel Orange Micro RX (R415). This model might be cheap to put in the air, but make no mistake, this is one seriously capable 3D Micro, just make sure you take a handful of Lipoly batteries with you when you go and fly, hovering this Slick 360 round the basketball court gets addictive!
Specs:
Wingspan: 490mm
Length: 421mm
Flying Weight: 80g
ESC: 6A w/BEC
Servo: HK-5320 Digital 1.7g x 4
Motor: AP05 3000kv Brushless Outrunner
Includes:
Instruction Book
Glue
Requires:
Your Own 4 Channel TX/RX (compatible RX with 1.25mm Molex 3 Pin Connectors)
180mAh 2s Lipoly Battery
perschek is offline Find More Posts by perschek
Old Oct 24, 2011, 10:50 PM
perschek is offline
GEEBEE Can't WAIT!
perschek's Avatar
USA, OR, Seaside
Joined Dec 2010
Micro Slick - HobbyKing Skunkwerks Series (3 min 42 sec)
Old Oct 25, 2011, 02:44 AM
4x4rc is offline
Find More Posts by 4x4rc
Fly, crash, glue. Repeat.
Belgium, Walloon Region, Plombières
Joined Jul 2011
There's already a thread here: http://www.rcgroups.com/forums/showthread.php?t=1524697
4x4rc is offline Find More Posts by 4x4rc
Old Oct 25, 2011, 05:43 AM
RealGambler is offline
Find More Posts by RealGambler
Way to many airplanes!
Canada, QC
Joined Oct 2009
and one that was close in the RTF section because the main thread was somewhere else...
http://www.rcgroups.com/forums/showthread.php?t=1502601
RealGambler is offline Find More Posts by RealGambler
Discussion HobbyKing Dolphin Micro Sport Glider EPO, 555mm (PNF) e_lm_70 Micro Ready-to-Fly 113 Oct 02, 2015 08:48 AM
New Product Hobbyking Extra 260 3D EPO Red (PNF) (USA Warehouse) tallflyer 3D Foamies 747 Sep 12, 2015 12:13 AM
New Product HK DuraFly Micro Slick 360 2S - Official Thread will3d4food Scratchbuilt Indoor and Micro Models 879 Feb 28, 2015 11:14 AM
New Product Hobby King Micro Slick 360 knifeedge63 3D Foamies 6 Oct 24, 2011 08:40 PM
New Product HobbyKing "Micro 3D series" MegaTesla Micro Ready-to-Fly 22 Oct 23, 2011 10:59 AM
