Old Dec 25, 2011, 02:01 AM
torque roll is offline
Find More Posts by torque roll
A Texan abroad
torque roll's Avatar
Joined Oct 2011
Originally Posted by ysolomon View Post
I don't know, but you might just be able to pull it off, if you keep the plane really light. My SAPAC T-45 was not a very light plane (fiberglass and wood construction), and it flew on a single 70mm SAPAC MB-1 combo, on a 4S 4400mAh (2x 4S 2200mAh 40C in parallel), and the A-10 seems to be a much more "lifty" plane compared with the "bricky" T-45. Again--I haven't finished building mine to the point of flying it and telling you if my power system is an overkill... If the rule-of-thumb is that you need at least 200W/lb for an EDF jet, and you can get the plane to 6lb, you might be able to get away with 1200W setup, which you could run off a 4S battery (82A total, 42A per side). On 5300mAh battery, a 25C battery would be enough (although I would probably go with 30C or higher).
Take my advice/calculation above with a grain of salt, as I haven't finished/flown mine yet.
That's about what I thought. I was going to set it up to be light anyways using the fixed gear, and lightweight but good quality esc's as well as light batteries. I should have a pretty good flight time considdering 5300mah. That was my goal. Lightweight and moderately cheap with a good amount of flight time.
torque roll is offline Find More Posts by torque roll
Old Dec 25, 2011, 07:29 AM
ysolomon is offline
Find More Posts by ysolomon
Another one on the way...
ysolomon's Avatar
Plano, Texas
Joined Feb 2009
You probably want to consider motors with 3000-3300kv, then.
ysolomon is offline Find More Posts by ysolomon
Old Dec 25, 2011, 09:42 PM
A Texan abroad
Joined Oct 2011
Remember, cheap was a factor.
Just kidding. Who knows, maybe she'll fly on a 4s.
Old Dec 26, 2011, 01:46 AM
Paul5910 is offline
Find More Posts by Paul5910
Paul5910's Avatar
USA, TX, Houston
Joined Jul 2002
This plane looks like an absolute steal of a deal! AM I reading this right? A 1500mm balsa plane for $119.50!? That I can put 2 Change Sun 70mm fans in? Sounds too good to be true, but as soon as I get my next check I will have one of these on the way. I am looking forward to seeing you guys flight videos.
Paul
Paul5910 is offline Find More Posts by Paul5910
Old Dec 26, 2011, 08:25 AM
ysolomon is offline
ysolomon's Avatar
Plano, Texas
Joined Feb 2009
Hey, you can drive 4 hours north and see it in person... Three of us here in Plano are building the same plane, so we might have a triple maiden. Probably around March. This plane is really of high quality. For just over $100, I didn't expect it...
Old Dec 26, 2011, 10:59 AM
Chris2087 is offline
Find More Posts by Chris2087
LHS Supporter.....
United States, VA, Springfield
Joined May 2009
Is the covering of the plane able to be repainted? I am going to build this, but want to copy a local A-10 grayscale scheme.
Thanks Chris
Chris2087 is offline Find More Posts by Chris2087
Old Dec 26, 2011, 11:15 AM
ysolomon is offline
ysolomon's Avatar
Plano, Texas
Joined Feb 2009
It looks like it. It really helps that it is painted in matte, so any new coat of paint will catch on easily. I painted over some of my CMP P-40 covering which appears to be made of the same material, and had no problem.
Old Dec 26, 2011, 02:48 PM
joelkirsh is offline
Find More Posts by joelkirsh
United States, TX, Dallas
Joined Dec 2008
Looking good going to start mine soon
joelkirsh is offline Find More Posts by joelkirsh
Old Dec 28, 2011, 03:26 PM
Jeanskydive is offline
Find More Posts by Jeanskydive
Jeanskydive's Avatar
Canada, QC, Saint-Jean-sur-Richelieu
Joined Feb 2009
Maiden Thunderbolt A-10 from Nitro
Maiden for the A-10, this Nitro A-10 fly almost by imself, just apply power and gentel lignt pressure in the elevator and that-ist- that- hall., I flew in the just perfect weather to, no wind, minus -2F, verry dence air, so all conditions there for a good result maiden , I have plenty of juice with is little Mega 1625/2 with 5S-5000 LiPo for the maiden , 6Lipo will be the best for perfos.,in hot summer time in light thin air,. nex flight in nex good weather ( winter storm here now,) good powder snow I hope again,keep is track easy rudders , verry effective rudders, no problem there verry easy jet for the conversion for skis, different king of flying on the powder snow, this jet with is top mount motors no problem for the snow.I will down load a small video of is first lift off. Cheers
Jeanskydive is offline Find More Posts by Jeanskydive
Old Dec 28, 2011, 03:38 PM
bighead93 is online now
Find More Posts by bighead93
Live to fly
bighead93's Avatar
Sacramento
Joined Apr 2005
A drifting A-10! Very nice!
bighead93 is online now Find More Posts by bighead93
Old Dec 28, 2011, 10:00 PM
ysolomon is offline
ysolomon's Avatar
Plano, Texas
Joined Feb 2009
Finally, a maiden on this plane... Congratulations!
Old Dec 29, 2011, 01:19 AM
Joined Feb 2009
There a short video , maiden for the A-10 in the powder snow. Cheers
Maiden for the A-10 (0 min 16 sec)
Landing on the powder snow for the A-10 (0 min 13 sec)
Old Dec 29, 2011, 09:55 PM
X30PILOT is offline
Find More Posts by X30PILOT
X30PILOT's Avatar
Joined Aug 2007
Nice video. So I guess you could not con someone to stand out in the cold and film the whole flight?
X30
X30PILOT is offline Find More Posts by X30PILOT
Old Dec 29, 2011, 10:08 PM
ysolomon is offline
ysolomon's Avatar
Plano, Texas
Joined Feb 2009
Interesting how the batteries performed. My batteries seem to underperform when the temperature is under 50F...
Old Dec 29, 2011, 10:12 PM
Joined Feb 2009
A-10 Thunderbolt
Trrust power on the powder................Cheers
Engine run-up test (0 min 12 sec)
This a brand new S-5000 65 LiPo, I did some taxi a bit for warm-up a bit the pack and it performe verry nice in that particular day special cold mass air but zero wind so was not to bad. Cheers
Alert RC Nitro Tech (UK Only) - 10% OFF!!! artuan00 Hot Online Deals 2 Oct 24, 2011 06:41 AM
Question 10% vs. 15% nitro fuels? DanF Beginner Training Area (Fuel) 30 Oct 19, 2011 05:08 PM
Question Good Plane for a 7 or 9 0r 10 nitro engine Rob1962 1/2A Planes 7 Oct 08, 2011 04:25 PM
For Sale Trade 1/10 nitro buggy for micro plane dinopilot Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 May 06, 2011 03:38 PM
Help! Nitro-plane A-10 kit ? cyclops2 Foamies (Kits) 3 Nov 08, 2008 07:49 AM
