Old Jun 05, 2012, 11:10 AM
nebstress is offline
Find More Posts by nebstress
Advanced Monkey
nebstress's Avatar
United Kingdom, England
Joined Nov 2011
Originally Posted by thepelell View Post
i have found the PC calibration to be quite useless, so i don't bother with it. always calibrate with radio before every flight.
For what concerns your flips on take off, you do seem to have quite high levels of Again and pot gain. Try going to 7 on again and pot at 9 o'clock position and see what happens. You should still have a quite stable craft , but should be less sensitive to vibration. Maybe there is a certain rpm or ground resonance or whatever that on takeoff will disturb accels too much and make it want to flip. I have had a flip on takeoff only the very first time i tried it on my X8.
Thank you thepelell, I will try as you suggest it might well be as you say a certain rpm or ground resonance, it has happened at the end of a pack as well as at the beginning but its strange Most 98% of the time it is perfect & fly's better & more stable than any other FC I have.
My pot gain is already very low as you can see in photo.
Name: POT SETTING.jpg
Description:
Probably a stupid question but you say 9 o'clock so where would 12 o'clock be? do you mean 50% or middle?
I calibrate once before I go out for a flight & that is all that's needed, I went through 5 packs last night when I was out & then 2 more when I got home with no issues. The whole reason I bought the AQ50D & not the AQ50 Pro was so that I wouldn't have to re-calibrate after changing every battery.
nebstress is offline Find More Posts by nebstress
Old Jun 05, 2012, 11:24 AM
thepelell is offline
Find More Posts by thepelell
Italia, Piemonte, Biella
Joined Feb 2011
Attachment 4916010
as always a pic is worth a thousand words... yes your gain is very low already, that for me is 12 o'clock. I wrongly thought you had it the opposite, at 6 o'clock. Unless you have some really bad motors or unbalanced props you should be able to up the gain.
thepelell is offline Find More Posts by thepelell
Old Jun 05, 2012, 11:37 AM
Advanced Monkey
nebstress's Avatar
Joined Nov 2011
Ah, thank you I wasn't sure how to explain the Pot positions but now that makes sense.
I will try lowering the AGain in the GUI & raising the Pot gain.
I use Keda 20-26 & 20-28 (not together, 20-26 on one Quad & 20-28 on another) not the best motors but I like them especially the price
I balance my propellers carefully & check the motors for balance as well as checking for vibration in general.
I have noticed that the AQ50D is very sensitive to Vibration, more so than other FC's I've owned.
Old Jun 05, 2012, 12:18 PM
Mix57 is offline
Find More Posts by Mix57
Joined Jan 2009
So is there a place in which i can order the add-on ???
Mix57 is offline Find More Posts by Mix57
Old Jun 05, 2012, 12:39 PM
pietronet is offline
Find More Posts by pietronet
France, PACA, Aix-en-Provence
Joined Jul 2011
Hi nebstress and thepelell, helpful discussion!!!
How do you balance your kedas btw? ... I have the 20-28 too.
Your props are from Flyduino too (they look like actually)? For me they don't need any tweaking but
for sure I do it not the right way....
Thx
pietronet is offline Find More Posts by pietronet
Old Jun 05, 2012, 12:51 PM
Advanced Monkey
nebstress's Avatar
Joined Nov 2011
Thx
The same as you balance any motor, if you have Keda 20-28 you should know that they are very well balanced.
My Props are from Quadframes.co.uk
Any & all propellers for Multicopters need balancing!
Old Jun 05, 2012, 12:56 PM
Joined Jul 2011
They seem balanced but I am not an expert in balancing... so that's why I am asking.
I'll try to blance my props then
Thx
Old Jun 05, 2012, 01:02 PM
Advanced Monkey
nebstress's Avatar
Joined Nov 2011
Thx
Balancing propellers is very important especially on multicopters.
I think maybe I have only ever had one prop that didn't need balancing to some extent.
If you run a motor with the prop off you can sometimes see & definitely feel if its unbalance, there will be extra vibration.
I have been lucky mostly with my motors being balanced, there are several ways to balance a motor usually by adding weight to a particular spot, using a 'zip tie' is an easy way to do it.
Old Jun 05, 2012, 03:33 PM
blast is offline
Find More Posts by blast
Joined Nov 2011
I've added numbers the the pot in these images as a reference to help clarify calibration discussions, 0 being the lowest full clockwise setting and 10 being the highest full counterclockwise setting...
blast is offline Find More Posts by blast
Old Jun 05, 2012, 03:40 PM
Advanced Monkey
nebstress's Avatar
Joined Nov 2011
Thats a great idea
Old Jun 05, 2012, 03:44 PM
blast is offline
Joined Nov 2011
Thats a great idea
I can see the numbers fine but looks like the resolution is to low to be of any use online...oh well
Old Jun 05, 2012, 03:54 PM
blast is offline
Joined Nov 2011
how about this......
Old Jun 05, 2012, 03:56 PM
Joined Jul 2011
Better!
Thx
Old Jun 05, 2012, 04:45 PM
caju is offline
Find More Posts by caju
caju's Avatar
Joined Jul 2011
Hi just got my new aqd50d embebed and was trying to update but nothing happens.
This is how I tried:
open firmware program
connect board
open firmware tmf digital 5.5
pressed the reset button on board
conected 5v
released button
and nothing
Could someone help me out
Also should I upgrade to tmp pro1.8 6g
Thanks for any input
caju is offline Find More Posts by caju
Old Jun 05, 2012, 05:36 PM
Advanced Monkey
nebstress's Avatar
Joined Nov 2011
connect board
conected 5v
released button
and nothing
I have just tried to update mine to 5.5 & I got the same, nothing happened!
this is what I got:Name: TMF GUI 5.5 Embeddeed.jpg
Description:
I can Flash it to 5.1 with no trouble but it wont flash 5.5
Poll What Motors do you use on your tri/quad/hexa/octal etc? bob4432 Multirotor Talk 4 Aug 29, 2010 07:10 PM
Sold MicroKopter ARF Quad/Hexa G-unit Aircraft - Electric - Helis (FS/W) 3 Aug 23, 2010 09:38 AM
Discussion Folding frame for AP - tri, quad, Hexa, Okto danielpetrescu Multirotor Talk 9 May 10, 2010 12:25 AM
Question Tri/hexa-copter or Quad/Octa-copter and Spartan AP2000i or Helicommand Arthur P. VTOLs 2 May 20, 2007 03:02 PM
