Old Jun 05, 2012, 08:22 PM
mahui625 is offline
Find More Posts by mahui625
Joined Aug 2008
Originally Posted by blast View Post
how about this......
cool.right.
mahui625 is offline Find More Posts by mahui625
Old Jun 05, 2012, 08:34 PM
mahui625 is offline
Joined Aug 2008
Originally Posted by nebstress View Post
I have just tried to update mine to 5.5 & I got the same, nothing happened!
this is what I got:Attachment 4916719
I can Flash it to 5.1 with no trouble but it wont flash 5.5
open firmware program
select com port
connect board
open firmware tmf digital 5.5
pressed the reset button on board don't release the hand.
conected 5v
wait for the LED starts blinking then released the button
click the connect and then start to upgrade the firmware.
when the upgarde is complete,power off.
Old Jun 06, 2012, 04:29 AM
nebstress is offline
Find More Posts by nebstress
Advanced Monkey
nebstress's Avatar
United Kingdom, England
Joined Nov 2011
select com port
connect board
conected 5v
I contacted jimmytseng & he replyed "Hi....remove chinese file name and try again "
From .zip:TMF_Digital_v5.5_Embedded(║)
Change to:TMF_Digital_v5.5_Embedded
I did this & all is OK now
Thank you jimmytseng
nebstress is offline Find More Posts by nebstress
Old Jun 06, 2012, 04:46 AM
mahui625 is offline
Joined Aug 2008
good!
Old Jun 06, 2012, 05:21 PM
caju is offline
Find More Posts by caju
caju's Avatar
Joined Jul 2011
select com port
connect board
conected 5v
Hi Maui I did exactly like you said
but my light only goes solid never blinks and nothing happens on the program black screen any sugest?
I have 5.1 with 2g @ the moment
caju is offline Find More Posts by caju
Old Jun 06, 2012, 05:36 PM
Advanced Monkey
nebstress's Avatar
Joined Nov 2011
Firmware Upgrade Procedure
This video shows the correct upgrade procedure:
TMF PRO Firmware Upgrade Procedure (1 min 22 sec)
Old Jun 06, 2012, 06:35 PM
caju is offline
caju's Avatar
Joined Jul 2011
This video shows the correct upgrade procedure:http://youtu.be/6HG_lg90rV4
yep did that all get is a solid light no blinking nothing on screen using windows 7
Old Jun 06, 2012, 06:52 PM
Advanced Monkey
nebstress's Avatar
Joined Nov 2011
I take it you have the New AQ50D & your trying to update to FW 5.5?
Have you deleted the characters at the end of the FW file?
ie, Changed it from:- TMF_Digital_v5.5_Embedded(║)
To:- TMF_Digital_v5.5_Embedded
That worked for me!
Are you sure your connecting to the right COM port?
To check COM port go to start button, type "Device Manager" into search box & click on it when it appears, make sure TMF data link is connected to PC then go to Device Manager & look for "Ports (COM & LPT)" there you should see different com ports, if more than one remove TMF data link & then replace to check for correct COM port.
Old Jun 06, 2012, 06:57 PM
caju is offline
caju's Avatar
Joined Jul 2011
just notice as soon as plug the board the blue light comes on and on the video does not....
Any help?
Old Jun 06, 2012, 07:02 PM
Advanced Monkey
nebstress's Avatar
Joined Nov 2011
Any help?
Are you holding down the button when you connect power to board?
Old Jun 06, 2012, 07:59 PM
mahui625 is offline
Joined Aug 2008
TMF mini FC with MS-5611 barometer module - Altitude hold testing (prototype)
TMF mini FC with MS-5611 barometer module - Altitude hold testing (prototype) (1 min 53 sec)
Old Jun 06, 2012, 08:52 PM
caju is offline
caju's Avatar
Joined Jul 2011
yes.
Old Jun 06, 2012, 09:00 PM
caju is offline
caju's Avatar
Joined Jul 2011
That worked for me!
all com checked as is the same i use for the tools 1.2 for the board
toke all the crazy letters out renamed as above.
Does your board lits when plugged to the tmf datalink?
As soon as I plug mine it shows solid blue light in 2 secs, then when press the flash button goes off put the power on the 10 servo place and light goes on solid again release the flash button and nothing.
Tried leting the flash button go before the light comes on again nothing
Old Jun 06, 2012, 09:50 PM
blast is offline
Find More Posts by blast
Joined Nov 2011
Will the MS-5611 barometer module work with the full size AQ50D?
blast is offline Find More Posts by blast
Old Jun 06, 2012, 10:58 PM
mahui625 is offline
Joined Aug 2008
only to test the sensor.tks!
Poll What Motors do you use on your tri/quad/hexa/octal etc? bob4432 Multirotor Talk 4 Aug 29, 2010 07:10 PM
Sold MicroKopter ARF Quad/Hexa G-unit Aircraft - Electric - Helis (FS/W) 3 Aug 23, 2010 09:38 AM
Discussion Folding frame for AP - tri, quad, Hexa, Okto danielpetrescu Multirotor Talk 9 May 10, 2010 12:25 AM
Question Tri/hexa-copter or Quad/Octa-copter and Spartan AP2000i or Helicommand Arthur P. VTOLs 2 May 20, 2007 03:02 PM
