Old Dec 17, 2011, 06:14 PM
SpeedMaster is offline
Find More Posts by SpeedMaster
UAS Test Pilot
SpeedMaster's Avatar
Norway
Joined Jul 2003
What pwm update frequency are you guys running for standard Plush ESC`s (running them as they come from HK, without reflashing firmware..)
SpeedMaster is offline Find More Posts by SpeedMaster
Old Dec 20, 2011, 07:04 AM
warthox is offline
Find More Posts by warthox
Joined Aug 2009
tmf aq50d pro // onboard (3 min 5 sec)
warthox is offline Find More Posts by warthox
Old Dec 20, 2011, 08:51 AM
Wayno Complaino is offline
Find More Posts by Wayno Complaino
Fixed wings can be Drones too!
Wayno Complaino's Avatar
United Kingdom, England, Milton Keynes
Joined Aug 2011
Originally Posted by warthox View Post
Wow, so stable. I know there's no wind but still.
Can't wait for all the parts to arrive to build my TMF PRO into a quad. Gonna be Warthox style too, Flyduino quad, 20-50 hackers, 10a esc's and 8" props. Shame my flying won't be ANYTHING like yours Warthox.
Wayno Complaino is offline Find More Posts by Wayno Complaino
Old Dec 20, 2011, 09:54 AM
samwei1950 is offline
Find More Posts by samwei1950
DIY Mania from Taiwan
Taiwan
Joined Aug 2011
This is the micro quad with TMF PRO on board from a local pilot.
3000kv motor,10A ESC,7.4V 400Mah batt and 2mm FRP frame.
the lenth of the quad is 14cm
Cheers
Sam
MVI_0357.avi (0 min 45 sec)
20111218_bc9981cb841be50117abS0NTE7HqdJBN
samwei1950 is offline Find More Posts by samwei1950
Old Dec 20, 2011, 03:49 PM
Joined Aug 2011
Errrr, just noticed infinity hobby say the pc app is win 7 only, is this correct?
I'm a mac guy and just spent ages getting an old xp laptop working for this...
Never mind, it installed fine.
Old Dec 20, 2011, 10:20 PM
jimmytseng is offline
Find More Posts by jimmytseng
Joined May 2011
XP is ok....
jimmytseng is offline Find More Posts by jimmytseng
Old Dec 21, 2011, 04:56 PM
Rc Heli Halle is offline
Find More Posts by Rc Heli Halle
Rc Heli Halle's Avatar
Berlin / Germany
Joined Feb 2010
RCHHB Test - TMF AQ50 Pro
Hi all ,
and a very Special Thank you to mahui and Fpv4ever Fabien.
I now a big delay in my Test the AQ50 pro. But now is the Time. Nothing is more Important than my New Job since first Dec. this is money, all other only Hobby.
I build now a Motor to Motor 60cm Frame, a Quadro in + Mode , made from 14mm Square Alu Tubing from Local DIY Store - Bauhaus.
Two round 145 mm Airplane Plywood 5mm -6 Layers - Sprayed Black, custom made Centerplates CNC in my RCHHB Workshop, all fixed togehter with 3mm Screws and self-locking nuts, all Motor Lines inside the Tubing, Cabels to Motors Silikon , Landing Gear from T-rex 700, Motors HK
Turnigy D3536/6 1250KV Brushless Outrunner Motor with lots of Power 500Watt ,
, Esc 30 Ampere -max 40A Bec 3A, Props 1045. Lipo 3S 35C Turnigy, All escs solder to a Power Battery ESC Connection Board from Goodluckbuy.
Weight all, incl. Lipo ---- 1300 gramm
No Firmware Update now.
When all was together, I put the Fc and a 6CH Esky RX on Double Side Foam Glue Tape on an extra Plastik Centerplate. Stick all Cables in.
Then Calibration the ACC and...........
First Flight today at 23:15 min in Dark. But the front and rear Leds shine bright enough. Leds also solderd to the esc Board. -----------Starting Motors works fine.
First thinking was --- Ups !! they turn fast at Idle....But is Ok. At the Gain Pot I do nothing yet. Speed up Motors ...Lift to 2-3meters.... Nice Flying.....some trimming at my Cheap super simple esky 6ch and Ok.
I fly only one Lipo tonighte. I fly around in all directions, fast foreward and back, very fast reset of position. I Like that thing from Lift up. More and Video tomorrow. Here for now some pics.
