Joined Aug 2008
video by QiW
New Mini TMF AQ50D Board - Baro Testflight
Hello all, I think good things need Time. But we are in unexpected excitement for the new NAvi Board.
Here a Test Video from White.
Mike |
United States, TX, Dallas
Joined Jan 2012
I need some help with the new sensor. I have the TMF Pro or AQ50. I downloaded Firmware_Release_0601 from this website. In this order I installed;
1) TMF_Pro_v1.8_2G.tmf (yes, I deleted the Chinese writing at the end of the files) 2) TMF_Digital_v5.6_Add-on.tmf 3) TMF_Digital v5.5_Embeded.tmf No problems installing the updated. Then I opened the TMF_Tool_v121.exe. At the very first I got data from flight controller but no movement in Flight Instrument, then nothing except for gain. Gain showed 5.619, Fmode X4 and Speed 400Hz. It shows Firmware 5.5, Acc (G) 2. In the past, when I did a firmware update and then used the TMF Tool, everything was working and calibrating. Anyone know what I may have done wrong or didn't do? |
Number "2" is for the New AQ50D with the embedded sensor & number "3" is for the AQ50 with the new add on sensor. I hope this helps
Joined Jan 2012
Thank you.
Since I have installed the other software's, how can I delete them? I have searched everywhere for a manual or proper procedures and cannot find anything except on this forum. Since the DS-Sensor works on both AQ50D & AQ50 Pro, there needs to be information on what works on what. I wrote to Infinity-Hobby and they were confused about what I installed. Here is what they said; We are a bit confused by your message. The firmware for AQ50 Pro (TMF Pro) with new sensor should be TMF_AQ50D-S(V5.2).tmf which can be downloaded from the following link : http://www.infinity-hobby.com/main/d...0D-S(V5.2).tmf You will need to upgrade the firmware of TMF Pro first before install the AQ50D-S. We are not sure where you got the firmwares listed in your message and what those 1)~4) meant. Can you advise further detail? |
| Thread Tools | |
| Poll What Motors do you use on your tri/quad/hexa/octal etc? | bob4432 | Multirotor Talk | 4 | Aug 29, 2010 07:10 PM |
| Sold MicroKopter ARF Quad/Hexa | G-unit | Aircraft - Electric - Helis (FS/W) | 3 | Aug 23, 2010 09:38 AM |
| Discussion Folding frame for AP - tri, quad, Hexa, Okto | danielpetrescu | Multirotor Talk | 9 | May 10, 2010 12:25 AM |
| Question Tri/hexa-copter or Quad/Octa-copter and Spartan AP2000i or Helicommand | Arthur P. | VTOLs | 2 | May 20, 2007 03:02 PM |
