Old Mar 19, 2012, 08:57 PM
mahui625 is offline
Find More Posts by mahui625
Joined Aug 2008
Originally Posted by chancesAU View Post
Cool!
I've made the camera mount a little better and wound the gain back a little, next videos should be much more ... exciting ??
hi,what video TX do you use?tks!
mahui625 is offline Find More Posts by mahui625
Old Mar 19, 2012, 10:24 PM
chancesAU is offline
Find More Posts by chancesAU
chancesAU's Avatar
Australia
Joined Apr 2008
Its a Lawmate 2.4ghz 500mw VTX running off its own BEC, camera is 12v 540TVL from securitycam2000, both the BEC and camera run off a separate 360mah 3cell Lipo.
chancesAU is offline Find More Posts by chancesAU
Old Mar 20, 2012, 10:51 AM
Rc Heli Halle is offline
Find More Posts by Rc Heli Halle
Rc Heli Halle's Avatar
Berlin / Germany
Joined Feb 2010
My T580 Frame reborn as AQ580Pro
Hi all , yes my T580 is History. I throw the Lotus Rc FC and the I2C Escs out.
Now have Implanted the AQ50Pro with the 1.2v . Escs from Turbo Jet 30A, Motors from Lotus Rc 650Kv , 11x4,5" Props from Flyduino.net, Landing Gear original Lotus.
Very Windy, nearly too much for this slow Motors and 11" Props. But will be a perfect Hover and Cam Quadro, before I hover around with a 2200mah Lipo - 24minutes. Complete Weight is 1125 Gramm - inc. Lipo !!
AQ580Pro TestFlight 2 (4 min 3 sec)
Between Lower Shell and Dome i put Spacer, around in Space i make a black Plastik Ring, So is now inside enough Room for the New TMF NAVI Board, for the AQ50Pro. Inside the Dome it comes self-adhesive copper foil , for better and More GPS Sattelites reception.
On Top then the GPS Receiver. ASAP Right Mahui ?
Now the Onboard Video , made with my VGA Spy Cam. RAW Video. You can see nicly the hard countermeasures from the AQ50Pro Fc at this Windy Day between to Houses.
Onboard AQ580Pro Video Test Flight 2 (12 min 21 sec)
NO Cam Gimbal and SD Card is a slow one, this is why Ticking in Video sometimes.
Mike RCHHB
Rc Heli Halle is offline Find More Posts by Rc Heli Halle
Old Mar 20, 2012, 10:57 AM
pietronet is offline
Find More Posts by pietronet
France, PACA, Aix-en-Provence
Joined Jul 2011
WOW! 24 minutes??!
pietronet is offline Find More Posts by pietronet
Old Mar 20, 2012, 11:15 AM
Berlin / Germany
Joined Feb 2010
Hi pietronet, yes . Last Year when I get the T580 from Lotus Rc I do Testing. The same as Today. Only a other Fc. I think now Props are 11" as last Year 12" and some Plastik Spacing and 4 normal escs , Weight was 950gramm or so, Flight Time now ? it will be less but in any Case more than 15min. Will try next 12" and do testing Indoor Hovering. These Motors from Lotus Rc are Great . Today it was too windy. The Motors can not react so fast the AQ FC send control Commands.
Mike RCHHB
Old Mar 20, 2012, 08:13 PM
mahui625 is offline
Joined Aug 2008
Mike RCHHB
flight time:24min.cool.
Old Mar 21, 2012, 08:44 AM
Berlin / Germany
Joined Feb 2010
Another Flight Test Day
Hi all, today the same heavy Wind as yesterday. I was not so happy with the sensitivity of the Motors, when it was windy , somtimes hard to fly and near a keel over when the Wind throw my AQ580pro around. Also the Yaw was bad. Upps, found lose screws at Motor mounts. Fixed. But It looked as if the ESCS were behind with the control signals. But I adjust the Gain Poti today , on FC-Board a little more UP , CCW. Then it was better. First ( Yesterday ) it wobble when lift off. I screw it down ( CW ) , the senitivity then was first too low. The Wind Bounce my Quad. It is Tricky to adjust when Slow Motors and Big Props. But now better. Also is my Quad Motor to Motor 580mm. Slow Motors and Big Props will need more fine adjust.
My RX/TX is a super simple Esky 6CH - Settings are Ail=REV , ELE= Nor , THR= Nor , RUD = Nor.
When I found a Indoor Place , will Test the Max Flight Time.