This is a real RTF FC, nothing to programm. Great.+++++
Rc Heli Halle is offline Find More Posts by Rc Heli Halle
Old Dec 21, 2011, 06:24 PM
mahui625 is offline
Find More Posts by mahui625
Joined Aug 2008
Originally Posted by Rc Heli Halle View Post
Hi all ,
mahui625 is offline Find More Posts by mahui625
Old Dec 21, 2011, 06:27 PM
flitelab is offline
Find More Posts by flitelab
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
Hi all ,
They area very stable and super simple board for sure. Just waiting on more from mahui now. I moved my current one over to my 330X frame, just had the dial the gain back a bit and it works great so far.
flitelab is offline Find More Posts by flitelab
Site Sponsor
Old Dec 22, 2011, 03:48 AM
Berlin / Germany
Joined Feb 2010
Questions...........
Hi all, today Night first flight. only one Lipo. Now Question. When start the Motors and let run at Idle, I wonder how fast they spin. I think a little speed down at Idle where better. Is any Solution for speed down Motors at Iddle ?
Sincerly Mike
Old Dec 22, 2011, 05:34 AM
QiW is offline
QiW
Find More Posts by QiW
QiW
south east asia
Joined Mar 2009
hi guys
i have done the hardware mod to the aq50d .. ie. remove R21 and short R19
installed new firmware 1.2 into FC
calibrated the FC leveling via PRO TOOL on the PC
1st flight/battery .. ok good ... almost perfectly level
2nd flight/battery .. leveling was off quite significantly ie. the quad drifted rather fast
so i calibrated using radio ... took off (still on 2nd battery) .. levels out good now
3rd flight/battery ... leveling was off again ... drifting rather fast
i thought no more calibration was required with each fresh battery after the hardware mod ?
yes ... it feels stabler than with firmware 1.0 without the hardware mod
QiW is offline Find More Posts by QiW
Old Dec 22, 2011, 05:40 AM
Joined Aug 2011
So some people have the new firmware and hardware mod but some are just using the new firmware without the hardware mod.
Is there a final say on the hardware mod, if it IS NEEDED and what it does.
I've upgraded the firmware but awaiting a new frame before I can fly it.
Old Dec 22, 2011, 06:31 AM
Mix57 is offline
Find More Posts by Mix57
Joined Jan 2009
Some pics of my quad with the AQ50D pro
Video soon..
Mix57 is offline Find More Posts by Mix57
Old Dec 22, 2011, 08:00 AM
Berlin / Germany
Joined Feb 2010
Solution - Question ......Flip in morning ???
Hi all, down my Questions are fixed. Made a Call to Heidekultur, see Posts before from me, he flys aq50pro before us all. So interesting Call. Different RX/TX - you need to handle Calibration ACC different.
If you cant go calibration the normal way. Gas up and Yaw left - Easy try this - go with Gas Trimming up, step by step, between try to Calibrate the normal way. At my Esky I have to push he trimming at Throttle up near to the Middle Point. This works perfect. Now I can Calibrate the ACC.
And my Quad was flip in morning. Lucky that this not happens in Night at first flight. --- If you go from inside to outside, let minimum 15 min Time for the FC to used to the Temp. Then calibrate the ACC.
Problem solved !!! Thanks Carsten ,
Hi all, like Warhox write ---------- stick centering with the button on board.---
Did the blue Led than Flash or blinking ? Mine not, see nothing ??
How at yours. Also when Throttle up and Yaw to right / try also Left , for ACC calibration , nothing happens. The Led no Flashing ? What could be wrong ?
Please Post her in your Start Procedure please.
Old Dec 22, 2011, 09:00 AM
thepelell is offline
Find More Posts by thepelell
Italia, Piemonte, Biella
Joined Feb 2011
Wayno , i had some rather strange reactions with firmware update only, it was flying worse than with 1.0; so i did hardware mod and now it is good.
I have my gain at 8 o'clock position and feel i can still go up without any traces of wobble, and it is so nice to be able to come down quickly on vertical descent..
thepelell is offline Find More Posts by thepelell
Poll What Motors do you use on your tri/quad/hexa/octal etc? bob4432 Multirotor Talk 4 Aug 29, 2010 07:10 PM
Sold MicroKopter ARF Quad/Hexa G-unit Aircraft - Electric - Helis (FS/W) 3 Aug 23, 2010 09:38 AM
Discussion Folding frame for AP - tri, quad, Hexa, Okto danielpetrescu Multirotor Talk 9 May 10, 2010 12:25 AM
Question Tri/hexa-copter or Quad/Octa-copter and Spartan AP2000i or Helicommand Arthur P. VTOLs 2 May 20, 2007 03:02 PM
