Old Dec 15, 2011, 07:17 PM
Joined May 2011
Originally Posted by wolfgangm View Post
The manual seems to be more than spartanic, I hope the manual will also get a lot of updates...
My question: what is the function of the "RC transmitter calibration" button?
Wolfgang
Hi~
"RC transmitter calibration button" will remeber your transmitter joystick neutral point for 0 deg attitude command.(because different transmitter have a different PWM in neutral point)
jimmytseng is offline Find More Posts by jimmytseng
Old Dec 15, 2011, 07:50 PM
QiW
south east asia
Joined Mar 2009
a.k.a. STICK CENTERING ... ok
QiW is offline Find More Posts by QiW
Old Dec 16, 2011, 03:56 AM
Italia, Piemonte, Biella
Joined Feb 2011
where can i find 1.1 firmware ?
i tried to remove the smd resistor in order to have 1.2 working good, but removing a smd component with a normal soldering iron is quite difficult. I didn't want to burn something so i chickened out after a couple of attemps.. last time i worked with smd stuff was in 1991 with a proper hot air soldering station....
so until i can find someone to remove the resistor, i'd like to go back to 1.1, but can't find it.. only have 1.0 and 1.2 available as download...
thepelell is offline Find More Posts by thepelell
Old Dec 16, 2011, 04:11 AM
Joined May 2011
hi~only have FW 1.0 & FW 1.2
Old Dec 16, 2011, 04:39 AM
Joined Feb 2011
never mind.. took a couple of courage pills and tried again with soldering iron, this time i had success. Updated to 1.2 again, but now it is raining, so no tests for the moment....
Old Dec 16, 2011, 04:57 AM
Registerer Used
milouze's Avatar
Paris
Joined May 2010
Hi,
This is a quick vid with a cool small hexa from www.cyberdrones.com , and the AQ50D pro on board. Stock settings, still not upgraded, but flies great
Setup:
-Scorpio hexa frame,
-AQ50D pro,
-Turnigy plush 10A,
-robbe roxxy 2216/25,
-GWS tri-bladed 5"3 props,
-2200mAh lipo.
I'm happily surprised of the stability the AQ50D provides; also, as you can see, the frame is not a "circular hexa", but is more like a "V" shaped hexa. So the FC deals with that without any problem for my pleasure.
Here's the vid, not as impressive as Warthox (), emm.. not yet lol!
http://vimeo.com/33585045
Pass: scorpio
Soon, I'll certainly make the hardware modification, because as I have read, calibrating accs each fresh lipo (which is annoying, by the way) would not be any longer needed.
Another thing I feel is missing, is the ability to choose a flight mode without auto-level, that could be useful (or fun!)
Cheers
milouze is offline Find More Posts by milouze
Old Dec 17, 2011, 01:58 AM
Nîmes - France
Joined Nov 2010
Hi,
Another little vid with a spider frame type MM6 design french by Andréas and sold by FPV4EVER .
http://www.fpv4ever.com/lang-en/fram...-type-mm6.html
Setup:
AQ50PRO
Keda 2050S
ESC 10A Hobbywing
GAUI 8" props
3S 2200mA 30C
Spider MM6 FPV4EVER et AQ50PRO - 1er vol (4 min 51 sec)
Il love it
olivier30900 is offline Find More Posts by olivier30900
Old Dec 17, 2011, 05:23 AM
Dirty Dozen FPV
Wayno Complaino's Avatar
United Kingdom, England, Milton Keynes
Joined Aug 2011
It seems off centre placement of the TMF Pro or non symmetrical layout of the props don't affect it's stability or handling. This is turning out to be a great little board.
Wayno Complaino is offline Find More Posts by Wayno Complaino
Old Dec 17, 2011, 06:10 AM
(My english is Bad - Sorry)
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Originally Posted by olivier30900 View Post
Hi,
http://i298.photobucket.com/albums/mm257/olivier30900/P1010111.jpg[/IMG]
Setup:
AQ50PRO
Keda 2050S
ESC 10A Hobbywing
GAUI 8" props
3S 2200mA 30C
http://www.youtube.com/watch?v=ETMPxtReY9Q&hd=1
Il love it
J'aime bien ton frame..!!!
Continue ton bon travail.
Ton GoPro est it stabilisé ? (Servo qui le fait basculé)
Eric
Dialfonzo is offline Find More Posts by Dialfonzo
Old Dec 17, 2011, 06:14 AM
Nîmes - France
Joined Nov 2010
Merci, non pas stabilisée, juste posé dans la frame .
Old Dec 17, 2011, 06:15 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Je suis curieux, je regarde pour faire un support.
Ca te donne de bon résultat ?
Old Dec 17, 2011, 07:07 AM
Nîmes - France
Joined Nov 2010
Oui très bien, mais on voit un peu les hélices devant.
Old Dec 17, 2011, 09:34 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Switching to english for everyone..
Which resolution you have try on the GoPro.
You said you see prop in the image, but try 1080, 720, 960. The don't do the same so maybe you will not have prop in one resolution.
Old Dec 17, 2011, 10:12 AM
Nîmes - France
Joined Nov 2010
Yes it's in R3 mode for this first fly.
I think in R5 i see less the props !
The rain coming, i don't fly in other mode for this time, but i'll be back :-)
Old Dec 17, 2011, 03:15 PM
Innsbruck, Austria
Joined Oct 2010
Ordered my TMF PRO in Taiwan last Sunday and received it on thursday with 15$-express-shipping, no problems at customs due to low price parcel marking.
This afternoon I mounted it (instead of FY-90Q) on my aluminium Quad with Turnigy Plush 25 A, GAUI 330X-motors and Futaba receiver.
Slight problems at the first try as I mounted it to fixed, but with some attenuation no problems at all. Flies perfectly indoor (due to weather can't try outside at the moment).
I like the software tool for calibration. It is rather cool to check the right mounting position or angle of the conroller. And I definitely like the arming of the motors: this is something extremely important for safety, which for example the Fyetech-products miss.
My version from Taiwan had smd-resistor already removed and firmversion 1.2 already installed!
The only critics at my current stage of knowledge is, that after disarming the motors spin slightly even at the throttle down. I would prefer that the motors would stay silent after disarming and start with more throttle.
Wolfgang
wolfgangm is online now Find More Posts by wolfgangm
Poll What Motors do you use on your tri/quad/hexa/octal etc? bob4432 Multirotor Talk 4 Aug 29, 2010 07:10 PM
Sold MicroKopter ARF Quad/Hexa G-unit Aircraft - Electric - Helis (FS/W) 3 Aug 23, 2010 09:38 AM
Discussion Folding frame for AP - tri, quad, Hexa, Okto danielpetrescu Multirotor Talk 9 May 10, 2010 12:25 AM
Question Tri/hexa-copter or Quad/Octa-copter and Spartan AP2000i or Helicommand Arthur P. VTOLs 2 May 20, 2007 03:02 PM