Video RAW ! No Cam Stabi , no Gimbal, Cam Casio exilim Z100, mount on Top with Cam Screw and BLUE-TAck between .
I can see no Vibration, and you? Sorry No money for HD cam.
AQ580Pro Test Flight 3 (0 min 50 sec)
Mike RCHHB
Old Mar 21, 2012, 03:58 PM
McDodo is offline
Find More Posts by McDodo
Joined Nov 2009
Hi Orphee,
are you using the default DJI 30A OPTO ESCs? Did you try it indoor or by no wind, too? Would you propose the F450 + AQ50DPro combo for a beginner?
McDodo is offline Find More Posts by McDodo
Old Mar 22, 2012, 01:40 PM
Berlin / Germany
Joined Feb 2010
No Wind , next Flight
Hi all, a firend send me his Aq50pro. For Testing out the Fc.He had his problems with ESCS. The escs always beeping continuously. But the AQ50pro Fc is 100% right. Now it can only be a Failure at the ESCS.
Watch out at 2:50min , what hard fast control commands with NIck and Roll.
Incredibly fast reactions to the FC. Clean Piece of Art. Good.
AQ580pro-TestFlight5 (3 min 43 sec)
Mike RCHHB
Old Mar 22, 2012, 07:24 PM
r0sewhite is offline
Find More Posts by r0sewhite
It wasn't me
r0sewhite's Avatar
Augsburg, Germany
Joined Mar 2010
It's not a failure, it's only a mismatch of the PWM signal. Most likely the output from the AQ50d is higher than what the ESC detects as idle. What you can try is calibrate the ESCs with a lower throttle curve low value.
I would call it rather normal. Most flight controls have a PWM output of 380 to 400 Hz. Sensor readings are even faster, between 100 and 400 KHz so I don't think that anyone can "see" if a FC works faster or not. You could gain the same result with MK, MultiWii or DJI.
r0sewhite is offline Find More Posts by r0sewhite
Old Mar 22, 2012, 08:11 PM
mahui625 is offline
Joined Aug 2008
ESC,hobbywing funfly is good.
Old Mar 23, 2012, 06:07 AM
Berlin / Germany
Joined Feb 2010
My Esc, My Lipo Warner
Hi all, Hi Mahui,
I use the TURBOJET 30A Esc, http://www.ebay.de/itm/TURBOJET-RC-3...-/150601123377
And only 8.29 € incl. Shipping. Tested - Works nice. It is a Super Simple Esc.
Leave Lipo cut off is a 2,9 volt per cell, Break enabled. For Safety I use Lipo Warner -Made in Germany - for 3S Lipo, w. Power led,1 flash at 4.2 volt , 2 Flash at 10.8 volt , 3 Flash at 10.2 volt ( NOW LANDING !! ) , 4 Flash at 9.9 volt ALARM , Works good. Buy at--->
[URL="http://lipoblitzer.de/"]http://lipoblitzer.de/
Mike RCHHB
Old Mar 23, 2012, 03:07 PM
Berlin / Germany
Joined Feb 2010
Some Parflying today
Park Flying AQ50pro -T580 Frame (7 min 53 sec)
Mike RCHHB
Old Mar 24, 2012, 01:57 PM
Berlin / Germany
Joined Feb 2010
Next Flight - HD Cam and 180 Lens
Hi all,
now my Rollei P3 on Top and Lift off.
AQ50Pro Testflight No.8 (3 min 30 sec)
But again Problems with Sun backlighting. And I dont no why not Upload in HD ?
I checked - Cam was set to 640 x ?? . My Error. DAMN !
Tomorrow ..........Better.
Mike RCHHB
Old Mar 24, 2012, 06:43 PM
Joined Jul 2011
Hi everyone,
Here is this morning flight:
Sunny Day in Provence Quadcopter + Bonus Crash. (10 min 25 sec)
Still some left drift and still no gopro ...
Pierre
Poll What Motors do you use on your tri/quad/hexa/octal etc? bob4432 Multirotor Talk 4 Aug 29, 2010 07:10 PM
Sold MicroKopter ARF Quad/Hexa G-unit Aircraft - Electric - Helis (FS/W) 3 Aug 23, 2010 09:38 AM
Discussion Folding frame for AP - tri, quad, Hexa, Okto danielpetrescu Multirotor Talk 9 May 10, 2010 12:25 AM
Question Tri/hexa-copter or Quad/Octa-copter and Spartan AP2000i or Helicommand Arthur P. VTOLs 2 May 20, 2007 03:02 PM
