Old Dec 24, 2011, 09:24 AM
Rc Heli Halle is offline
Find More Posts by Rc Heli Halle
Rc Heli Halle's Avatar
Berlin / Germany
Joined Feb 2010
Merry X-Mas
Rc Heli Halle is offline Find More Posts by Rc Heli Halle
Old Dec 24, 2011, 09:57 AM
apejovic is offline
Find More Posts by apejovic
Spain, CN
Joined Dec 2011
Originally Posted by mahui625 View Post
test for Propeller failure.
Mahui, Im starting a new Build, need to carry a Canon 5d, initially I was going for a Hexa, but watching your video I think your Octo has definitely a much better redundancy. Could you please post your setup, motors, motor to motor distance, props, etc.
apejovic is offline Find More Posts by apejovic
Old Dec 24, 2011, 11:04 AM
Wayno Complaino is offline
Find More Posts by Wayno Complaino
Fixed wings can be Drones too!
Wayno Complaino's Avatar
United Kingdom, England, Milton Keynes
Joined Aug 2011
Originally Posted by guyg View Post
Wayno Complaino
Well done
i love when all components are fixed and wired properly!!
If it looks good- it will fly good!!
I have a new quad too that looks - nice.
Let me know how is the trimming of every flight on this bird
And how is the ACC arm - up left on the bird
Trimming- every power off - is one of the "problems" on this board
Let me know...
Tx
Guy
I've run through three packs but it is very windy so I wouldn't like to comment too much on how it flies, trims and such. That said in moments between gusts it is very stable and doesn't need any trims as long as I've calibrated the accelerometers (every batter still). It does seem to yaw right slowly though and if I give it a load I throttle it pitches forward. Again, it's bloody windy and a very unfair test.
Also tidied it up even more, black insulating tape over the motor wires taping them to the booms, you can hardly see they are there on the black booms.
It's got masses of power an hovers at about 35% throttle, takes off like a rocket if you give it some beans! 7A at hover maxed at 38A, perfect for the set up.
Wayno Complaino is offline Find More Posts by Wayno Complaino
Old Dec 24, 2011, 11:16 AM
Alwayscrash is offline
Find More Posts by Alwayscrash
"you'll play to live "
Alwayscrash's Avatar
Canada, QC, Montreal
Joined Sep 2009
Let it snow
Test flight my XA /AQ50D PRO/GOPRO r5 mode
http://www.megavideo.com/?v=54PLW909
AC
Alwayscrash is offline Find More Posts by Alwayscrash
Old Dec 24, 2011, 11:23 AM
flitelab is offline
Find More Posts by flitelab
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
Nice video (once I got by all the popups). Good to see we aren't the only ones with snow :P
Sounds like you may have a bad/noisey motor.
flitelab is offline Find More Posts by flitelab
Site Sponsor
Old Dec 24, 2011, 11:33 AM
Joined Sep 2009
Thanks flitelab
I'm using 3506 MT-motor and it does have this kind of noise with high timing an smooth when in low .
AC
Old Dec 25, 2011, 04:16 AM
madmarten is offline
Find More Posts by madmarten
Joined Nov 2011
Hi, I got mine mounted on a hex yesterday. Today when I'm trying it outdoors it always wants to spin in either direction. I try to use trim to find a sweet spot, but then suddenly it spins in another direction. I try to trim again and again, but it spins so fast once up in the air and it's impossible to fly like that. The other leveling seems to be fine. It's just that it spins around it's own axle and it's impossible to trim away.
What could this be?
madmarten is offline Find More Posts by madmarten
Old Dec 25, 2011, 08:27 AM
QiW is offline
QiW
Find More Posts by QiW
QiW
south east asia
Joined Mar 2009
i think my aq50d just tried to flip on me again an hour ago
i armed the FC and it immediately jumped up about 4-5inches and landed
throttle was at ZERO ...
i have somewhat lost confidence in the aq50d with the 5.8ghz fpv system ...
i was previously running the same 5.8ghz fpv system on a KK board without any problems
i may try the aq50d with a 1.2ghz fpv setup when i have the chance and time
flying without turning on the 5.8fpv system was trouble free
the auto leveling is not consistent though ... even after hardware mod and firmware upgrade
QiW is offline Find More Posts by QiW
Old Dec 25, 2011, 09:09 AM
Joined Sep 2009
What could this be?
check carefully all blades direction with proper turning sens.
AC
Old Dec 25, 2011, 10:16 AM
Joined Nov 2011
AC
Thank you, Alwayscrash. I did recheck the turning direction and I had them all one step wrong with CW vs CCW. I thought I had double checked that before, but obviously not. Now it's to windy outside, but I can see it looks much better now. Thanks!
Old Dec 25, 2011, 07:25 PM
mahui625 is offline
Find More Posts by mahui625
Joined Aug 2008
六軸空拍1080P+阿狼雲台+陣風 (3 min 51 sec)
mahui625 is offline Find More Posts by mahui625
Old Dec 25, 2011, 07:38 PM
mahui625 is offline
Joined Aug 2008
pls refer to the above configuration. www.droidworx.com.au/DW%20apps%20and%20setup.pdf.Scorpion 3014 830KV, apc 1260e, esc 40a,4s 10000mah 15c.hexa.total:4.5kg.
Old Dec 25, 2011, 11:12 PM
quaddynamics is offline
Find More Posts by quaddynamics
Joined Mar 2010
IT seems to have a Gps position hold capability .. it stays in same place even tilted to an angle (roll) ,compensating the wind ... is it so ?
quaddynamics is offline Find More Posts by quaddynamics
Old Dec 25, 2011, 11:58 PM
saucisse is offline
Find More Posts by saucisse
Don't disturb the pilot !!!
saucisse's Avatar
Canada, QC, Quebec
Joined Jun 2008
To me it only looks like the cam is on a camera gimball and using the cam stab of the fc.
saucisse is offline Find More Posts by saucisse
Old Dec 26, 2011, 06:40 AM
Joined Mar 2010
Obviously it has gimbal , the gimbal will work when the frame is tilted .. if the frame is tilted then frame should move .. but it stays in same place ,this will happen only when you oppose the wind .. and it does .. thats why i raised
Poll What Motors do you use on your tri/quad/hexa/octal etc? bob4432 Multirotor Talk 4 Aug 29, 2010 07:10 PM
Sold MicroKopter ARF Quad/Hexa G-unit Aircraft - Electric - Helis (FS/W) 3 Aug 23, 2010 09:38 AM
Discussion Folding frame for AP - tri, quad, Hexa, Okto danielpetrescu Multirotor Talk 9 May 10, 2010 12:25 AM
Question Tri/hexa-copter or Quad/Octa-copter and Spartan AP2000i or Helicommand Arthur P. VTOLs 2 May 20, 2007 03:02 PM
