Old Jun 19, 2012, 02:30 PM
pietronet is offline
Find More Posts by pietronet
France, PACA, Aix-en-Provence
Joined Jul 2011
Hi everyone!
Here is an add on-test, no calibration after a pack change.
Video is shot @ 30fps 1080p on a GoPro HD2 to see the stability.
A few wobbeling, 60fps is definitely better to cancel vibration but it was not too bad!!!
9" props are way better for me!!!
gain is @ 3 on the board according to this picture:
and @ 7.4 in Protool.
The quad is 40cm motors to motors
Cheers.
Quadcopter AQ50 add-on test Onboard and External Camera (3 min 17 sec)
pietronet is offline Find More Posts by pietronet
Old Jun 19, 2012, 03:23 PM
SpeedMaster is offline
Find More Posts by SpeedMaster
UAS Test Pilot
SpeedMaster's Avatar
Norway
Joined Jul 2003
I received my add on sensors today and will test them during this comming weekend, if it stops raining....
SpeedMaster is offline Find More Posts by SpeedMaster
Old Jun 19, 2012, 06:55 PM
catamar is offline
Find More Posts by catamar
Alicante, Espaņa
Joined Jun 2010
Well, if people from AQ50 dont hurry, they will lose the train. With the new naza gps, and the cheap and complete rabbit board with stabilization, sonar, height hold and gps, they have two options, or they hurry up, or people will beging to sell this multicopter controler to buy one of the other.
catamar is offline Find More Posts by catamar
Old Jun 20, 2012, 04:48 AM
lovegroove is offline
Find More Posts by lovegroove
http://drone-pilot.blogspot.fr
lovegroove's Avatar
Rhone Alps, France
Joined Aug 2008
I just got one of these from FPV4Ever and I foolishly thought that it came with the USB adapter. I'm guessing that it's just some sort of FTDI converter, so can anyone tell me if this will work with a standard 5v FTDI converter, and if so, what is the pin-out for the 4 pin connector on the AQ50D?
Cheers,
LG
lovegroove is offline Find More Posts by lovegroove
Old Jun 20, 2012, 04:56 AM
nebstress is offline
Find More Posts by nebstress
Advanced Monkey
nebstress's Avatar
United Kingdom, England
Joined Nov 2011
Cheers,
LG
Have you tried looking in the manual
Description:
I guess it would work, don't see why not.
On the proper TMF adapter there is only RX, TX & GND connected, you have to power the board separately.
nebstress is offline Find More Posts by nebstress
Old Jun 20, 2012, 06:06 AM
saucisse is offline
Find More Posts by saucisse
Don't disturb the pilot !!!
saucisse's Avatar
Canada, QC, Quebec
Joined Jun 2008
Phil, a regular FTDI converter wil work just fine, I'm using the one I've got years ago for a multiwii board that I don't have anymore. Like said previously, just power the board separately if your converter don't supply a 5v to the fc.
saucisse is offline Find More Posts by saucisse
Old Jun 20, 2012, 07:12 AM
lovegroove's Avatar
Rhone Alps, France
Joined Aug 2008
Cheers Seb!
I just need it to do the firmware update because I got the add on sensor. Just this minute got back from flying without connecting it to the computer and just like the original AQ50, it flies great.
As good as all these multiwii thingies are, I just don't have the patience required for PID tuning, give me a couple of gain pots any day.
Really loving these boards and will probably end up equipping all of my copters with them. Just wish they could also do altitude hold, because that's one feature that I think I would use quite a bit.
Old Jun 20, 2012, 07:21 AM
flitelab is offline
Find More Posts by flitelab
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
Cheers Seb!
Altitude hold and GPS are in the works. It is a really great board for getting up and flying quickly with no tuning.
flitelab is offline Find More Posts by flitelab
Site Sponsor
Old Jun 20, 2012, 05:37 PM
catamar is offline
Alicante, Espaņa
Joined Jun 2010
Well, I tried with the add-on sensor today. And I am disapointed, I haven't notice any improvement in the stability and worse than that, the quad is constantly rotating around it's axis. In one direction some times, and some other times in the opposite direction, not fast, but in one fly of 10 minutes it rotates 4-5 times. I have to be correcting all the time the position of the front part. And for some reason the correction is harder now, it looks like the stick do not responds to my orders, it responds late and slow.
Maybe I am doing something wrong. I have updated the firmware. I made the calibration before flying. (in fact I was not calibrating the quad in every flight, today I did it).I tried with stabilixation in 3 and in 5 (acording to the numbers on this page) with same results. I went to fly yesterday without problems. Today I installed the add-on sensor and had begun the problems.
Anybody can help me?
Old Jun 20, 2012, 08:13 PM
mahui625 is offline
Find More Posts by mahui625
Joined Aug 2008
check the FC by proTool.what firmware do you use?
mahui625 is offline Find More Posts by mahui625
Old Jun 20, 2012, 11:30 PM
FitzyKiter is offline
Find More Posts by FitzyKiter
Fitzy
FitzyKiter's Avatar
Gold Coast
Joined Jul 2008
I have the same problem.
Old board was installed on a Quad Frame and was flying very satisfactorily.
Now with the add on sensor and updated firmware it continually yaws left or right while hovering and requires constant correction.
Recalibration does not improve the situation. Have a similar problem with the new board with the inbuilt sensor on a Hex frame that was flying well with the old board.
Hmmmmmmmm !!!!
FitzyKiter is offline Find More Posts by FitzyKiter
Old Jun 21, 2012, 12:44 AM
mahui625 is offline
Joined Aug 2008
Hmmmmmmmm !!!!
decrease the gain in the board,pls try it.
Old Jun 21, 2012, 05:53 AM
Fitzy
FitzyKiter's Avatar
Gold Coast
Joined Jul 2008
Thanks ..... 9 at night here, so will give it a whirl in the morning on both Quad and Hexa.
Cheers - Fitzy
Old Jun 21, 2012, 09:25 AM
catamar is offline
Alicante, Espaņa
Joined Jun 2010
I tried yesterday with the gain at 5 and later with the gain at 3, same results.
What do I do?. Try with gain at 2 and 1?
I am using version 5.6.
Old Jun 21, 2012, 10:03 AM
blast is offline
Find More Posts by blast
Joined Nov 2011
It may help in finding a solution if you also include the AGain setting and distance between motors.
I think it is good practice for everyone to post their multicopter details in every post when describing a problem.
I would suggest always including in each post-
1-Board Version
2-Firmware Version
3-AGain setting
4-Pot Gain setting
5-Distance between motors
6-Discription of problem
It makes it easier to follow the thread and diagnose the problem and we all benefit the faster issues are resolved....
Cheers
blast is offline Find More Posts by blast
Poll What Motors do you use on your tri/quad/hexa/octal etc? bob4432 Multirotor Talk 4 Aug 29, 2010 07:10 PM
Sold MicroKopter ARF Quad/Hexa G-unit Aircraft - Electric - Helis (FS/W) 3 Aug 23, 2010 09:38 AM
Discussion Folding frame for AP - tri, quad, Hexa, Okto danielpetrescu Multirotor Talk 9 May 10, 2010 12:25 AM
Question Tri/hexa-copter or Quad/Octa-copter and Spartan AP2000i or Helicommand Arthur P. VTOLs 2 May 20, 2007 03:02 PM
