This thread is privately moderated by kdwzagi, who may elect to delete unwanted replies.
Old Oct 24, 2011, 06:50 AM
kdwzagi is offline
Find More Posts by kdwzagi
(madkev :) )
kdwzagi's Avatar
United Kingdom, England, Stafford
Joined Dec 2002
Build Log
Rudder setup
Hi
the rudders have a hole drilled in the bottom edge and a simple L shaped piano wire inserted. this is then joined to the 2mm carbon push rod with a bouble thickness of heat shrink tube. cutting the carbon tube to the correct length is important but the L shaped piano wire can be bent to adjust a slight error
the piano wire will be epoxied into the rudders once the wing top skin is in place
kdwzagi is offline Find More Posts by kdwzagi
Question any one ever made a no rudder dual motor setup ? NoWizkid Scale Boats 5 Oct 10, 2011 04:05 AM
Help! DX8: setting D/R on my rudder now trims the rudder. hackdroot Radios 17 Sep 09, 2011 03:23 PM
Help! elevator/Rudder setup for Stobel V3 airtimeasto Hand Launch 4 Jul 15, 2011 05:06 PM
???Microswitch on/off installation??? Rudder setup without gyro??? jspoz Hand Launch 7 Sep 25, 2003 11:02 PM
Has anyone messed with putting a rudder setup, on a Zagi? slowflyer Foamies (Kits) 2 Oct 15, 2001 03:43 AM
